Home » Language IDEs » ServerTools (WTP) » Update site for WTP 1.0 is now declared available
Update site for WTP 1.0 is now declared available [message #155937] Wed, 11 January 2006 13:59 Go to next message
While we've found a couple of bugs and issues with updating WTP,
our official update site for WTP 1.0 is now available at
http://download.eclipse.org/webtools/updates/
Before pointing your Update Manager to the update site URL,
be sure to point your webbrowser to it first, and read the
section on "known issues". We've discovered a couple of glitches
in the system and workarounds are documented there, at
http://download.eclipse.org/webtools/updates/index.html
As always, let us know how it goes (and/or open bugs/feature requests th=
at
reflect your experiences).
Re: Update site for WTP 1.0 is now declared available [message #156245 is a reply to message #155937] Fri, 13 January 2006 00:05 Go to previous messageGo to next message
Originally posted by: nospam.for.me
I started from a new 3.1.1 installation and followed the installation
instructions.
After several attempts the installation is still failing with the message:
"Update operation has failed"
While selecting entries to install I am also getting the message:
"java.lang.NullPointerException"
>"David Williams" <david_williams@us.ibm.com> wrote in message
>news:op.s279pxqeac05ss@dmw2t23.raleigh.ibm.com...
>As always, let us know how it goes (and/or open bugs/feature requests that
>Thanks
Re: Update site for WTP 1.0 is now declared available [message #156410 is a reply to message #156245] Fri, 13 January 2006 01:57 Go to previous messageGo to next message
> instructions.
> After several attempts the installation is still failing with the mess=
Hmmm, Well, I just now tested again on my system for a sanity check and =
it worked fine,
but I am on East Coast of US, and was not using a mirror site.
Were you using a mirror site? If so, if its not obvious,
be sure to try several mirror sites and/or resort to the "canada/ottawa"=
(home) site.
If you still get the problem, I'd suggest opening a bugzilla with attach=
ments of your
..metadata/.log file (that should show the history of where the null poin=
ter exception
is occuring). It would also be good to attach your "configuration' from =
the Eclipse Help About
Dialog. Also, you might be clear on exactly what steps you got through .=
.. I assume it asked you about licenses?
And then locations? Did you specify a different location directory or no=
t? Did it then work for a while, and eventually ask you to "install now"=
, or did it never get to that part?
Re: Update site for WTP 1.0 is now declared available [message #156413 is a reply to message #156410] Fri, 13 January 2006 04:02 Go to previous messageGo to next message
*** Date: Fri Jan 13 00:51:02 PST 2006*** Platform Details:*** System
properties:awt.toolkit=sun.awt.windows.WToolkiteclipse.appli cation=org.eclipse.ui.ide.workbencheclipse.buildId=M20050929 -0840eclipse.commands=-oswin32-wswin32-archx86-launcherC:\Pr ogram
Files\eclipse\eclipse.exe-nameEclipse-showsplash600-exitdata e18_58-vmC:\WINDOWS\system32\javaw.exeeclipse.product=org.ec lipse.sdk.ideeclipse.startTime=1137142214500eclipse.vm=C:\WI NDOWS\system32\javaw.exeeclipse.vmargs=-Xms40m-Xmx256m-jarC: \Program
Files\eclipse\startup.jareof=eoffile.encoding=Cp1252file.enc oding.pkg=sun.iofile.separator=\java.awt.graphicsenv=sun.awt .Win32GraphicsEnvironmentjava.awt.printerjob=sun.awt.windows .WPrinterJobjava.class.path=C:\Program
Files\eclipse\startup.jarjava.class.version=49.0java.endorse d.dirs=C:\Program
Files\Java\jre1.5.0_06\lib\endorsedjava.ext.dirs=C:\Program
Files\Java\jre1.5.0_06\lib\extjava.home=C:\Program
Files\Java\jre1.5.0_06java.io.tmpdir=C:\DOCUME~1\Brad\LOCALS ~1\Temp\java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\s ystem32;C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS \System32\Wbem;C:\Program
Files\Real\Helix Producer Basic;C:\Program
Files\Perforce;c:\mysql\bin;"C:\Program Files\Symantec\Norton Ghost
