Home » Language IDEs » ServerTools (WTP) » Installing WTP plugin
Installing WTP plugin [message #157598] |
Sat, 21 January 2006 19:33  |
Originally posted by: jazeltine.sbcglobal.net
<rant>
Ok, I have finally gotten to the point of getting irritated. I have an
Eclipse 3.1 version running with WTP. I did this last year, and to be
perfectly honest, I don't know how I did it. I tried to install the
plugin, but no matter what I did, none of the features would work. Then
I read in a post that using an update site would work, so I tried that.
That seemed to work. I tried to do it a second time, and I was unable
to! >8|
It appears that the update site that I was using no longer exists, and
the new version is completely different and does not work! I do not know
how many times I have read posts where people have stated that they
installed a plugin, but it doesn't work, and they cannot figure out why.
This is NOT RIGHT. If all the dependencies for a plugin are not met,
then something needs to happen! I truly love the Eclipse product, but
this one thing is so frustrating, it makes me a little crazy.
We need to be able to reliably install plugins, and have a repeatable
method for finding out why a plugin doesn't work. IMHO, being forced to
go to an update site just to get something to work because the download
package is errored or incomplete is CRAP! Downloads need to be correct,
if they are not they need to be fixed! If a plugin doesn't work, what is
the best method to go about figuring out why?
So just when I thought things were getting better... I downloaded the
new all-in-one version. It installed fine. Only problem is that IT
DOESN"T WORK! No matter what I did, none of the projects that I spent
all taht time on in the previous version would work after they were
imported.
</rant>
Re: Installing WTP plugin [message #157668 is a reply to message #157598] |
Mon, 23 January 2006 08:13   |
Originally posted by: caclark.cox.net
Jim Azeltine wrote:
> <rant>
> to! >8|
> imported.
> </rant>
Perhaps you could look in the .log file and see if there are any errors
reported there. And, if so, share them with others to help you solve
the problem. I've installed on several machines with different JDK's
and everything worked fine.
You should give details on versions of all the software you're using
from the OS to the JDK.
Re: Installing WTP plugin [message #157770 is a reply to message #157668] |
Mon, 23 January 2006 20:54   |
Cary Clark <caclark@cox.net> wrote in
news:dr2kpv$qi$1@utils.eclipse.org:
> Jim Azeltine wrote:
>> <rant>
>> an Eclipse 3.1 version running with WTP. I did this last year, and to
>> be perfectly honest, I don't know how I did it. I tried to install
>> the plugin, but no matter what I did, none of the features would
>> work. Then I read in a post that using an update site would work, so
>> I tried that. That seemed to work. I tried to do it a second time,
>> and I was unable to! >8|
>> and the new version is completely different and does not work! I do
>> not know how many times I have read posts where people have stated
>> that they installed a plugin, but it doesn't work, and they cannot
>> figure out why. This is NOT RIGHT. If all the dependencies for a
>> plugin are not met, then something needs to happen! I truly love the
>> Eclipse product, but this one thing is so frustrating, it makes me a
>> little crazy. We need to be able to reliably install plugins, and
>> have a repeatable method for finding out why a plugin doesn't work.
>> IMHO, being forced to go to an update site just to get something to
>> work because the download package is errored or incomplete is CRAP!
>> Downloads need to be correct, if they are not they need to be fixed!
>> If a plugin doesn't work, what is the best method to go about
>> figuring out why? So just when I thought things were getting
>> better... I downloaded the new all-in-one version. It installed fine.
>> Only problem is that IT DOESN"T WORK! No matter what I did, none of
>> the projects that I spent all taht time on in the previous version
>> would work after they were imported.
>> </rant>
> errors reported there. And, if so, share them with others to help you
> solve the problem. I've installed on several machines with different
> JDK's and everything worked fine.
I have tried this on both Windows 2000 (all service packs) and XP (home
version, no service packs). I installed JDK 1.4.2_08 in both machines.
In both cases I did not find any errors in the log. I have finally come
to the conclusion that the standard process of installing the plugins by
extracting them into the eclipse folder and restarting eclipse is just
not suitable for installing WTP (and all the related stuff like EMF,
GEF, etc.). There is one or more things that are happening when the
install is done using the update manager that are not being done the
other way.
I did try a new thing which did work, although I am not sure why. I
found some text in the eclipse book that I bought about creating a local
update site for the update manager. I extracted all of the packages into
this local site and ran the update manager aginst it. The odd thing is
that once I did that, it found the correct update sites on the network
and installed everything correctly, even though I did not enter the
information for those update sites. Now that install is working. Very
strange.
Jim
Re: Installing WTP plugin [message #158043 is a reply to message #158014] |
Thu, 26 January 2006 09:42  |
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <Xns9756E245A580jamesrazeltinesaicco@206.191.52.34>,
jazeltine@sbcglobal.net says...
> alrenb@gmail.com (R B) wrote in
> news:50955785bdaae13265f885848c1a1169$1@www.eclipse.org:
> > I ended up just downloading this :
> > http://www.eclipse.org/downloads/download.php?
> file=/webtools/downloads/
> > drops/R-1.0-200512210855/wtp-all-in-one-sdk-1.0-win32.zip
> > which has everything you need for WTP.
> > Thanks,
> > R
> Unfortunately, I did try that. That is one of the reasons I got
> irritated. The install was painless, but alas, it is buggy. Here is an
> excerpt from a post on Jan 15 on the WTP 1.0 maintenance release:
> "WTP 1.0 is unusable without patches
> (saving takes 5-10 seconds, look at all those bug-reports and forum
> posts about that issue), and delaying a usable release until
> mid-february forces everyone to either drop WTP or install a nightly
> build."
> Oh well, at least I figured out a way to get the older version installed
> and working.
Yeah, I'm still running Eclipse 3.0 and WTP 0.7 until they get the
3.2/1.5 installation working.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Current Time: Sat Sep 06 12:38:38 EDT 2025
Powered by FUDForum. Page generated in 0.03991 seconds
