Home » Eclipse Projects » DSDP - Target Management » Orphaned Terminal window
Orphaned Terminal window [message #15544] Tue, 30 October 2007 05:58 Go to next message
Originally posted by: paul.mcconkey.net
I had a detached Terminal view dragged onto my secondary monitor for some
time. I then reattached it to the debug perspective. Since then, a working,
but blank, detached window keeps appearing every time I switch to the debug
perspective. This window has no title, controls or content apart from an X
close icon and it is happy to be dragged or closed.
Any idea how I can get rid of it short of a complete reinstall of Eclipse?
Paul.
Re: Orphaned Terminal window [message #15575 is a reply to message #15544] Mon, 05 November 2007 19:39 Go to previous messageGo to next message
Hi Paul,
I'd recommend you first try Window > Reset Perspective.
If that does not help: if I'm not mistaken, the file which holds
information about the position of windows, views and dialogs is
stored in your workspace:
{ws}/.metadata/.plugins/org.eclipse.ui/dialog_settings.xml
deleting that file should restore the default settings for all
views in all perspectives.
In case you can reproduce your issue, please file a bug.
Thanks!
Martin
Paul McConkey schrieb:
> Cheers,
> Paul.
Martin Oberhuber
Wind River Systems, Inc.
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Re: Orphaned Terminal window [message #15607 is a reply to message #15575] Mon, 05 November 2007 19:47 Go to previous messageGo to next message
Sorry, wrong file:
{ws}/.metadata/.plugins/org.eclipse.ui.workbench/workbench.x ml
seems to be the file holding view state and location.
Martin
Martin Oberhuber schrieb:
> Hi Paul,
> Thanks!
> Martin
>> Hi,
>> some time. I then reattached it to the debug perspective. Since then,
>> a working, but blank, detached window keeps appearing every time I
>> switch to the debug perspective. This window has no title, controls or
>> content apart from an X close icon and it is happy to be dragged or
>> closed.
>> Eclipse?
>> Cheers,
>> Paul.
Martin Oberhuber
Re: Orphaned Terminal window [message #15639 is a reply to message #15607] Tue, 06 November 2007 05:32 Go to previous messageGo to next message
"Martin Oberhuber" <martin.oberhuber@windriver.com> wrote in message
news:472FB9A9.9020002@windriver.com...
> Sorry, wrong file:
Thanks, Martin.
I found the window coordinates of the dialog using spy and a search in the
workbench.xml led me to this section in the debug perspective:
<detachedWindow height="425" width="585" x="2098" y="315">
<presentation
id=" org.eclipse.ui.internal.presentations.r33.WorkbenchPresentat ionFactory_33 ">
</presentation>
</detachedWindow>
I have not been able to reproduce this - but maybe there is some way for the
Terminal view's page content tags to be removed. If it reoccurs I will try
to figure out how to reproduce it.
Paul.
Re: Orphaned Terminal window [message #15670 is a reply to message #15639] Wed, 07 November 2007 03:18 Go to previous messageGo to next message
Hi Paul,
if this is a bug it may not be related to the Terminal at all.
Did you search Eclipse (Platform) bugzilla for things like
"detached" "empty" ?
Martin Oberhuber
Re: Orphaned Terminal window [message #15698 is a reply to message #15670] Wed, 07 November 2007 05:02 Go to previous message
That seems likely, and after an hour of trying I can't reproduce it -
although I did find a detached window drawing issue:
http://bugs.eclipse.org/208990
Good point, but no joy.
Paul.
Re: Orphaned Terminal window [message #570547 is a reply to message #15544] Mon, 05 November 2007 19:39 Go to previous message
Hi Paul,
Thanks!
Martin
> Cheers,
> Paul.
Martin Oberhuber
Re: Orphaned Terminal window [message #570558 is a reply to message #15575] Mon, 05 November 2007 19:47 Go to previous message
Sorry, wrong file:
Martin
> Hi Paul,
> Thanks!
> Martin
>> Hi,
>> closed.
>> Eclipse?
>> Cheers,
>> Paul.
Martin Oberhuber
Re: Orphaned Terminal window [message #570596 is a reply to message #15607] Tue, 06 November 2007 05:32 Go to previous message
> Sorry, wrong file:
Thanks, Martin.
<presentation
</presentation>
</detachedWindow>
Paul.
Re: Orphaned Terminal window [message #570625 is a reply to message #15639] Wed, 07 November 2007 03:18 Go to previous message
Hi Paul,
Martin Oberhuber
Re: Orphaned Terminal window [message #570674 is a reply to message #15670] Wed, 07 November 2007 05:02 Go to previous message
Paul.
Previous Topic:Orphaned Terminal window
Next Topic:Remote launching of Java code
Current Time: Sat Sep 13 17:29:44 EDT 2025
Powered by FUDForum. Page generated in 0.04433 seconds