2003\";C:\Program Files\Microsoft Visual
Studio\Common\Tools\WinNT;C:\Program Files\Microsoft Visual
Studio\Common\MSDev98\Bin;C:\Program Files\Microsoft Visual
Studio\Common\Tools;C:\Program Files\Microsoft Visual
Studio\VC98\bin;c:\cygwin\bin;c:\utilityjava.runtime.name=Ja va(TM) 2 Runtime
Environment, Standard
Editionjava.runtime.version=1.5.0_06-b05java.specification.n ame=Java
Platform API Specificationjava.specification.vendor=Sun Microsystems
Inc.java.specification.version=1.5java.vendor=Sun Microsystems
Inc.java.vendor.url= http://java.sun.com/java.vendor.url.bug=http://java.sun.com/ cgi-bin/bugreport.cgijava.version=1.5.0_06java.vm.info=mixed
mode, sharingjava.vm.name=Java HotSpot(TM) Client
VMjava.vm.specification.name=Java Virtual Machine
Specificationjava.vm.specification.vendor=Sun Microsystems
Inc.java.vm.specification.version=1.0java.vm.vendor=Sun Microsystems
Inc.java.vm.version=1.5.0_06-b05line.separator=org.osgi.fram ework.bootdelegation=*org.osgi.framework.executionenvironmen t=J2SE-1.5org.osgi.framework.language=enorg.osgi.framework.o s.name=WindowsXPorg.osgi.framework.os.version=5.1org.osgi.fr amework.processor=x86org.osgi.framework.system.packages=java x.accessibility,javax.activity,javax.crypto,javax.crypto.int erfaces,javax.crypto.spec,javax.imageio,javax.imageio.event, javax.imageio.metadata,javax.imageio.plugins.bmp,javax.image io.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax .management,javax.management.loading,javax.management.modelm bean,javax.management.monitor,javax.management.openmbean,jav ax.management.relation,javax.management.remote,javax.managem ent.remote.rmi,javax.management.timer,javax.naming,javax.nam ing.directory,javax.naming.event,javax.naming.ldap,javax.nam ing.spi,javax.net,javax.net.ssl,javax.print,javax.print.attr ibute,javax.print.attribute.standard,javax.print.event,javax .rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.security.auth,javax .security.auth.callback,javax.security.auth.kerberos,javax.s ecurity.auth.login,javax.security.auth.spi,javax.security.au th.x500,javax.security.cert,javax.security.sasl,javax.sound. midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sa mpled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial ,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.s wing.colorchooser,javax.swing.event,javax.swing.filechooser, javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.met al,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing .table,javax.swing.text,javax.swing.text.html,javax.swing.te xt.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.s wing.undo,javax.transaction,javax.transaction.xa,javax.xml,j avax.xml.datatype,javax.xml.namespace,javax.xml.parsers,java x.xml.transform,javax.xml.transform.dom,javax.xml.transform. sax,javax.xml.transform.stream,javax.xml.validation,javax.xm l.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.om g.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.COR BA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodeP ackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtP ackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynami c,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage ,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.Co decFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging ,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORB InitInfoPackage,org.omg.PortableServer,org.omg.PortableServe r.CurrentPackage,org.omg.PortableServer.POAManagerPackage,or g.omg.PortableServer.POAPackage,org.omg.PortableServer.porta ble,org.omg.PortableServer.ServantLocatorPackage,org.omg.Sen dingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bo otstrap,org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xm l.sax.ext,org.xml.sax.helpersorg.osgi.framework.vendor=Eclip seorg.osgi.framework.version=1.3.0org.osgi.supports.framewor k.extension=trueos.arch=x86os.name=Windows
