Home » Eclipse Projects » GEF » ContextMenuProvider + selected editParts
ContextMenuProvider + selected editParts [message #157766] Fri, 12 November 2004 05:16 Go to next message
Originally posted by: james.willans.xactium.com
Is it possible to know which editparts are selected in a
ContextMenuProvider? I want to be able to calculate which menus to show
based on this knowledge. Note that there is not enough information in the
SelectionAction since I need the set of (enabled) actions and the set of
selected edit parts.
Thanks.
James
Re: ContextMenuProvider + selected editParts [message #157814 is a reply to message #157766] Fri, 12 November 2004 10:00 Go to previous messageGo to next message
Originally posted by: gaslade.yahoo.com
What about selectionAction.getSelectedObjects(). This gives you a list
of the selected edit parts. The calculateEnabled() method of your
action(s) can use this to decide if they are enabled or not.
Guy
> the SelectionAction since I need the set of (enabled) actions and the
> set of selected edit parts.
> Thanks.
> James
Re: ContextMenuProvider + selected editParts [message #157844 is a reply to message #157814] Fri, 12 November 2004 12:17 Go to previous messageGo to next message
Guy,
Yes - I'm currently using that route, I was just wondering whether the
list of selected edit parts was scoped over the ContextMenuProvider.
Thanks anyway.
James
> Guy
>> Thanks.
>> James
Re: ContextMenuProvider + selected editParts [message #157857 is a reply to message #157766] Fri, 12 November 2004 12:53 Go to previous messageGo to next message
I don't understand the question. ContextMenuProvider contains the
EditPartViewer, so you just need to call getSelection()
"James Willans" <james.willans@xactium.com> wrote in message
news:cn22ip$tm4$1@eclipse.org...
> Thanks.
> James
Re: ContextMenuProvider + selected editParts [message #157872 is a reply to message #157844] Fri, 12 November 2004 13:36 Go to previous messageGo to next message
Ok, I understand what you want to do. But I think the right way to do it
is through the action enabled/disabled route. If you don't want disabled
actions to show in your context menu then when your context menu
provider builds the menu prior to showing it should only add the actions
that are enabled.
Guy
> Guy,
> Thanks anyway.
> James
>> Guy
>>> show based on this knowledge. Note that there is not enough
>>> information in the SelectionAction since I need the set of (enabled)
>>> actions and the set of selected edit parts.
>>> Thanks.
>>> James
Re: ContextMenuProvider + selected editParts [message #158089 is a reply to message #157844] Mon, 15 November 2004 11:49 Go to previous message
JFace already provides a filter mechanism. You need to provide the filter
processor, and fill in the rules for your actions in the plugin.xml file.
The only reason to use this mechanism would be to prevent plug-in startup.
Otherwise, I'd just use the enablement technique we use in the examples.
news:cn2r7o$dpv$1@eclipse.org...
> Guy,
> Thanks anyway.
> James
> > Guy
show
> >> Thanks.
> >> James
Previous Topic:connection endpoints not placed correctly
Next Topic:GEF Editor freezes when ContextMenu is to be displayed (solved)
Current Time: Tue Jul 22 13:12:29 EDT 2025
Powered by FUDForum. Page generated in 0.03137 seconds
