Home » Eclipse Projects » GEF » Strategy to handle empty editor inputs
Strategy to handle empty editor inputs [message #157616] |
Wed, 10 November 2004 21:08  |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
I noticed that if i create a logic example, then go to the filesystem
and delete it, then double click it in the project, the logic program
does not explode.
currently my application explodes with selection errors and i have to
end eclipse with ctrl-alt-del or stop the debugger.
What technique should I used when I am passed a FileEditorInput that
happens to not actually contain a file?
The errors are from the UI thread or at least that is where I am
catching them, and that really does not tell me anything. I think the
class that is initiating the error is not logging it appropriately and
thus I can not trace back to it...
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Strategy to handle empty editor inputs [message #157728 is a reply to message #157616] |
Thu, 11 November 2004 16:57   |
Look at LogicEditor#setInput(). It fails to read data from the file and
prints that exception to stderr. But it doesn't "blow up" because
logicDiagram is initialized to a new instance of LogicDiagram, and that
serves as the contents for the viewer.
"CL [dnoyeb] Gilbert" <Lamont_Gilbert@rigidsoftware.com> wrote in message
news:cmuhhi$c4$1@eclipse.org...
> does not explode.
> Respectfully,
> CL Gilbert
Re: Strategy to handle empty editor inputs [message #157783 is a reply to message #157728] |
Fri, 12 November 2004 08:20   |
I did look, and I did try that. But it didnt work.
That got me into some crazy looping dialog box errors and had to kill
the app. Seems like logic example sets the contents of the graphical
viewer at the same time the model is set whereas I set the graphical
viewer in initializegraphicalViewer. That seems the only difference but
i cant really debug it with the action in the UI threads being
disconnected from their source.
Some class is opening up error dialogs but not dumping stack traces
beforehand.
>>does not explode.
>>Respectfully,
>>CL Gilbert
Respectfully,
CL Gilbert
Re: Strategy to handle empty editor inputs [message #157806 is a reply to message #157783] |
Fri, 12 November 2004 09:52   |
Originally posted by: gaslade.yahoo.com
You need to do more investigating if Pratik's solution did not work. If
your editor follows along the same general flow as the logic editor (
which almost everyones will since everyone uses it as a leaping point )
then you will see when the editor starts opening the .setInput() method
is called passing in the editor input. This ought to be a file that your
code knows how to interpret and build a model from.
As Pratik has said, in the case of the logic example, if anything
horrible happens while it is trying to interpret the file and build the
model then it is caught, reported and a model is created that is empty.
The setInput method in the logic example does not need to set the
graphical viewer input..... I don't know why it does. If you take a look
at the initializeGraphicalViewer() method of the logic example you will
see that it has the same code in it to set the viewer contents.
In fact, you don't actually have to create the model in the setInput
method if you don''t want to. I have an editor that has a getter for the
model and it creates it lazily.
Anyway, there a few things to ponder but really it sounds like it is up
to you to debug.
Guy
> beforehand.
>>> does not explode.
>>> Respectfully,
>>> CL Gilbert
Re: Strategy to handle empty editor inputs [message #157829 is a reply to message #157806] |
Fri, 12 November 2004 11:06   |
That is to handle the case where, once the editor is already open, the
underlying file is changed (eg., you replace the file in workspace with a
previous version from the repository).
"Guy Slade" <gaslade@yahoo.com> wrote in message
news:cn2ili$s20$1@eclipse.org...
> to you to debug.
> Guy
> > beforehand.
and
message
> >>> does not explode.
> >>> Respectfully,
> >>> CL Gilbert
into
Re: Strategy to handle empty editor inputs [message #157852 is a reply to message #157829] |
Fri, 12 November 2004 12:22   |
Well that is the failure I am trying to overcome. So perhaps I can try
setting the model into the graphicalViewer inside the setInput method as
well. Hard to see why this is required, but not hard to see the
explosion that is happening in my code now.
Actually my code works well if I keep the model null. But if i make a
default model like logic example, but dont add it to the
graphicalViewer, all hell breaks loose when an empty IEditorInput is
sent to my class...
>>to you to debug.
>>Guy
>>>beforehand.
> and
> message
>>>>>does not explode.
>>>>>Respectfully,
>>>>>CL Gilbert
> into
Respectfully,
CL Gilbert
Re: Strategy to handle empty editor inputs [message #158013 is a reply to message #157880] |
Fri, 12 November 2004 17:20   |
> > sent to my class...
> When does an empty IEditorInput get sent to setInput() ?
Like Pratik said, when there is a file resource in the project, but the
file has been deleted using some OS level technique that Eclipse is
unaware of. Its not empty per se. It contains a File, that simply does
not point to a file and will throw exceptions when you try to get one
out of it.
Respectfully,
CL Gilbert
Re: Strategy to handle empty editor inputs [message #158028 is a reply to message #157852] |
Sun, 14 November 2004 20:40   |
This is not exactly the problem you're trying to fix. Yours is a change not
detected by Eclipse. The case I was talking about is where the file is
replaced in the workspace (with the editor already open). The platform is
aware of this change and will invoke setInput() on your editor with the new
contents.
news:cn2rfc$dc2$2@eclipse.org...
> well. Hard to see why this is required, but not hard to see the explosion
> default model like logic example, but dont add it to the graphicalViewer,
> all hell breaks loose when an empty IEditorInput is sent to my class...
>>>to you to debug.
>>>Guy
>>>>beforehand.
>> and
>> message
>>>>>>does not explode.
>>>>>>Respectfully,
>>>>>>CL Gilbert
>> into
> Respectfully,
> CL Gilbert
> the sheepfold{}, but climbeth up some other *way, the same is a thief and
Re: Strategy to handle empty editor inputs [message #158071 is a reply to message #158028] |
Mon, 15 November 2004 08:05   |
How can I cause the file to be replaced in the workspace? Sounds like
an interesting test considering I am not setting the GraphicalViewer
input when I get new editor input directly.
> contents.
>>>>to you to debug.
>>>>Guy
>>>>>beforehand.
>>>and
>>>message
>>>>>>>does not explode.
>>>>>>>Respectfully,
>>>>>>>CL Gilbert
>>>into
>>Respectfully,
>>CL Gilbert
Respectfully,
CL Gilbert
Re: Strategy to handle empty editor inputs [message #158252 is a reply to message #158071] |
Tue, 16 November 2004 22:36  |
As I mentioned already, one example is by replacing the file in the
workspace with a previous version from the repository or local history.
news:cna9jc$qlv$2@eclipse.org...
not
is
new
> > contents.
message
look
a
explosion
graphicalViewer,
If
point )
method
your
the
empty.
look
will
the
up
> >>>>to you to debug.
> >>>>Guy
but
> >>>>>beforehand.
> >>>and
that
> >>>message
filesystem
program
> >>>>>>>does not explode.
to
that
the
and
> >>>>>>>Respectfully,
> >>>>>>>CL Gilbert
> >>>into
thief
> >>Respectfully,
> >>CL Gilbert
and
> Respectfully,
> CL Gilbert
Current Time: Sun Aug 31 09:56:50 EDT 2025
Powered by FUDForum. Page generated in 0.15353 seconds
