Home » Language IDEs » C / C++ IDE (CDT) » different error parser in standard make
different error parser in standard make [message #157931] Mon, 14 November 2005 10:33 Go to next message
Originally posted by: henrik.lindstrom.ericsson.com
I am trying to implement a remote make using a standard make project.
The build is working but I want CDT to parse the result.
How can I add different error parsers to a standard make project? I lack
the possibility to edit the error parser list in the project settings
(both for managed build and standard make projects).
Is it only possible by defining a new managed build system? However I do
not want to specify all the tool-chain since I am just needing the
'standard make' part for my remote make. I tried to skip the
tool/configuration parts of the extension but then the project settings
dialog will get exceptions when I try to use it (since the compiler etc
are missing).
Henrik
Re: different error parser in standard make [message #158021 is a reply to message #157931] Mon, 14 November 2005 16:11 Go to previous messageGo to next message
Found the answer myself. Any Error Parser is automatically available in
the error parser list. I did not see that anywhere in documentation but
now I tested and my parser is listed under preferences.
Thanks anyway...
Re: different error parser in standard make [message #158087 is a reply to message #158021] Wed, 16 November 2005 02:50 Go to previous messageGo to next message
"Henrik L" <henrik.lindstrom@ericsson.com> wrote in message
news:1a6e1195e58fa7d91286d0ed90f94f0d$1@www.eclipse.org...
> are missing).
> Regards,
> Henrik
news:7c3a40f368eda16d902cc21ce552318d$1@www.eclipse.org...
> Thanks anyway...
No, I cannot get CDT to run my new error parser. Seems like it is not loaded
at all. I've added tracing but it is never called.
The error parser, a clearmake variant of the make parser, is listed in the
Error Parser tab for standard C/C++ make project, but when I perform a built
it does not get called.
Any ideas? Could this be a bug?
/Henrik
Re: different error parser in standard make [message #158181 is a reply to message #158087] Wed, 16 November 2005 14:27 Go to previous messageGo to next message
Originally posted by: eclipse.dharty.com
First, is your error parser selected? You mention that it is listed,
but you never said if you selected it.
Second, have you tried running it from the plugin debugger? Put a
breakpoint at the entry point of your parser, launch the debugger, open
up a project in the "Debug" eclipse, ensure that the error parser is
selected, and then try to build some code with a known error.
If your breakpoint is never hit, you have a problem, but if it your
parser is showing up in the parser list, it should be getting called.
D
>>are missing).
>>Regards,
>>Henrik
>>Thanks anyway...
> /Henrik
Re: different error parser in standard make [message #158707 is a reply to message #158181] Tue, 22 November 2005 05:13 Go to previous message
> D
Yes, I made those steps. I set a breakpoint as well and run the debugger.
Made a new project and selected the parser (replaced the make error parser
and put it first in the error parser list as well).
But while building code it never enter my plugin. I might add the I use
this for a "remote build" which I perform like this using a standard make
project.
- Replace 'make' command with "rsh [HOST]-l [USER]
/usr/atria/bin/cleartool setview -exec 'cd [SRCPATH];make' [VIEW]"
It is in its beginning state so for now I have settled with hardcoded
arguments, but will change to at least variables (the [XXX] parts). Or
perhaps make some extension to the clearcase plugin since source is in
clearcase on the remote build machine as well.
The build is working (I see output in eclipse console). However clearmake
report any error beginning with "clearmake:" instead of "make:" as the
default make error parser expects.
The default linker error parser is reporting a few errors so integration
between my remote make command and CDT seems to work, just my own parser
is not run.
Henrik
Previous Topic:Debug: Cannot access memory at address 0x0
Next Topic:Can not run executable from within Eclipse
Current Time: Wed Jul 23 10:21:34 EDT 2025
Powered by FUDForum. Page generated in 0.05176 seconds
