Home » Language IDEs » Java Development Tools (JDT) » Bumping up the Ant heapsize
Bumping up the Ant heapsize [message #15842] Tue, 06 May 2003 16:03 Go to next message
Originally posted by: twoytaszek.rsasecurity.com
Is there any way (via plugin.xml or other) to specify a min and max
heapsize for the ant tool. Default 64Mb just doesn't cut it for me. I want
to specify -Xms128m.
Looking at the plugin.xml for the and org.eclipse.ant.core_2.1.0 plugin,
it seems there may be some way to specify it:
<application>
<run
class="org.eclipse.ant.core.AntRunner">
</run>
</application>
Say it's so.
Tom
Re: Bumping up the Ant heapsize [message #15861 is a reply to message #15842] Tue, 06 May 2003 16:11 Go to previous message
Tom,
In 2.1 Ant is run in the same VM as Eclipse. So specify the min, max heap
size when starting the
Eclipse VM (using -vmargs -Xmx256M -Xms256M)
In the latest integration builds it is possible to specify to start Ant in a
separate VM...see https://bugs.eclipse.org/bugs/show_bug.cgi?id=24129
This feature is a work in progress.
HTH
Darins
"Tom" <twoytaszek@rsasecurity.com> wrote in message
news:b994ec$q7d$1@rogue.oti.com...
> <application>
> <run
> </run>
> </application>
> Say it's so.
> Tom
Previous Topic:missing incremental build
Next Topic:Debugger apparently does not work
Current Time: Wed Sep 03 08:08:44 EDT 2025
Powered by FUDForum. Page generated in 0.07377 seconds