XPos.version=5.1osgi.arch=x86osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:startosgi.bundlestore=c:\Program
Files\eclipse\configuration\org.eclipse.osgi\bundlesosgi.con figuration.area=file:/c:/Program
Files/eclipse/configuration/osgi.framework=file:/c:/Program
Files/eclipse/plugins/org.eclipse.osgi_3.1.1.jarosgi.framewo rk.beginningstartlevel=1osgi.framework.shape=jarosgi.framewo rk.version=3.1.1osgi.install.area=file:/c:/Program
Files/eclipse/osgi.instance.area=file:/C:/work/eclipse/osgi. instance.area.default=file:/C:/Documents
and
Settings/Brad/workspace/osgi.logfile=C:\work\eclipse\.metada ta\.logosgi.manifest.cache=c:\Program
Files\eclipse\configuration\org.eclipse.osgi\manifestsosgi.n l=en_CAosgi.os=win32osgi.splashLocation=c:\Program
Files\eclipse\plugins\org.eclipse.platform_3.1.1\splash.bmpo sgi.splashPath=platform:/base/plugins/org.eclipse.platformos gi.syspath=c:\Program
Files\eclipse\pluginsosgi.ws=win32path.separator=;sun.arch.d ata.model=32sun.boot.class.path=C:\Program
Files\Java\jre1.5.0_06\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_06\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_06\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_06\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_06\classessun.boot.library.path=C:\Progr am
Files\Java\jre1.5.0_06\binsun.cpu.endian=littlesun.cpu.isali st=pentium_pro+mmx
pentium_pro pentium+mmx pentium i486 i386
i86sun.desktop=windowssun.io.unicode.encoding=UnicodeLittles un.jnu.encoding=Cp1252sun.management.compiler=HotSpot
Client Compilersun.os.patch.level=Service Pack
2user.country=CAuser.dir=C:\Program Files\eclipseuser.home=C:\Documents and
Settings\Braduser.language=enuser.name=Braduser.timezone=Ame rica/Los_Angelesuser.variant=***
Features:org.eclipse.emf.doc (2.1.1) "Eclipse Modeling Framework (EMF)
Programmers Guide"org.eclipse.emf.ecore.sdo.doc (2.1.1) "EMF Service Data
Objects (SDO) Programmers Guide"org.eclipse.emf.ecore.sdo.source (2.1.1)
"EMF Service Data Objects (SDO) Source"org.eclipse.jdt (3.1.1) "Eclipse Java
Development Tools"org.eclipse.jdt.source (3.1.1) "Eclipse Java Development
Tools SDK"org.eclipse.pde (3.1.1) "Eclipse Plug-in Development
Environment"org.eclipse.pde.source (3.1.1) "Eclipse Plug-in Development
Environment Developer Resources"org.eclipse.platform (3.1.1) "Eclipse
Platform"org.eclipse.platform.source (3.1.1) "Eclipse Platform Plug-in
Developer Resources"org.eclipse.rcp (3.1.1) "Eclipse
RCP"org.eclipse.rcp.source (3.1.1) "Eclipse RCP Plug-in Developer
Resources"org.eclipse.sdk (3.1.1) "Eclipse Project SDK"*** Plug-in
Registry:org.apache.ant (1.6.5) "Apache Ant" [Resolved]org.apache.lucene
(1.4.3) "Apache Lucene" [Resolved]org.eclipse.ant.core (3.1.1) "Ant Build
Tool Core" [Resolved]org.eclipse.ant.ui (3.1.1) "Ant UI"
[Resolved]org.eclipse.compare (3.1.1) "Compare Support"
[Resolved]org.eclipse.core.boot (3.1.0) "Core Boot"
[Resolved]org.eclipse.core.commands (3.1.0) "Commands"
[Active]org.eclipse.core.expressions (3.1.0) "Expression Language"
[Active]org.eclipse.core.filebuffers (3.1.0) "File Buffers"
[Active]org.eclipse.core.resources (3.1.0) "Core Resource Management"
[Active]org.eclipse.core.resources.compatibility (3.1.0) "Core Resource
Management Compatibility Fragment"
[Resolved]org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management
Win32 Fragment" [Resolved]org.eclipse.core.runtime (3.1.1) "Core Runtime"
[Active]org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]org.eclipse.core.variables (3.1.0) "Core Variables"
[Resolved]org.eclipse.debug.core (3.1.0) "Debug Core"
[Active]org.eclipse.debug.ui (3.1.1) "Debug UI" [Active]org.eclipse.emf.doc
(2.1.1) "Eclipse Modeling Framework (EMF) Programmers Guide"
[Resolved]org.eclipse.emf.ecore.sdo.doc (2.1.1) "EMF Service Data Objects
(SDO) Programmers Guide" [Resolved]org.eclipse.emf.ecore.sdo.source (2.1.1)
"EMF Service Data Objects (SDO) Source" [Resolved]org.eclipse.help (3.1.0)
"Help System Core" [Active]org.eclipse.help.appserver (3.1.0) "Help
