Home » Eclipse Projects » GEF » SelectionTool - something like a "selection changed" event/request?
SelectionTool - something like a "selection changed" event/request? [message #158154] Tue, 16 November 2004 15:32 Go to next message
Originally posted by: iwan.global.co.za
Supposing a user clicks on something with the selection tool active - does
it generate a request? I need somehow to intercept such an event.
I am struggling to find some sort of definitive document describing what
events the SelectionTool reacts on, and what Requests it generates for
each. Is there something like this out there?
-i
Re: SelectionTool - something like a "selection changed" event/request? [message #158195 is a reply to message #158154] Tue, 16 November 2004 19:47 Go to previous messageGo to next message
Originally posted by: caniszc.us.ibm.com
Iwan Vosloo wrote:
> Hello,
> does it generate a request? I need somehow to intercept such an event.
> -i
* @see org.eclipse.gef.EditPart#setSelected(int)
public void setSelected(int value) {
super.setSelected(value);
To deal with object specific selections I override that method. I
specifically use it to add highlights to my editparts when they are
selected. Is this the best way to do it? Not sure, so if any GEF
developers want to give a better idea how to deal with this, go for it!
Peace,
~ Chris
Re: SelectionTool - something like a "selection changed" event/request? [message #158219 is a reply to message #158154] Tue, 16 November 2004 21:43 Go to previous messageGo to next message
No, it selects that editpart (and invokes setSelected(SELECTED_PRIMARY) on
that EditPart), unless it was already selected (in which case you get a
DIRECT_EDIT request). What do you want to do instead?
"Iwan Vosloo" <iwan@global.co.za> wrote in message
news:cndo4r$it0$1@www.eclipse.org...
> Hello,
> -i
Re: SelectionTool - something like a "selection changed" event/request? [message #158227 is a reply to message #158195] Tue, 16 November 2004 21:50 Go to previous messageGo to next message
"Chris Aniszczyk" <caniszc@us.ibm.com> wrote in message
news:cne738$9hq$1@www.eclipse.org...
> Iwan Vosloo wrote:
> > Hello,
> > -i
You should have a SelectionEditPolicy installed on the EditPart (which you
probably already have) and should override its showSelection() and
hideSelection() methods.
> Peace,
> ~ Chris
Re: SelectionTool - something like a "selection changed" event/request? [message #158349 is a reply to message #158154] Wed, 17 November 2004 13:20 Go to previous messageGo to next message
See the earlier post
> Hello,
> -i
Re: SelectionTool - something like a "selection changed" event/request? [message #158449 is a reply to message #158227] Thu, 18 November 2004 06:01 Go to previous messageGo to next message
thanks to all (and Randy's reply on my earlier post). I have also found
setSelected and proceeded to use it, although I was a bit uncomfortable
with the idea. A SelectionEditPolicy seems to be the proper answer then -
I have looked for it and could not find it though :-), so I will revisit
the issue.
-i
Re: SelectionTool - something like a "selection changed" event/request? [message #158455 is a reply to message #158227] Thu, 18 November 2004 08:06 Go to previous message
Originally posted by: jojo.virtutech.se
"Pratik Shah" <ppshah@us.ibm.com> writes:
What role should I use when installing it?
/Jesper
Previous Topic:Lines disappearing on grid
Next Topic:export GEF diagram as jpg
Current Time: Mon Sep 15 12:31:09 EDT 2025
Powered by FUDForum. Page generated in 0.05628 seconds
