Home » Eclipse Projects » Eclipse Platform » Change proejct type on the fly?
Change proejct type on the fly? [message #156597] Thu, 13 November 2003 22:30 Go to next message
Originally posted by: s_s_patil.hotmail.com
Can I change the type of a project after its creation? I believe it may
have something to do with associating new plug-ins (and natures!) with the
project. Not sure how to get this done though?
Specifically - when I check out a project from a CVS repository, a simple
project gets created. In order to compile the code (it's Java), it seems
the project needs to be of "Java type". How do I now change the project
type without losing the CVS functionalities (compare with latest version,
etc)?
Thanks in advance
-- SP
Re: Change proejct type on the fly? [message #156653 is a reply to message #156597] Fri, 14 November 2003 04:29 Go to previous messageGo to next message
- Open the ".project" file of you project. You might have to switch to
the Resources perspective to do that.
- Find the "natures" section. For a plain java project it should look
like this:
<natures>
<nature>org.eclipse.jdt.core.javanature</nature>
</natures>
- To attach a java builder, check the "buildSpec" section. It should
contain:
<buildCommand>
<name>org.eclipse.jdt.core.javabuilder</name>
<arguments>
</arguments>
</buildCommand>
- You also might have to patch or even create the ".classpath" file. Its
"classpath" section should at least contain:
<classpathentry kind="con"
path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
- Depending on whether you have a "bin" directory you should have:
<classpathentry kind="output" path="bin"/>
But you should be able to resolve most of these issues during checkout.
When you checkout a project, that is not an Eclipse project, the "Check
out As..." dialog offers to "Checkout as project using the New Project
Wizard". Try that.
Hope that helps,
Chris
Re: Change proejct type on the fly? [message #156661 is a reply to message #156597] Fri, 14 November 2003 04:31 Go to previous message
"SP" <s_s_patil@hotmail.com> wrote in message
news:bp1i8d$n0c$1@eclipse.org...
Not sure if you want to do it through a UI or programaticaly. Through a UI,
it is not possible (I believe there's a feature request somewhere in
bugzilla). Programaticaly, you need to set the description of the project
(see IProject.setDescription(...)).
> etc)?
If your project in the CVS repository was checked in without a .project
file, then when you check it out, just choose 'Check Out As...' and in the
New Project wizard choose 'Java project'.
Otherwise you can manually edit the .project file and add the following in
the projectdescription:
<buildSpec>
<buildCommand>
<arguments>
</arguments>
</buildCommand>
</buildSpec>
<natures>
</natures>
Jerome
Previous Topic:[TextCellEditor] TableViewer not updated?
Next Topic:Filtering on subfolders
Current Time: Fri Nov 07 22:56:00 EST 2025
Powered by FUDForum. Page generated in 0.05933 seconds