Application Server" [Resolved]org.eclipse.help.base (3.1.0) "Help System
Base" [Resolved]org.eclipse.help.ui (3.1.1) "Help System UI"
[Resolved]org.eclipse.help.webapp (3.1.0) "Help System Webapp"
[Resolved]org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools"
[Resolved]org.eclipse.jdt.core (3.1.1) "Java Development Tools Core"
[Active]org.eclipse.jdt.debug (3.1.1) "JDI Debug Model"
[Resolved]org.eclipse.jdt.debug.ui (3.1.1) "JDI Debug UI"
[Resolved]org.eclipse.jdt.doc.isv (3.1.1) "Eclipse JDT Plug-in Developer
Guide" [Resolved]org.eclipse.jdt.doc.user (3.1.1) "Eclipse Java Development
User Guide" [Resolved]org.eclipse.jdt.junit (3.1.1) "Java Development Tools
JUnit support" [Resolved]org.eclipse.jdt.junit.runtime (3.1.0) "Java
Development Tools JUnit runtime support" [Resolved]org.eclipse.jdt.launching
(3.1.0) "Java Development Tools Launching Support"
[Resolved]org.eclipse.jdt.source (3.1.1) "Eclipse Java Development Tools
SDK" [Resolved]org.eclipse.jdt.ui (3.1.1) "Java Development Tools UI"
[Active]org.eclipse.jface (3.1.1) "JFace" [Active]org.eclipse.jface.text
(3.1.1) "JFace Text" [Active]org.eclipse.ltk.core.refactoring (3.1.0)
"Refactoring Core" [Resolved]org.eclipse.ltk.ui.refactoring (3.1.1)
"Refactoring UI" [Resolved]org.eclipse.osgi.services (3.1.1) "OSGi Release 3
Services" [Resolved]org.eclipse.osgi.util (3.1.1) "OSGi R3 Utility Classes"
[Resolved]org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
[Resolved]org.eclipse.pde.build (3.1.0) "Plug-in Development Environment
Build Support" [Resolved]org.eclipse.pde.core (3.1.1) "Plug-in Development
Core" [Resolved]org.eclipse.pde.doc.user (3.1.1) "Eclipse Plug-in
Development User Guide" [Resolved]org.eclipse.pde.junit.runtime (3.1.0) "PDE
JUnit Plug-in Test" [Resolved]org.eclipse.pde.runtime (3.1.1) "Plug-in
Development Environment Runtime" [Resolved]org.eclipse.pde.source (3.1.1)
"Eclipse Plug-in Development Environment Developer Resources"
[Resolved]org.eclipse.pde.ui (3.1.1) "Plug-in Development UI"
[Resolved]org.eclipse.platform (3.1.1) "Eclipse Platform"
[Resolved]org.eclipse.platform.doc.isv (3.1.1) "Eclipse Platform Plug-in
Developer Guide" [Resolved]org.eclipse.platform.doc.user (3.1.1) "Eclipse
Workbench User Guide" [Resolved]org.eclipse.platform.source (3.1.1) "Eclipse
Platform Plug-in Developer Resources"
[Resolved]org.eclipse.platform.source.win32.win32.x86 (3.1.1) "Eclipse
Platform Plug-in Developer Resources" [Resolved]org.eclipse.rcp (3.1.0)
"Eclipse RCP" [Resolved]org.eclipse.rcp.source (3.1.1) "Eclipse RCP Plug-in
Developer Resources" [Resolved]org.eclipse.rcp.source.win32.win32.x86
(3.1.1) "Eclipse RCP Plug-in Developer Resources" [Resolved]org.eclipse.sdk
(3.1.1) "Eclipse Project SDK" [Resolved]org.eclipse.search (3.1.1) "Search
Support" [Resolved]org.eclipse.swt (3.1.0) "Standard Widget Toolkit"
[Resolved]org.eclipse.swt.win32.win32.x86 (3.1.1) "Standard Widget Toolkit
for Windows" [Resolved]org.eclipse.team.core (3.1.1) "Team Support Core"
[Active]org.eclipse.team.cvs.core (3.1.1) "CVS Team Provider Core"
[Resolved]org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core"
[Resolved]org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2"
[Resolved]org.eclipse.team.cvs.ui (3.1.1) "CVS Team Provider UI"
[Resolved]org.eclipse.team.ui (3.1.1) "Team Support UI"
[Resolved]org.eclipse.text (3.1.1) "Text" [Active]org.eclipse.tomcat
(4.1.30.1) "Tomcat Wrapper" [Resolved]org.eclipse.ui (3.1.1) "Eclipse UI"
[Active]org.eclipse.ui.browser (3.1.1) "Browser Support"
[Resolved]org.eclipse.ui.cheatsheets (3.1.1) "Cheat Sheets"
[Resolved]org.eclipse.ui.console (3.1.0) "Console"
[Resolved]org.eclipse.ui.editors (3.1.1) "Default Text Editor"
[Active]org.eclipse.ui.externaltools (3.1.1) "External Tools"
[Active]org.eclipse.ui.forms (3.1.0) "Eclipse Forms"
[Active]org.eclipse.ui.ide (3.1.1) "Eclipse IDE UI"
[Active]org.eclipse.ui.intro (3.1.1) "Welcome Framework"
[Active]org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]org.eclipse.ui.views (3.1.1) "Views" [Active]org.eclipse.ui.win32
