| Re: Program g++ and gcc NOT FOUND In PATH!!!!! [message #1700601 is a reply to message #1576414] |
Sat, 04 July 2015 11:23   |
Your English is far easier to understand than native speakers who assume a huge amount of knowledge.
I have followed your steps, but i have the following problems:
Problem pane:
Description Resource Path Location Type
Program "g++" not found in PATH Preferences, C++/Build/Settings/Discovery, [CDT GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "gcc" not found in PATH Preferences, C++/Build/Settings/Discovery, [CDT GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
undefined reference to `WinMain' [project name] line 0, external location: C:\MinGW\x86_64-w64-mingw32\lib\libmingw32.a(lib64_libmingw32_a-crt0_c.o):crt0_c.c C/C++ Problem
A little red X symbol on the project in the Project explorer
When i choose Run/Run or Run/Debug, I get the error "Launching [project name].exe has encountered a problem., Program file does not exist.
Indeed the file does not exist at that location, and I have no idea how to put it there. Can anyone help please?
| Re: Program g++ and gcc NOT FOUND In PATH!!!!! [message #1842413 is a reply to message #1298610] |
Fri, 18 June 2021 01:50  |
I am using win7 OS. I ve been fighting for almost a month to get Eclipse Working with C/C++. read thousands of topics and comments..
I downloaded and reinstall Eclipse 10 times but didnt get anything (Now I think reinstall OS also, NuEclipse is Worst IDE I ever seen). installed MinGw, put gcc and g++ whatever...
but when i try to compile a simple Hello World it shows me 2/3 errors one by one.
1. Program file not found
2. Error: gdb --version
3. Program g++ and gcc NOT FOUND In PATH... Mad
4. Error i starting sequence
NuEclipse is Worst IDE I ever seen...Any help whould be appreciated....
FUDForum. Page generated in 0.14426 seconds
