Home » Eclipse Projects » BPMN 2.0 Modeler » Validation decorators missing
Validation decorators missing [message #1572707] Mon, 19 January 2015 04:31 Go to next message
Hi Bob,
Using version 1.1.1 of the modeler, I noticed that I do not have validation decorators in the diagram anymore.
I looked at the getDecorators() method in the Bpmn2ToolBehaviorProvider class and I observed that ShapeDecoratorUtil.isValidationDecorator(pe) is always false and I never enter the block which should add the decorators. I found that the only place where you set the GraphitiConstants.VALIDATION_DECORATOR property is in the ShapeDecoratorUtil.createValidationDecorator(), which is only called in AbstractBpmn2AddFeature.decorateShape(). For activity elements, this method is overriden in AbstractAddTaskFeature class and so not called. For event elements, the decorator pictogram element is created, but with the active property set to false, and the Graphiti framework seems to not call the getDecorators() method for non-active pictogram elements.
I managed to add a validation decorator on a custom task by overriding the decorateShape() in my add feature and calling ShapeDecoratorUtil.createValidationDecorator() then setting the active property on the returned pictogram element (the error marker is not very well positioned in the left corner, but that's another story).
I hope my explanations are not too confused. Let me know if I misinterpreted the code. If you think a bug needs to be filled in bugzilla, I can do it as well.
Thank you very much.
Cédric
Re: Validation decorators missing [message #1575620 is a reply to message #1572707] Tue, 20 January 2015 18:03 Go to previous messageGo to next message
This looks like a regression. I've filed this bugzilla to track the issue.
Thanks for keeping me honest Wink
Bob
Re: Validation decorators missing [message #1587244 is a reply to message #1575620] Tue, 27 January 2015 03:17 Go to previous messageGo to next message
Hi Bob,
I tested with latest build Luna 1.1.1.201501262023 and the problem decorators are back.
Thanks for your responsiveness !
Re: Validation decorators missing [message #1587663 is a reply to message #1587244] Tue, 27 January 2015 08:39 Go to previous message
My pleasure Smile
Previous Topic:Luna update repository
Next Topic:Contributions
Current Time: Sun Jul 27 12:03:11 EDT 2025
Powered by FUDForum. Page generated in 0.03901 seconds