(3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]org.eclipse.ui.workbench
(3.1.1) "Workbench" [Active]org.eclipse.ui.workbench.compatibility (3.1.0)
"Workbench Compatibility" [Resolved]org.eclipse.ui.workbench.texteditor
(3.1.1) "Text Editor Framework" [Active]org.eclipse.update.configurator
(3.1.0) "Install/Update Configurator" [Active]org.eclipse.update.core
(3.1.1) "Install/Update Core" [Active]org.eclipse.update.core.win32 (3.1.0)
"Install/Update Core for Windows" [Resolved]org.eclipse.update.scheduler
(3.1.0) "Automatic Updates Scheduler" [Active]org.eclipse.update.ui (3.1.1)
"Install/Update UI" [Active]org.junit (3.8.1) "JUnit Testing Framework"
[Resolved]system.bundle (3.1.1) "OSGi System Bundle" [Active]*** User
Preferences:#Fri Jan 13 00:51:02 PST
2006/instance/org.eclipse.help.ui/browser.h=768/instance/org .eclipse.jdt.ui/org.eclipse.jface.textfont=1|Courier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier
New;/instance/org.eclipse.ui/showIntro=false/instance/org.ec lipse.jdt.ui/org.eclipse.jdt.ui.formatterprofiles.version=8/ instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDOW =false@org.eclipse.ui =3.1.1/instance/org.eclipse.help.ui/browser.maximized=false\ !/=/instance/org.eclipse.ui.ide/platformState=97/configurati on/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=false/ instance/org.eclipse.core.resources/version=1/instance/org.e clipse.ui.ide/tipsAndTricks=true/instance/org.eclipse.jdt.ui /org.eclipse.jdt.ui.editor.tab.width=@org.eclipse.help.ui=3.1.1@org.eclipse.core.resources =3.1.0/instance/org.eclipse.help.ui/browser.y=110/instance/o rg.eclipse.jdt.ui/useQuickDiffPrefPage=true/instance/org.ecl ipse.help.ui/browser.x=110/instance/org.eclipse.help.ui/brow ser.w=1024@org.eclipse.ui.ide=3.1.1@org.eclipse.jdt.ui =3.1.1/instance/org.eclipse.jdt.ui/tabWidthPropagated=true/c onfiguration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=2 /configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5/co nfiguration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\work\\ eclipse/instance/org.eclipse.jdt.ui/fontPropagated=true/inst ance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true/instance /org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1 /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true/instance/org.eclipse.ui.ide/quickStart=tr uefile_export_version=3.0@org.eclipse.ui.editors=3.1.1***
Current Install Configuration:Install configuration: Last changed on
12-Jan-2006 Location: file:/c:/Program
Files/eclipse/configuration/org.eclipse.update/platform.xml Configured
sites: platform:/base/ Configured features: ID: org.eclipse.platform,
Version: 3.1.1 ID: org.eclipse.rcp, Version: 3.1.0 ID:
org.eclipse.platform.source, Version: 3.1.1 ID: org.eclipse.jdt, Version:
3.1.0 ID: org.eclipse.emf.ecore.sdo.doc, Version: 2.1.1 ID:
org.eclipse.jdt.source, Version: 3.1.1 ID: org.eclipse.pde, Version: 3.1.0
ID: org.eclipse.emf.ecore.sdo.source, Version: 2.1.1 ID:
org.eclipse.emf.doc, Version: 2.1.1 ID: org.eclipse.sdk, Version: 3.1.1
ID: org.eclipse.pde.source, Version: 3.1.1 ID: org.eclipse.rcp.source,
Version: 3.1.1 Configured plug-ins: file:/c:/Program
Files/eclipse/plugins/org.apache.ant_1.6.5/ file:/c:/Program
Files/eclipse/plugins/org.apache.lucene_1.4.3/ file:/c:/Program
Files/eclipse/plugins/org.eclipse.ant.core_3.1.1.jar file:/c:/Program
Files/eclipse/plugins/org.eclipse.ant.ui_3.1.1.jar file:/c:/Program
Files/eclipse/plugins/org.eclipse.compare_3.1.1.jar file:/c:/Program
Files/eclipse/plugins/org.eclipse.core.boot_3.1.0.jar file:/c:/Program
Files/eclipse/plugins/org.eclipse.core.commands_3.1.0.jar file:/c:/Program
