Servers View empty [message #155885] |
Wed, 11 January 2006 09:52  |
Originally posted by: pecanov.mt.net.mk
--=-cfeLus5yKfObr1Z3dLmx
Content-Type: text/plain
Today, out of nowhere, the Servers view came up empty.
Servers are present in "Servers" project in my workspace and I can add
them and remove them, but they are not listed in the servers view.
The view also seems not to render properly, since borders around
columns, and columns them selves are not shown. However, the
right-button menu is present. Very strange.
I've checked (.)logs but nothing is reported there.
Anyone has any clues about this?
I'm using Eclipse 3.1.1 with WTP 1.0, on Linux (GTK).
I haven't done any installing or upgrading to Eclipse, or it's plugins.
Thank you
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.8.1">
</HEAD>
<BODY>
Today, out of nowhere, the Servers view came up empty.<BR>
Servers are present in "Servers" project in my workspace and I can add them and remove them, but they are not listed in the servers view.<BR>
The view also seems not to render properly, since borders around columns, and columns them selves are not shown. However, the right-button menu is present. Very strange.<BR>
I've checked (.)logs but nothing is reported there.<BR>
<BR>
Anyone has any clues about this?<BR>
<BR>
I'm using Eclipse 3.1.1 with WTP 1.0, on Linux (GTK).<BR>
I haven't done any installing or upgrading to Eclipse, or it's plugins.<BR>
<BR>
Thank you<BR>
<BR>
<BR>
</BODY>
</HTML>
--=-cfeLus5yKfObr1Z3dLmx--
Re: Servers View empty [message #158301 is a reply to message #155918] |
Sun, 29 January 2006 07:32  |
Hi there!
I had the same problem a couple of times, so I diffed the .metadata
settings. Turns out it's only a column width problem! :) I filed a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=125642
There you have also the explanation on how to fix it.
It will still happen again, but at least you don't loose all your settings!
Miquel
Aleksandar Pecanov wrote:
> I know ...
> I did that too :(
> On Wed, 2006-01-11 at 17:14 +0000, Tande P wrote:
>>Had the same problem... I had to remove ALL eclipse settings (all .******)
>>and start over again and then it suddenly worked again.
FUDForum. Page generated in 0.04940 seconds
