Using custom skin for login screen [message #1567000] |
Fri, 16 January 2015 00:24  |
I am trying to coustomize the login page and followed all the steps mentioned at stardust documentation (Creating & using custom skins -> Applying a Customizable Branding to the Login Page) -
But I am getting following exception at the tomcat console and getting no change at the login screen -
SEVERE: Servlet.service() for servlet [SkinContentServlet] in context with path [/ApprovePO] threw exception
org.eclipse.stardust.common.error.PublicException: Failed retrieving content for file '/default-skin/login.css'.: java.lang.NullPointerException
at org.eclipse.stardust.ui.client.dms.SkinContentServlet$1.invoke(SkinContentServlet.java:210)
at org.eclipse.stardust.ui.client.dms.SkinContentServlet$1.invoke(SkinContentServlet.java:98)
at org.eclipse.stardust.common.Function.call(Function.java:38)
at org.eclipse.stardust.common.Function.execute(Function.java:33)
at org.eclipse.stardust.engine.api.spring.AbstractSpringForkingServiceBean$TxIsolatedActionInvoker.isolate(AbstractSpringForkingServiceBean.java:245)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.CallingInterceptor.invoke(CallingInterceptor.java:29)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.proceed(MethodInvocationImpl.java:130)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.POJOExceptionHandler.invoke(POJOExceptionHandler.java:30)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.RuntimeExtensionsInterceptor.invoke(RuntimeExtensionsInterceptor.java:34)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.NonInteractiveSecurityContextInterceptor.invoke(NonInteractiveSecurityContextInterceptor.java:47)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.doWithDataSource(SpringSessionInterceptor.java:142)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.access$000(SpringSessionInterceptor.java:48)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor$1.doInConnection(SpringSessionInterceptor.java:87)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:342)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.invoke(SpringSessionInterceptor.java:81)
at org.eclipse.stardust.engine.api.spring.SpringConfigurationInterceptor.invoke(SpringConfigurationInterceptor.java:101)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.PropertyLayerProviderInterceptor.invoke(PropertyLayerProviderInterceptor.java:129)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor.invoke(DebugInterceptor.java:55)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor$1.doInTransaction(SpringTxInterceptor.java:66)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:131)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor.invoke(SpringTxInterceptor.java:51)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.execute(MethodInvocationImpl.java:68)
at org.eclipse.stardust.engine.core.runtime.beans.InvocationManager.invoke(InvocationManager.java:53)
at $Proxy51.isolate(Unknown Source)
at org.eclipse.stardust.engine.api.spring.AbstractSpringForkingServiceBean$2.doInTransaction(AbstractSpringForkingServiceBean.java:146)
at org.eclipse.stardust.engine.api.spring.AbstractSpringForkingServiceBean.isolate(AbstractSpringForkingServiceBean.java:135)
at org.eclipse.stardust.ui.client.dms.SkinContentServlet.doDownloadFileContent(SkinContentServlet.java:97)
at org.eclipse.stardust.vfs.impl.jcr.web.AbstractVfsContentServlet.doGet(AbstractVfsContentServlet.java:75)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.eclipse.stardust.ui.web.html5.EnhancedJarResourceFilter.doFilter(EnhancedJarResourceFilter.java:140)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:936)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1004)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.eclipse.stardust.ui.client.dms.SkinContentServlet$1.invoke(SkinContentServlet.java:164)
... 61 more
Jan 16, 2015 10:33:08 AM org.apache.catalina.core.StandardWrapperValve invoke
org.eclipse.stardust.common.error.PublicException: Failed retrieving content for file '/default-skin/login_safari.css'.: java.lang.NullPointerException
FUDForum. Page generated in 0.11130 seconds
