Home » Eclipse Projects » GEF » Adding Label to PolylineDecoration
Adding Label to PolylineDecoration [message #156535] |
Mon, 01 November 2004 19:41  |
Originally posted by: bandrews.nospam_bphnx.com
I cannot seem to get this to work. I got this to work with a
PolylineConnection by extending it and using the ConnectorLocator to
relocate the labels, but what I want now is the 2 labels to follow the
decorator around. So in the end, I want one Label above the source
decorator and one Label below. I tried extending the PolylineDecoration
and using an ArrowLocator to relocate the labels, however the relocate()
method expects a RotableDecoration which Label is not. Am I going about
this all wrong? What am I missing? I cannot even get the Label to show on
the screen.
thanks,
B
Re: Adding Label to PolylineDecoration [message #156766 is a reply to message #156695] |
Thu, 04 November 2004 09:56   |
If children were not meant to be added, why is there add() methods?
Anyway, I did figure out to use the ConnectionEndPointLocator to get the
same effect like you said.
But now, I have run into another problem. It seems that my labels are
always one step behind the connectors current position. So for example, if
I move an object (that has a connector attached) from the top of the
screen to the bottom, when relocate() is called from my validate() method,
the labels will still be at the top of the screen. If I resize the object,
the the labels will fall into the correct position. So it's like the
labels are always a step behind.
How do I get the labels to always stay exactly with the connector? I tried
calling super.validate() before I call relocate() and that gives the
behavior I want, but then I get weird things happening like the labels
disappear.
Thanks a lot for your reply!!
Here is my code:
import org.eclipse.draw2d.ConnectionEndpointLocator;
import org.eclipse.draw2d.DelegatingLayout;
import org.eclipse.draw2d.Label;
import org.eclipse.draw2d.PolylineConnection;
public class ConnectorMultipleText extends PolylineConnection
private Label sourceUpperLabel,sourceLowerLabel;
private Label targetUpperLabel,targetLowerLabel;
private ConnectionEndpointLocator
sourceUpperLocator,sourceLowerLocator;
targetUpperLocator,targetLowerLocator;
private static final short
UPPER_SOURCE = 0,
LOWER_SOURCE = 1,
UPPER_TARGET = 2,
LOWER_TARGET = 3;
public ConnectorMultipleText()
super();
setLayoutManager(new DelegatingLayout());
protected ConnectionEndpointLocator createLocator(short type)
assert(type == LOWER_TARGET ||
type == LOWER_SOURCE ||
type == UPPER_TARGET ||
type == UPPER_SOURCE);
ConnectionEndpointLocator locator = null;
if(type == UPPER_TARGET || type == LOWER_TARGET)
locator = new ConnectionEndpointLocator(this,true);
else
locator = new ConnectionEndpointLocator(this,false);
locator.setUDistance(10);
if(type == LOWER_TARGET || type == LOWER_SOURCE)
locator.setVDistance(10);
else
locator.setVDistance(-10);
return locator;
public void validate()
if(sourceLowerLocator != null)
sourceLowerLocator.relocate(sourceLowerLabel);
if(sourceUpperLocator != null)
sourceUpperLocator.relocate(sourceUpperLabel);
if(targetUpperLocator != null)
targetUpperLocator.relocate(targetUpperLabel);
if(targetLowerLocator != null)
targetLowerLocator.relocate(targetLowerLabel);
super.validate();
* @return the sourceLowerLabel.
public Label getSourceLowerLabel()
return sourceLowerLabel;
* @param sourceLowerLabel
public void setSourceLowerLabel(Label sourceLowerLabel)
this.sourceLowerLabel = sourceLowerLabel;
this.add(sourceLowerLabel);
if(sourceLowerLabel != null)
this.sourceLowerLocator = createLocator(LOWER_SOURCE);
* @return the sourceUpperLabel.
public Label getSourceUpperLabel()
return sourceUpperLabel;
* @param sourceUpperLabel
public void setSourceUpperLabel(Label sourceUpperLabel)
this.sourceUpperLabel = sourceUpperLabel;
this.add(sourceUpperLabel);
if(sourceUpperLabel != null)
this.sourceUpperLocator = createLocator(UPPER_SOURCE);
* @return the targetLowerLabel.