Files/eclipse/plugins/org.eclipse.core.expressions_3.1.0.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.core.filebuffers_3.1.0.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.core.resources.compatibili ty_3.1.0.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.core.resources.win32_3.1.0 .jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.core.resources_3.1.0.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.core.runtime.compatibility _3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.core.runtime_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.core.variables_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.debug.core_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.debug.ui_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.emf.doc_2.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.emf.ecore.sdo.doc_2.1.1/
file:/c:/Program
Files/eclipse/plugins/org.eclipse.emf.ecore.sdo.source_2.1.1 /
file:/c:/Program Files/eclipse/plugins/org.eclipse.help.appserver_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.help.base_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.help.ui_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.help.webapp_3.1.0/
file:/c:/Program Files/eclipse/plugins/org.eclipse.help_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt.core_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt.debug.ui_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt.debug_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt.doc.isv_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt.doc.user_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt.junit.runtime_3.1.0/
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt.junit_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt.launching_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt.source_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt.ui_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.jdt_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.jface.text_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.jface_3.1.1.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.1.0 .jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.1.1.j ar
file:/c:/Program Files/eclipse/plugins/org.eclipse.osgi.services_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.osgi.util_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.osgi_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.pde.build_3.1.0/
file:/c:/Program Files/eclipse/plugins/org.eclipse.pde.core_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.pde.doc.user_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.pde.junit.runtime_3.1.0/
file:/c:/Program Files/eclipse/plugins/org.eclipse.pde.runtime_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.pde.source_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.pde.ui_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.pde_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.platform.doc.isv_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.platform.doc.user_3.1.1/
file:/c:/Program
Files/eclipse/plugins/org.eclipse.platform.source.win32.win3 2.x86_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.platform.source_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.platform_3.1.1/
file:/c:/Program
Files/eclipse/plugins/org.eclipse.rcp.source.win32.win32.x86 _3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.rcp.source_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.rcp_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.sdk_3.1.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.search_3.1.1.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.swt.win32.win32.x86_3.1.1. jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.swt_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.team.core_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.team.cvs.core_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.1.0/
file:/c:/Program Files/eclipse/plugins/org.eclipse.team.cvs.ssh_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.team.cvs.ui_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.team.ui_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.text_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.tomcat_4.1.30.1/
