Home » Modeling » UML2 » Registering and loading a profile programatically (standalone)
Registering and loading a profile programatically (standalone) [message #1573732] Mon, 19 January 2015 17:46 Go to next message
Hi. I'm trying to load a model with a profile in a standalone application.
I've followed the tutorial at http://wiki.eclipse.org/MDT/UML2/Introduction_to_UML2_Profiles#Loading_Models
but that still doesn't clarify how to register a third-party profile.
Some related threads suggest looking at UMLResourcesUtil to see how standard profiles are registered. Following the pattern there, I manage to register the profile (see attached file), and at first it seems to work, but as soon as I try to apply it, I get the following exception:
applying profile: org.eclipse.uml2.uml.internal.impl.ProfileImpl@3e5c7b6b (name: UMLRealTime, visibility: <unset>) (URI: http://www.eclipse.org/papyrus/umlrt)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject(ResourceImpl.java:737)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223)
	at org.eclipse.uml2.uml.util.UMLUtil.getProfile(UMLUtil.java:11298)
	at org.eclipse.uml2.uml.util.UMLUtil.getNamedElement(UMLUtil.java:11494)
	at org.eclipse.uml2.uml.util.UMLUtil.getNamedElement(UMLUtil.java:11444)
	at org.eclipse.uml2.uml.util.UMLUtil.getStereotype(UMLUtil.java:11506)
	at org.eclipse.uml2.uml.util.UMLUtil.getStereotype(UMLUtil.java:11533)
	at org.eclipse.uml2.uml.internal.operations.ElementOperations.getStereotypeApplications(ElementOperations.java:213)
	at org.eclipse.uml2.uml.internal.impl.ElementImpl.getStereotypeApplications(ElementImpl.java:186)
	at org.eclipse.uml2.uml.internal.operations.PackageOperations.applyProfile(PackageOperations.java:672)
	at org.eclipse.uml2.uml.internal.impl.PackageImpl.applyProfile(PackageImpl.java:1083)
	at eposse.experiments.profiletest.ProfileTest.applyProfiles(ProfileTest.java:75)
	at eposse.experiments.profiletest.ProfileTest.main(ProfileTest.java:34)
If I comment out the line applying the profiles, I still get the same exception when invoking "getAppliedStereotypes".
What's the problem what am I doing wrong?
Thanks.
Re: Registering and loading a profile programatically (standalone) [message #1575046 is a reply to message #1573732] Tue, 20 January 2015 10:48 Go to previous messageGo to next message
Hi, Ernesto,
This is happening because you put only the URI of the profile
*resource* into UML2's profile location map. At line 50 of your
ProfileTest.java, you need to map the profile namespace URI to the URI
of the root Profile *object* in the profile resource.
The consequence of putting the resource URI in this map is that the
UMLUtil::getProfile(...) method passes a URI having no fragment to the
ResourceSet::getEObject(...) API, which results on an NPE on the null
fragment.
HTH,
Christian
> applying profile:
> at
> at
> at
> at
> at
> at
> at
> Thanks.
> <image><image>
Re: Registering and loading a profile programatically (standalone) [message #1575511 is a reply to message #1575046] Tue, 20 January 2015 16:36 Go to previous message
Thanks Christian.
Pointing to the root element of the profile works. However, I still have another problem: stereotypes do not seem to be applied even though the stereotype instances are in the XMI, and in the resource contents. Furthermore, if I explicitly try to apply all applicable stereotypes to the relevant elements, the stereotype instances seem to be created (I see them in the debugger), but when I try to "getAppliedStereotypes" on the elements, after "element.applyStereotype(stereotype)" I obtain an empty list!
See the new version attached.
Am I missing some step to get the stereotype instances attached to the appropriate elements?
Previous Topic:Registering and loading a profile programatically (standalone)
Next Topic:getAppliedStereotypes() does not work when model and profile are in the same file ?
Current Time: Mon Jul 21 00:33:41 EDT 2025
Powered by FUDForum. Page generated in 0.03364 seconds
