Home » Modeling » UML2 » Property#setDefaultValue of EnumerationLiteral
Property#setDefaultValue of EnumerationLiteral [message #1563544] Wed, 14 January 2015 03:59 Go to next message
I'm trying to set a Property defaultValue to an EnumerationLiteral. However, after the following code has been executed, the enum literal specification value is null, and the default value shows a 0.
Here is xtend code snippet:
val EnumerationLiteral A_LITERAL = // lookup of enumeration literal
val Property p = // lookup of class property (which has a Enumeration as type)
// The following line calls void org.eclipse.uml2.uml.Property.setDefaultValue(ValueSpecification value)
p.defaultValue = A_LITERAL.specification
What is wrong? How do I correctly assign an enumeration literal as a default value?
I'm using an old version of UML2 api (Version: 3.1.2.v201010261927) on IBM RSA 8.0.4.
Thanks a lot!
/Andreas
Re: Property#setDefaultValue of EnumerationLiteral [message #1563991 is a reply to message #1563544] Wed, 14 January 2015 09:35 Go to previous messageGo to next message
Hi, Andreas,
Try this:
-------- 8< --------
p.createDefaultValue(null, A_LITERAL.enumeration,
UMLPackage.Literals.INSTANCE_VALUE) as InstanceValue => [
instance = A_LITERAL
-------- >8 --------
A value of enumeration type is represented by an InstanceValue, because
EnumerationLiterals are InstanceSpecifications of their Enumeration
types.
HTH,
Christian
On 2015-01-14 08:59:23 +0000, Andreas Jakobik said:
> default value?
> IBM RSA 8.0.4.
> Thanks a lot!
> /Andreas
Re: Property#setDefaultValue of EnumerationLiteral [message #1564127 is a reply to message #1563991] Wed, 14 January 2015 11:17 Go to previous message
Great, that works fine. Here is an excerpt from running code:
                              (te as Property).createDefaultValue(null, null,
				UMLPackage$Literals::INSTANCE_VALUE) as InstanceValue => [
 					instance = NOSTATUS_LITERAL
(I set type parameter to null, in order to get exact same emx encoding as if done by MetaModelAgent GUI.)
Thank you very much for the quick reply!
MVH,
Andreas
Previous Topic:Rich Text Editor for SysML Comments
Next Topic:Stereotype owning two specialization
Current Time: Sun Jul 20 21:23:13 EDT 2025
Powered by FUDForum. Page generated in 0.25659 seconds
