Problem using WebDav FTP Plugin [message #157904] |
Wed, 25 January 2006 10:08  |
Originally posted by: richard.joyce.meteor.ie
I am having a problem using the WebDAV FTP plugin for eclipse. I am using
eclipse 3.1.1 with j2sdk1.4.2_09. I installed WebDAV FTP-Plugin from the
eclipse update site using Help\Software Updates\Find and Install
When I go to Import\export from\to the ftp site I get an eclipse error:
"Problem Opening Wizard
The selected wizard could not be started.
Reason
Plug-in org.eclipse.team.ftp was unable to load class
org.eclipse.team.internal.ftp.ui.subscriber.FTPExportWizard. "
org.eclipse.team.internal.ftp.ui.subscriber.FTPExportWizard is a class
which exists in the following jar:
C:\eclipse\plugins\org.eclipse.team.ftp_3.0.0\ftp.jar
For some reason this UI screen is not being properly loaded, can't really
understand why thoug.
I tried reinstalling eclipse and the plugin and also starting eclipse with
the - clean option, no luck
any help would be great
thanks
Richard
Re: Problem using WebDav FTP Plugin [message #158102 is a reply to message #158022] |
Thu, 26 January 2006 22:21   |
On Thu, 26 Jan 2006 03:53:11 -0500, Richard Joyce <richard@rejoyce.net> wrote:
> I tried it out with eclipse 3.0.2 and the WebDAV FTP plugin seems to work
> ok, it just doesn't work with 3.1.1. I tried installing it on 2 machines
> and its doesn't work using eclipse 3.1.1 on either of them. Does anyone
> know any thing about this issue?
I don't ... but, you mean on a "pure eclipse" install, right?
If so, you might ask or open a bug on the Eclipse Project.
(they distribute this ... I know, sounds like webtools :) ... and its
pretty much "as is" (unsupported) ... but if it didn't work at all, I'm sure
they'd appreciate knowing and I'm sure they'd investigate that.
On the other hand ... if you mean installed with WTP, you might first try to
see if it works without WTP :( .... *we* would be interested if there was some
bad interaction that prevented it from working with projects codes.
Re: Problem using WebDav FTP Plugin [message #170343 is a reply to message #157904] |
Wed, 31 May 2006 09:25  |
> eclipse update site using HelpSoftware UpdatesFind and Install
> When I go to Importexport fromto the ftp site I get an eclipse error:
> Reason
> C:eclipsepluginsorg.eclipse.team.ftp_3.0.0ftp.jar
tell me have solved a problem? I have the same trouble, :-( winXP, J2SE
5.0 Update 6, Eclipse 3.1.1...
FUDForum. Page generated in 0.04504 seconds
