Home » Modeling » OCL » Using sortedBy
Using sortedBy [message #1573311] Mon, 19 January 2015 12:15 Go to next message
Hi all,
I have defined two stereotypes (A and B), and a stereotype for a
dependency (RelationshipC) in a profile to relate A and B stereotypes.
RelationshipC has an attribute 'Order' that is supposed to be used to
specify an ordering between the several instances of RelationshipC that
an A element could have with several Bs (please, see the images attached).
I've written some OCL that gets the relationships from a specific A
element and it works.
self.clientDependency->select(p : UML::Dependency |
p.getAppliedStereotypes().qualifiedName->includes('profile::RelationshipC'))
However, I would like to get the dependencies sorted according to its
'Order' attribute. I guess I should use something like:
p.getAppliedStereotypes().qualifiedName->includes('profile::RelationshipC'))->sortedBy(Order)
But I can't find examples on how to use sortedBy.
Could anybody help me?
Please, find attached also the project with the profile and the model
that uses it.
Greetings,
Víctor
Re: Using sortedBy [message #1573370 is a reply to message #1573311] Mon, 19 January 2015 13:02 Go to previous messageGo to next message
What you are doing is nearly right, but because you are using the UML2
project Java API you have lost type information, which you could
re-instate with an oclAsType(profile::RelationshipC).
The new Povot-based Xtext support in the OCL project is moving to
supporting stereotype navigation in a type-safe fashion as hinted at by
the UML specification.
Something like (untested) might be better
self.clientDependency->selectByKind(UML::Dependency).extension_RelationshipC->sortedBy(Order)
Traditionally sortedBy takes an expression that computes a
String/Integer that determines the sort order. The Pivot-based support
introduces an OclComparable type for use as the sortedBy argument type
so that it is extensible to arbitrary user types such as Date.
Ed Willink
On 19/01/2015 17:15, "V. López" wrote:
> Hi all,
> that uses it.
> Greetings,
> Víctor
Re: Using sortedBy [message #1574764 is a reply to message #1573370] Tue, 20 January 2015 07:17 Go to previous messageGo to next message
Thanks for the quick answer Ed, it worked in the console.
However, I would like to use it also in Acceleo.
Thus, "extension_RelationC" nor oclAsType(profile::RelationshipC) syntax
work with my own profile, at least without registering the profile by
creating a plug-in.
Is there a workaround to use sortBy in that situation or an alternative
way of ordering?
Greeting,
Víctor
El 19/01/2015 a las 19:02, Ed Willink escribió:
> Hi
> Regards
> Ed Willink
>> Hi all,
>> attached).
>> that uses it.
>> Greetings,
>> Víctor
Re: Using sortedBy [message #1574765 is a reply to message #1573370] Tue, 20 January 2015 07:18 Go to previous messageGo to next message
creating a plug-in.
way of ordering?
Greeting,
Víctor
> Hi
> Regards
> Ed Willink
>> Hi all,
>> attached).
>> that uses it.
>> Greetings,
>> Víctor
Re: Using sortedBy [message #1574861 is a reply to message #1574765] Tue, 20 January 2015 08:34 Go to previous messageGo to next message
You're unlikely to get this working in Acceleo.
Use it's ability to invoke some Java code. If you've not used it yet,
it's worth learning.
Ed Willink
> creating a plug-in.
> way of ordering?
> Greeting,
> Víctor
>> Hi
>> Regards
>> Ed Willink
>>> Hi all,
>>> attached).
>>> that uses it.
>>> Greetings,
>>> Víctor
Re: Using sortedBy [message #1575102 is a reply to message #1574861] Tue, 20 January 2015 11:25 Go to previous message
Thanks Ed. I'll give it a try.
El 20/01/2015 a las 14:34, Ed Willink escribió:
> Hi
> Regards
> Ed Willink
>> creating a plug-in.
>> way of ordering?
>> Greeting,
>> Víctor
>>> Hi
>>> Regards
>>> Ed Willink
>>>> Hi all,
>>>> attached).
>>>> that uses it.
>>>> Greetings,
>>>> Víctor
Previous Topic:Working with MARTE
Next Topic:ecore to oclinecore conversion, single line comments disappear
Current Time: Fri Jul 25 08:33:55 EDT 2025
Powered by FUDForum. Page generated in 0.28288 seconds
