Home » Archived » Hudson » Looking forward to Hudson 3.3.0 - Java 7 and Above
Looking forward to Hudson 3.3.0 - Java 7 and Above [message #1565750] Thu, 15 January 2015 08:07 Go to next message
As we close down the 3.2.2 maintenance release we are also looking forward to what to do in 3.3.0 as the next major release. As part of this we want to communicate a key change that we are intending to make.
As of the 3.3.0 release it is planned that the Hudson Server itself will only be supported on Java 7 and above. We currently build against Java 6 and test across Java 6, 7 and 8 but in this next major version we'd like to start to really take advantage of what the newer JDKs will offer us and move on up.
This change will have several side effects in terms of what application servers versions will be able to run the Hudson WAR and of course there will be a general up-levelling of any library dependencies that we have to JDK 7 compatible versions as well.
Note that this change will not preclude you from using Hudson to build Java 6 based applications, we only discussing the version of Java that Hudson itself runs on.
If you have any concerns about this planned change please do let us know, either in this thread, the developer mailing list or of course the bi-weekly community phone-call.
Duncan
Re: Looking forward to Hudson 3.3.0 - Java 7 and Above [message #1566737 is a reply to message #1565750] Thu, 15 January 2015 20:46 Go to previous messageGo to next message
How about Java EE versions? Currently, Hudson runs on Java EE 6 application server nicely, but to run it on Java EE 7 server, the implicit CDI support of the server must be explicitly disabled, due to unsatisfied dependencies. (See https://blogs.oracle.com/theaquarium/entry/default_cdi_enablement_in_java for the default CDI enabledment in Java EE 7.)
Re: Looking forward to Hudson 3.3.0 - Java 7 and Above [message #1566824 is a reply to message #1566737] Thu, 15 January 2015 21:56 Go to previous messageGo to next message
Can you please file a bug for this.
Re: Looking forward to Hudson 3.3.0 - Java 7 and Above [message #1567193 is a reply to message #1566824] Fri, 16 January 2015 02:55 Go to previous message
Already reported: https://bugs.eclipse.org/bugs/show_bug.cgi?id=455960
Unfortunately, GlassFish 4 reports one set of unsatisfied dependencies at once. If I resolve one, another comes up.
[Updated on: Fri, 16 January 2015 03:01] by Moderator
Previous Topic:Planned Maintenance on Hudson-ci infrastructure
Next Topic:Delay loading "Configure Job"
Current Time: Sun Aug 31 15:56:20 EDT 2025
Powered by FUDForum. Page generated in 0.03698 seconds