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui.browser_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui.cheatsheets_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui.console_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui.editors_3.1.1.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.ui.externaltools_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui.forms_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui.ide_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui.intro_3.1.1.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.ui.presentations.r21_3.1.0 .jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui.views_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui.win32_3.1.0.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.ui.workbench.compatibility _3.1.0/
file:/c:/Program
Files/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3. 1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui.workbench_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.ui_3.1.1.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.update.configurator_3.1.0. jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.update.core.win32_3.1.0.ja r
file:/c:/Program Files/eclipse/plugins/org.eclipse.update.core_3.1.1.jar
file:/c:/Program
Files/eclipse/plugins/org.eclipse.update.scheduler_3.1.0.jar
file:/c:/Program Files/eclipse/plugins/org.eclipse.update.ui_3.1.1.jar
file:/c:/Program Files/eclipse/plugins/org.junit_3.8.1/!ENTRY
org.eclipse.update.ui 4 0 2006-01-11 21:21:07.734
!MESSAGE java.lang.NullPointerException
!STACK 0
at
org.eclipse.update.internal.ui.wizards.ReviewPage$TreeConten tProvider.getParent(ReviewPage.java:172)
at
org.eclipse.update.internal.ui.wizards.ReviewPage.getSite(Re viewPage.java:1410)
at
org.eclipse.update.internal.ui.wizards.ReviewPage.access$28( ReviewPage.java:1407)
at
org.eclipse.update.internal.ui.wizards.ReviewPage$13.run(Rev iewPage.java:824)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)I
have tried several mirror sites including the home site.
Yes, it asked me about licenses, and I installed in the default location.
It never gets to the "install now". It usually
says "Update operation has failed", and a few times I get a null pointer
exception.
>news:op.s3a1lzbjac05ss@dmw2t23.raleigh.ibm.com...
>> instructions.
>> message:
>Hmmm, Well, I just now tested again on my system for a sanity check and it
>worked fine,
>(home) site.
>attachments of your
>.metadata/.log file (that should show the history of where the null pointer
>exception
>is occuring). It would also be good to attach your "configuration' from the
>Eclipse Help About
>Dialog. Also, you might be clear on exactly what steps you got through .. I
>And then locations? Did you specify a different location directory or not?
>Did it then work for a while, and eventually ask you >to "install now", or
Re: Update site for WTP 1.0 is now declared available [message #156459 is a reply to message #156413] Fri, 13 January 2006 20:06 Go to previous messageGo to next message
You should open bugs for issues such as this (with all these big lists o=
f data and logs).
See https://bugs.eclipse.org/bugs/
I queried in Eclipse/Platform/update categories and looks like several s=
imilar ones open,
but none quite the same.
I will continue to investigate and reproduce, but think the bug report w=
ould be most helpful.
Re: Update site for WTP 1.0 is now declared available [message #156534 is a reply to message #156459] Sat, 14 January 2006 14:40 Go to previous messageGo to next message
What I am seeing is Bug 79212. (Plus some more problems.)
I have tried the identical operations on another PC and it worked fine.
The only differences I can think of between these PC's are:
Works:
Windows XP Home
Microsoft JVM not installed
Does not work:
Windows XP Professional
Microsoft JVM installed.
Does Eclipse work with the Microsoft JVM?
If both the Microsoft JVM and the Sun JVM are installed on a PC, how does
Eclipse
decided which JVM to use?
