Home » Language IDEs » C / C++ IDE (CDT) » Linker problem: undefined reference, trying to use a function defined in a .dll
Linker problem: undefined reference, trying to use a function defined in a .dll [message #155984] |
Mon, 10 October 2005 10:33  |
Originally posted by: corno.alum.mit.edu
I'm starting with C++ again after a hiatus of 8 years. I'm running Eclipse
+ CDT + cygwin on Windows XP. I have created a DLL containing,
appropriately, a class called Hello which defines a public sayHello
function.
void sayHello()
cout << "Hello World" << endl;
This DLL is called HelloLib.dll and resides in P:/eclipse/HelloLib/Debug.
I then try to use Hello::sayHello() in another project, like so:
int main (int argc, char** argv)
Hello hello;
hello.sayHello();
return 0;
This will compile, but it will not link. The errors I get are as follows:
Building target: Sleepycat.exe
Invoking: GCC C++ Linker
g++ -LP:/eclipse/HelloLib/Debug -oSleepycat.exe ./main.o -lHelloLib
/main.o: In function `main':
/cygdrive/p/eclipse/Sleepycat/Debug/../main.cpp:10: undefined reference to
`Hello::sayHello()'
collect2: ld returned 1 exit status
make: *** [Sleepycat.exe] Error 1
What am I missing here? I searched for all occurrences of "undefined
reference" in the newsgroup archive, but was unable to find anything
specific to using DLLs (do these work differently to .so files on Unix?)
Many thanks,
Petra
Re: Linker problem: undefined reference, trying to use a function defined in a .dll [message #155992 is a reply to message #155984] |
Tue, 11 October 2005 03:18   |
Hi!
When you use the -l flag for the linker your libraries should follow the
name
convention: "lib(YOURLIBNAME).a", or "lib(YOURLIBNAME).so" for shared
libraries.
Your lib name is missing the first "lib" and you are using the "dll"
filetype which is only
used by windows compilers (Visual Studio, Intel,...).
Try the following solutions:
1) Rename your lib to libsayHello.so and try again
or 2) Change your linker flag to:
g++ -LP:/eclipse/HelloLib/Debug -oSleepycat.exe ./main.o HelloLib.so
In both cases, you shouldn't use the dll ending if you use the
g++ compiler!
I hope this helps
andrés
Am Mon, 10 Oct 2005 16:33:10 +0200 schrieb Petra Chong
<corno@alum.mit.edu>:
> Hello,
> Eclipse + CDT + cygwin on Windows XP. I have created a DLL containing,
> function.
> void sayHello()
> Hello hello;
> hello.sayHello();
> return 0;
> to `Hello::sayHello()'
> Many thanks,
> Petra
Written with Opera
Re: Linker problem: undefined reference, trying to use a function defined in a .dll [message #155997 is a reply to message #155992] |
Tue, 11 October 2005 04:15   |
Andrés wrote:
> Hi!
> name
> libraries.
> g++ compiler!
> I hope this helps
> andrés
Hi Andrés,
I'm afraid it did not work...
Here is the full transcript of what I have tried.
1. Build library:
make -k clean all
rm -rf ./Hello.o ./Hello.d HelloLib.dll
Building file: ../Hello.cpp
Invoking: GCC C++ Compiler
g++ -O3 -Wall -c -fmessage-length=0 -oHello.o ../Hello.cpp
Finished building: ../Hello.cpp
Building target: HelloLib.dll
g++ -shared -Wl,-soname=libHello.so -Wl,--out-implib=libHello.a
-Wl,--output-def=libHello.def -oHelloLib.dll ./Hello.o
Creating library file: libHello.a
Finished building target: HelloLib.dll
Build complete for project HelloLib
2. Build the application that is trying to link to HelloLib (I did not yet
rename HelloLib.dll to libHello.so)
make -k clean all
rm -rf ./main.o ./main.d HelloWorld.exe
Building file: ../main.cpp
g++ -IP:/eclipse/HelloLib -O0 -g3 -Wall -c -fmessage-length=0 -omain.o
../main.cpp
Finished building: ../main.cpp
Building target: HelloWorld.exe
g++ -LP:/eclipse/HelloLib/Release -oHelloWorld.exe ./main.o -lHello
/cygdrive/p/eclipse/HelloWorld/Debug/../main.cpp:10: undefined reference
make: *** [HelloWorld.exe] Error 1
make: Target `all' not remade because of errors.
Build complete for project HelloWorld
3. Rename HelloLib.dll to libHello.so, tried the above, got EXACTLY the
same output.
4. Tried the command line you suggested (with appropriate changes in path)
$ g++ -LP:/eclipse/HelloLib/Release -oHelloWorld.exe ./main.o libHello.so
g++: libHello.so: No such file or directory
I can confirm that libHello.so is in p:/eclipse/HelloLib/Release.
Couple of questions.
a) Is it possible just to rename a .dll to a .so without rebuilding? Seems
that I am misunderstanding something here?
b) If not, what do I need to do to build to a particular library type?
What is the difference between a .dll and a .so? What do all the compiler
flags do that set something to build as a shared library?
Petra
Re: Linker problem: undefined reference, trying to use a function defined in a .dll [message #156005 is a reply to message #155997] |
Tue, 11 October 2005 06:00   |
Try to change the second line to:
> -Wl,--output-def=libHello.def -olibHelloLib.so ./Hello.o
and then compile the second project with
> g++ -LP:/eclipse/HelloLib/Release -oHelloWorld.exe ./main.o -lHelloLib
andrés
Am Tue, 11 Oct 2005 10:15:42 +0200 schrieb Petra Chong
> Andrés wrote:
>> Hi!
