Home » Language IDEs » PHP Development Tools (PDT) » SQL and Properties File Editors no more available ?
SQL and Properties File Editors no more available ? [message #1567305] Fri, 16 January 2015 04:19 Go to next message
Hi everybody !!
On my old Eclipse (Europa) I used to open my SQL files with the "SQL File Editor" and my .htaccess files (e.g) with the "Properties File Editor.
But I recently switched to Eclipse Luna version and they are no more available in the list of proposed Editors (both in Internal and External).
Can I add some Editors in this list ? And if yes how ?
Or perhaps I have to change my behaviors and so I would need some suggestions to work on this files (SQL, .htaccess and other strange files commonly found in a Web-PHP project).
Thank a lot for your help and time,
Aurélien.
Re: SQL and Properties File Editors no more available ? [message #1567683 is a reply to message #1567305] Fri, 16 January 2015 09:10 Go to previous messageGo to next message
For SQL files you can use DBeaver, available on marketplace, have also many other advance fatures. On Europa you probably worked with http://eclipsesql.sourceforge.net/
Properties file editor is part of JDT, so you need Java capabilities to use it again.
Re: SQL and Properties File Editors no more available ? [message #1572693 is a reply to message #1567683] Mon, 19 January 2015 04:22 Go to previous messageGo to next message
Thanks a lot Dawid !
And so, now my question become, is there a way to include Java capabilities in PHP project ?
Re: SQL and Properties File Editors no more available ? [message #1572824 is a reply to message #1572693] Mon, 19 January 2015 06:05 Go to previous messageGo to next message
Found !
In Help -> Install new softwares ...
And so resolved.
Thanks one more time.
[Updated on: Mon, 19 January 2015 06:07] by Moderator
Re: SQL and Properties File Editors no more available ? [message #1572832 is a reply to message #1572824] Mon, 19 January 2015 06:10 Go to previous message
Go to : Help->Install new software.
Select Luna update site.
Wait a moment.
Check "Eclipse Java Development Tools" under "Programming Languages"
Previous Topic:Importing files from other directories
Next Topic:What does the project folder + icon mean?
Current Time: Wed Sep 03 16:51:15 EDT 2025
Powered by FUDForum. Page generated in 0.03379 seconds
