Home » Modeling » OCL » Working with MARTE(Strange error with the import directive)
Working with MARTE [message #1551076] Wed, 07 January 2015 06:46 Go to next message
Working with OCL (v5.0.3.20141123-1844) and Papyrus (v1.0.1.201412190917)
I get a strange behavior with the import directive when I use it to import the Papyrus MARTE profile. Here is the scenario:
1. I create an empty OCL file (e.g. "dummy.ocl")
2. I add these two lines:
import marte: _'http://www.eclipse.org/papyrus/MARTE/1'
import sysml: _'http://www.eclipse.org/papyrus/0.7.0/SysML'
3. I get an error mark on the first one only(import marte: ...)
4. I make a neutral change (adding a space at the end of a line, adding an empty line,...)
5. the error mark disappears
6. I save, close and reopen the file: the error mark on the first line appears again
7. I can go back to step 4 and loop as long as I want...
Note that I never get an error mark on the SysML import directive.
Do you get the same? What do you think?
Yves
Re: Working with MARTE [message #1553375 is a reply to message #1551076] Thu, 08 January 2015 12:11 Go to previous messageGo to next message
If you open a *.ecore file with the Sample Ecore Editor and do Load
Resource.... then Browse Registered Packages you may see the same as me.
Many SYSML packages, no MARTE packages.
If you want to use MARTE I think an additional install is required.
Therefore the editor is correct when it shows an error on MARTE and none
on SYSML.
The occasionally missing MARTE error may be an Xtext synchronization
bug, or may be something I fixed a couple of weeks ago.
Ed Willink
On 07/01/2015 11:46, Yves BERNARD wrote:
> Hello,
> import marte: _'http://www.eclipse.org/papyrus/MARTE/1' import sysml:
> an empty line,...)
> appears again
> Yves
Re: Working with MARTE [message #1554465 is a reply to message #1553375] Fri, 09 January 2015 02:51 Go to previous messageGo to next message
Hi Ed,
Thanks.
You're right: an additional install is required for MARTE. I forgot to mention it, sorry.
The behaviour I described happen with the MARTE plugin installed and thus with the 'http://www.eclipse.org/papyrus/MARTE/1' actually listed as a registred package.
Yves
Re: Working with MARTE [message #1557464 is a reply to message #1551076] Sat, 10 January 2015 19:09 Go to previous messageGo to next message
Thanks. Definitely a (hopefully nice simple) bug.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=457203
Ed Willink
> Hello,
> an empty line,...)
> appears again
> Yves
Re: Working with MARTE [message #1559726 is a reply to message #1557464] Mon, 12 January 2015 01:55 Go to previous message
Ed,
You're very welcome!
Thanks for this OCL tool.
Yves
Previous Topic:New in OCL
Next Topic:Using sortedBy
Current Time: Sat Jul 26 04:03:03 EDT 2025
Powered by FUDForum. Page generated in 0.05654 seconds