public Label getTargetLowerLabel()
return targetLowerLabel;
* @param targetLowerLabel
public void setTargetLowerLabel(Label targetLowerLabel)
this.targetLowerLabel = targetLowerLabel;
this.add(targetLowerLabel);
if(targetLowerLabel != null)
this.targetLowerLocator = createLocator(LOWER_TARGET);
* @return the targetUpperLabel.
public Label getTargetUpperLabel()
return targetUpperLabel;
* @param targetUpperLabel
public void setTargetUpperLabel(Label targetUpperLabel)
this.targetUpperLabel = targetUpperLabel;
this.add(targetUpperLabel);
if(targetUpperLabel != null)
this.targetUpperLocator = createLocator(UPPER_TARGET);
Pratik Shah wrote:
> I don't think children were meant to be added to PolygonDecoration. Why do
> you want to add the children to the PolygonDecoration anyway? Can't you get
> the same effect by using the ConnectionEndPointLocator's setUDistance() and
> setVDistance() methods?
> "bandrews" <bandrews@nospam_bphnx.com> wrote in message
> news:cm8ukb$ovi$1@eclipse.org...
>> I now believe there is a bug here. I can add a Label to a
>> PolylineConnection just fine, but when I add it to the PolygonDecoration
>> it will not show. It should work the same. I checked out the
>> paintChildren() method, and it shows that it does have my child Label
>> attached and it's repaint() gets called. So I am not yet sure where the
>> problem lies. Can someone else confirm this is a bug, and I will log it.
>> thanks,
>> Barry
> on
>> > the screen.
>> > thanks,
>> > B
Re: Adding Label to PolylineDecoration [message #156828 is a reply to message #156821] |
Thu, 04 November 2004 11:56   |
It's difficult to post something that will actually run because it takes
so many classes, but here I have made the snippet less complex so that
hopefully I will be more clear.
So with the code below, I can draw this:
- - Help - -
- objectA ----------------- objectB -
And if I move objectA down the screen so that the connector also moves,
I get this:
Help -- objectA -
Then, if I just resize or move something just slightly (enough to cause
a repaint), then the Help label will move down where it's supposed to be.
Notice, in my validate() method I call super.validate() after the
relocate(). I also tried calling it before relocate() and that works
like I want except sometimes the label disappears.
Hopefully this is more clear?
Many thanks,
Barry
private Label sourceUpperLabel;
private ConnectionEndpointLocator sourceUpperLocator;
super();
sourceUpperLabel = new Label("Help");
sourceUpperLocator = createLocator();
protected ConnectionEndpointLocator createLocator()
ConnectionEndpointLocator locator = new
return locator;
super.validate();
Randy Hudson wrote:
> Please post a snippet which can be executed, and remove anything not
> relevant to the problem. Or, post a picture of what you are trying to do.
Re: Adding Label to PolylineDecoration [message #156874 is a reply to message #156828] |
Thu, 04 November 2004 18:58   |
Hmm, looking at your code, I can clearly see that you've not come across
this article:
http://eclipse.org/articles/Article-GEF-Draw2d/GEF-Draw2d.ht ml
When you add the labels as children of the PolylineConnection, you need to
provide the endpoint locators as constraints. Then you don't need to
overridate validate() and invoke relocate() on those endpoint locators.
"Barry Andrews" <bandrews@nospam_bphnx.com> wrote in message
news:cmdn01$7p3$1@eclipse.org...
> - - Help - -
> I get this:
> Help -- objectA -
> Many thanks,
> Barry
> super();
> return locator;
> super.validate();
do.
Re: Adding Label to PolylineDecoration [message #157009 is a reply to message #156874] |
Fri, 05 November 2004 09:45  |
Ahhh! Wonderful! Not as complicated as I was trying to make it. Thanks
for the article.
> this article:
>>- - Help - -
>>I get this:
>> Help -- objectA -
>>Many thanks,
>>Barry
>> super();
>> return locator;
>> super.validate();
> do.
Current Time: Fri Sep 19 16:13:42 EDT 2025
Powered by FUDForum. Page generated in 0.27488 seconds
