Home » Eclipse Projects » Oomph » How to update the bundle pool meta data?
How to update the bundle pool meta data? [message #1565438] Thu, 15 January 2015 04:25 Go to next message
at first, thanks for this nice tool. I like it very much.
Now to my problem. I want to replace the current target file mechanism with this targlet thing. And it works well for the first time. But in our company we have a huge composite p2 repository with all of our bundles and the content is changing often, especially the snapshot builds. The problem is, that several specific snapshot builds aren't longer available. I thought this is not problematic, because I use version ranges for compatibility and I thought the next best compatible bundle will be loaded.
Now the targlet mechanism want always to load the old version from the first execution, but the bundle with a specific time stamp is no more longer available and it is OK. There is now a newer one (version is compatible).
So I don't know how I could teach the tool to update the local meta data and forget the old bundle version (time stamp).
Daniel
Re: How to update the bundle pool meta data? [message #1567458 is a reply to message #1565438] Fri, 16 January 2015 06:17 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
</head>
Hi Daniel,<br>
<br>
Comments below...<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a><br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
<div class="moz-cite-prefix">Am 15.01.2015 um 15:53 schrieb Daniel
Brenner:<br>
</div>
<blockquote cite="mid:m98k9v$ls$1@xxxxxxxxe.org" type="cite">Hi,
<br>
<br>
<br>
</blockquote>
Thank you ;-)<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
The TargletTask should behave just like you expect. If it doesn't I
see two possible reasons:<br>
<br>
1) Your version ranges are too narrow. It's unlikely, but how are
they specified?<br>
<br>
2) Oomph's offline mode is enabled. Make sure that the offline cache
is not used:<br>
<img src="https://www.eclipse.org/forums/index.php?t=getfile&amp;id=20465" alt=""><br>
<br>
A third reason could be that p2 itself has cached the repo contents
in memory. Does the problem persist after a restart of the IDE?<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
  • Attachment: ifgafcgi.png
    (Size: 29.43KB, Downloaded 118 times)
Re: How to update the bundle pool meta data? [message #1567491 is a reply to message #1567458] Fri, 16 January 2015 06:43 Go to previous messageGo to next message
One more thought:
Are you sure that the timestamps of your composite repos are properly updated when new content is available?
Cheers
/Eike
Re: How to update the bundle pool meta data? [message #1572594 is a reply to message #1567491] Mon, 19 January 2015 03:13 Go to previous message
Hi Eike,
thanks for your help.
I solved my problem with the following "work a round", whereas I don't know if it's a good solution.
I added the problematic P2 repository to the "P2 Director" in the hope that the meta data will be updated. And it works for my use case.
If I have the right understanding of Oomph, every bundle is stored in one central bundle pool and the P2 Director takes care of it. Seems to be so.
Maybe it's not the best solution...
Previous Topic:Create project setup task
Next Topic:PDE Target provisioning taking much longer than before
Current Time: Fri Oct 24 05:53:40 EDT 2025
Powered by FUDForum. Page generated in 0.05191 seconds