>news:op.s3cf1uk7ac05ss@dmw2t23.raleigh.ibm.com...
>You should open bugs for issues such as this (with all these big lists of
>data and logs).
>similar ones open,
>would be most helpful.
Re: Update site for WTP 1.0 is now declared available [message #156539 is a reply to message #156534] Sat, 14 January 2006 17:33 Go to previous messageGo to next message
On Sat, 14 Jan 2006 14:40:48 -0500, None <nospam@for.me> wrote:
I'm glad you have seen at least one success!!
(And am glad to have your help debugging the problem case,
but still suggest you open a bug, and we can discuss and document
issues there.
But, in the meantime, more on the mysteries inlined below ...
Maybe, but others bugs, such as bug 99529 appear more similar
in the NullPointerException during
ReviewPage$TreeContentProvider.getParent
method ... which I think was in yours.
I'm actually not sure .... does anyone use the microsoft vm? :)
But ... see below ....
>If both the Microsoft JVM and the Sun JVM are installed on a PC, how do=
es
> Eclipse
..... But, your's is using the java VM. I could see it in the properties =
you attached in previous post:
java.runtime.version=3D1.5.0_06-b05
To answer your question more generally though, if you use the defaults f=
or launching "eclipse.exe",
then it will use the same VM your operating system would find if you jus=
t typed "java" from a command line.
(I'm not actually sure of algorithm of how 'java.exe' is found ... some =
combination of path and Java_home?
And easy way to see in advance what would be used by default is to type
java -version
Re: Update site for WTP 1.0 is now declared available [message #156915 is a reply to message #155937] Tue, 17 January 2006 08:00 Go to previous messageGo to next message
Originally posted by: user.domain.invalid
Just wondering why this isn't integrated in the main eclipse download
site? Is the plan going forward that users will need to add an
additional update site to their settings to get WTP?
> Thank
> s
Re: Update site for WTP 1.0 is now declared available [message #157040 is a reply to message #156915] Tue, 17 January 2006 17:12 Go to previous messageGo to next message
Yes, for the immediate future. There is some work to be done for the "mi=
d year"
simultaneious release of many eclipse projects ... but my guess is it wi=
ll be some
combination of a "central" eclipse site, but each project could still ha=
ve their own more
specialized ones.
The reason for not integrated with main eclipse site, right now, as we d=
id with 0.7, is
specifically because I wanted to give it a try. Its the first time anyon=
e has had a
non-central site, which still pre-reqs other proejects.
So ... any and all comments, are appreciated.
Re: Update site for WTP 1.0 is now declared available [message #157141 is a reply to message #155937] Wed, 18 January 2006 10:52 Go to previous messageGo to next message
Originally posted by: caclark.etechsolutions.net
David Williams said the following on 1/11/2006 12:59 PM:
> Thanks
Hey David, does the update site pick up the Maintenance releases? I see
another update posted yesterday.
Cary
Re: Update site for WTP 1.0 is now declared available [message #157170 is a reply to message #157141] Wed, 18 January 2006 12:37 Go to previous messageGo to next message
On Wed, 18 Jan 2006 10:52:46 -0500, Cary <caclark@etechsolutions.net> wr=
ote:
> Hey David, does the update site pick up the Maintenance releases? I s=
ee
Of WTP? no, not yet (bug on our part), but will soon in future.
There wasn't any updates posted yesterday that I know of.
.... so if you saw the wpt update change, let me know.
Re: Update site for WTP 1.0 is now declared available [message #157186 is a reply to message #157170] Wed, 18 January 2006 17:18 Go to previous message
David Williams said the following on 1/18/2006 11:37 AM:
Oops, yes, WTP's update site. I should clarify the "update posted
yesterday." I saw another maintenance drop on
http://download.eclipse.org/webtools/downloads/
Previous Topic:JVM 1.4 vs 1.5?
Next Topic:moving a Servlet
Current Time: Fri May 09 04:57:56 EDT 2025
Powered by FUDForum. Page generated in 0.09708 seconds