>> the name
>> libraries.
>> g++ compiler!
>> I hope this helps
>> andrés
> Hi Andrés,
> I'm afraid it did not work... Here is the full transcript of what I have
> tried.
> 1. Build library:
> make -k clean all rm -rf ./Hello.o ./Hello.d HelloLib.dll Building
> file: ../Hello.cpp
> yet rename HelloLib.dll to libHello.so)
> make -k clean all rm -rf ./main.o ./main.d HelloWorld.exe
> ./main.cpp
> same output. 4. Tried the command line you suggested (with appropriate
> changes in path)
> Seems that I am misunderstanding something here?
> compiler flags do that set something to build as a shared library?
> Petra
Written with Opera
Re: Linker problem: undefined reference, trying to use a function defined in a .dll [message #156013 is a reply to message #156005] |
Tue, 11 October 2005 08:12   |
> andrés
OK, tried again... got this:
1. Building the library:
Building target: libHelloLib.so
Finished building target: libHelloLib.so
2. Importing / linking:
../main.cpp
/usr/lib/gcc/i686-pc-cygwin/3.4.4/../../../../i686-pc-cygwin /bin/ld:
cannot find -lHelloLib
Still no joy, I am afraid. I had also tried, on someone else's suggestion,
to use this command line:
$ ls -la p:/eclipse/HelloLib/Release/*.a
-rw-r--r-- 1 chongpe mkgroup-l-d 6236 Oct 11 13:05
p:/eclipse/HelloLib/Release/libHello.a
chongpe@wldn0135446 ~/eclipse/HelloWorld/Debug
$ g++ -static -LP:/eclipse/HelloLib/Release -oHelloWorld.exe ./main.o
-lHello
where basically I try to link statically.
Petra
Re: Linker problem: undefined reference, trying to use a function defined in a .dll [message #156020 is a reply to message #156013] |
Tue, 11 October 2005 10:01   |
ok, the shared version doesn't work because you are generating a
libHello.a file, not
a libHello.so.
aaaaaah, I think I found the error after rereading your first mail. your
method definition is
incomplete. You wrote
> void sayHello()
but you should write
> void Hello::sayHello()
you forgot to put the scope operator of the class!!!
And you should change your first linking line to:
>> -Wl,--output-def=libHello.def -oHello.dll ./Hello.o
and in the second linking process the -lHello flag.
Does it work now??
Am Tue, 11 Oct 2005 14:12:41 +0200 schrieb Petra Chong
>> andrés
> ./main.cpp
> suggestion, to use this command line:
> -lHello
> where basically I try to link statically. Thanks,
> Petra
Written with Opera
Re: Linker problem: undefined reference, trying to use a function defined in a .dll [message #156028 is a reply to message #156020] |
Tue, 11 October 2005 10:44   |
> a libHello.so.
>> void sayHello()
> Does it work now??
No joy, I am afraid.
Here is what I did:
1. As you said, resolve the function properly:
2. Build the library:
Building target: libHello.so
-Wl,--output-def=libHello.def -olibHello.so ./Hello.o
Finished building target: libHello.so
(I changed it back to do libHello.so)
3. Try to link it:
../main.cpp
g++ -Lp:/eclipse/HelloLib/Release -oHelloWorld.exe ./main.o -lHello
It's still the same error as the original one. If I rename the library to
Hello.dll or anything else other than libHello.so it seems to not even
find it.
I'm really at a dead end, I am using Visual C++ at the moment because I
cannot get Eclipse working. I can't tell if it's because I don't know how
to use g++; i have looked at a lot of man pages, but can't seem to find
anything that suggests I should be doing anything different from what I am
doing now.
Thanks for your help Andrés.
Petra
Re: Linker problem: undefined reference, trying to use a function defined in a .dll [message #156434 is a reply to message #155984] |
Mon, 17 October 2005 12:55  |
Originally posted by: mendoza.anafocus.com
Hi Petra.
I tried to read the evolution of your problem but I got a little bit lost,
so I will start again.
I've just solved a similar problem, this is, compile against a DLL using
g++.
Basically, you have to create a static library "libXXXX.a" from the DLL so
the g++ understands it.
This are the steps I've taken: (substitute "library" for your dll file
name)
1. Execute the following lines:
echo EXPORTS library.def
pexports library.dll | sed 's/^_//' > library.def
This creates a .def file that contents all the DLL functions definitions.
2. Now create the liblibrary.a file executing:
dlltool --input-def library.def --dllname library.dll --output-lib
liblibrary.a -k
3. Now, to be able to use liblibrary.a, execute:
cp liblibrary.a /usr/lib/w32api
ranlib /usr/lib/w32api/liblibrary.a
4. To link against the liblibrary.a file, use the "-llibrary" option.
5. If you still get an "undefined reference to some function" message like:
"undefined reference to SomeFunction"
go to the library.def file, rename that function to have that exact name
and repeat from step 2.
Hope this helps.
Carlos
Petra Chong wrote:
> Hello,
> function.
> void sayHello()
> Hello hello;
> hello.sayHello();
> return 0;
> `Hello::sayHello()'
> Many thanks,
> Petra
Current Time: Thu Oct 09 16:01:46 EDT 2025
Powered by FUDForum. Page generated in 0.25037 seconds
