Home » Language IDEs » ServerTools (WTP) » Servers View empty
Servers View empty [message #155885] Wed, 11 January 2006 09:52 Go to next message
Originally posted by: pecanov.mt.net.mk
--=-cfeLus5yKfObr1Z3dLmx
Content-Type: text/plain
Today, out of nowhere, the Servers view came up empty.
Servers are present in "Servers" project in my workspace and I can add
them and remove them, but they are not listed in the servers view.
The view also seems not to render properly, since borders around
columns, and columns them selves are not shown. However, the
right-button menu is present. Very strange.
I've checked (.)logs but nothing is reported there.
Anyone has any clues about this?
I'm using Eclipse 3.1.1 with WTP 1.0, on Linux (GTK).
I haven't done any installing or upgrading to Eclipse, or it's plugins.
Thank you
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.8.1">
</HEAD>
<BODY>
Today, out of nowhere, the Servers view came up empty.<BR>
Servers are present in &quot;Servers&quot; project in my workspace and I can add them and remove them, but they are not listed in the servers view.<BR>
The view also seems not to render properly, since borders around columns, and columns them selves are not shown. However, the right-button menu is present. Very strange.<BR>
I've checked (.)logs but nothing is reported there.<BR>
<BR>
Anyone has any clues about this?<BR>
<BR>
I'm using Eclipse 3.1.1 with WTP 1.0, on Linux (GTK).<BR>
I haven't done any installing or upgrading to Eclipse, or it's plugins.<BR>
<BR>
Thank you<BR>
<BR>
<BR>
</BODY>
</HTML>
--=-cfeLus5yKfObr1Z3dLmx--
Re: Servers View empty [message #155912 is a reply to message #155885] Wed, 11 January 2006 12:14 Go to previous messageGo to next message
Originally posted by: cmonandspamme.yahoo.com
Had the same problem... I had to remove ALL eclipse settings (all .******)
and start over again and then it suddenly worked again.
Re: Servers View empty [message #155918 is a reply to message #155912] Wed, 11 January 2006 12:35 Go to previous messageGo to next message
--=-TkEwCOCrOCu/w5EAIzoQ
Content-Type: multipart/alternative; boundary="=-KmiE3ScynJaabxhlW/rp"
--=-KmiE3ScynJaabxhlW/rp
I know ...
I did that too :(
<HTML>
<HEAD>
</HEAD>
<BODY>
I know ...<BR>
I did that too <IMG SRC="cid:1137000902.9000.0.camel@aleksandar" ALIGN="middle" ALT=":(" BORDER="0"><BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<FONT COLOR="#000000">Had the same problem... I had to remove ALL eclipse settings (all .******) </FONT>
<FONT COLOR="#000000">and start over again and then it suddenly worked again.</FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-KmiE3ScynJaabxhlW/rp--
Content-ID: <1137000902.9000.0.camel@aleksandar>
Content-Disposition: attachment; filename=smiley-6.png
Content-Type: image/png; name=smiley-6.png
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAC40lEQVR42n2T W2iUZxCGn/+wm7Wb
gxovjBGTKLZ6Y1SqJUKhUaFWoxbNRUpKLxpFIx6KeKNeSXslggdaz4JYWiwo GIqRRFPQaMw2pCIG
s0ZlYyBqTDZ73v/4fV8vEkprxQeGYXjnHRiYgf9TAewEWgB3Mq4B2ya1/6C9 VZ9aUPnB9v1blrDm
84WY4UoQNm4mSlfXXQ6eGCc65J4Gmt81oONQc/XKXbsb0Iwp+LlB3OwAmmZg hMowgqV4uRhHj9/i
8OWxDmA1gDFpPvv9zo/rd+1pRFjDePlBpJdC0wMASDeOn4sBippPKjHyb+be 67NnAtd1oKL6o2lb
dzRvQNgjCGcUTTNo2t+NbhYyEpc07O1F0wNIN4mmB9jxzQw+nG1sByoMoDHy c/m60PRluJkouhlm
64E7tHe+IJmRPH1VxLUbj8i6Raypa8AavY1RMJ0CM0N7t/WnCSwqnF2Pk3wI 6KCZ/LCvlkxecez4
SZzUI3p7ezly9AyZoV8nFlaSqvIAwJd6efmsJgDppwEJymfOvKW0td1EOGM4 4xF+b7lCevAibvIv
AHz7DWUzDIBNZjweB80E6aKkhxIWTqIHJ/kAlI8SFsmBIyg/g5IClA/KJ5uX AOi27VxXfu4fsxQ2
0s8ivfREFjZKWBO6dFDKQwjB8KgAiJhAW/5168bg1MUIewSUT+eDNIfPDTCa cAgYGlOLTRrXlrJ5
dRglHPoHPfr7sgCXTaB1/e5XtF1aTDbv8tuNIR4/z3Nw7yZW1daAHiL2rI8f T54nWFTJ8qoE0ZhL
S5cF0G4AqZFxd06xlluyomY+88os6j4tZlbJa5zxHpyxTsLBBF/UNVBSaPIk +pjuSIqOh+I0cOnf
p/zHtg2ltfuawgRDxWh6AdJLk0hZ5CyF4ylevPSI9KQ40+reBj571zNdqJqp f/tVbSGLqqcQDmlY
jiKZkcSGPa62JxkY5hfga95DBfAdcB/wgDjQD/wELH27+W+Kz2OL5AeL7gAA AABJRU5ErkJggg==
--=-TkEwCOCrOCu/w5EAIzoQ--
Re: Servers View empty [message #158301 is a reply to message #155918] Sun, 29 January 2006 07:32 Go to previous message
Hi there!
I had the same problem a couple of times, so I diffed the .metadata
settings. Turns out it's only a column width problem! :) I filed a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=125642
There you have also the explanation on how to fix it.
It will still happen again, but at least you don't loose all your settings!
Miquel
Aleksandar Pecanov wrote:
> I know ...
> I did that too :(
Previous Topic:Tomcat logging level
Next Topic:How to use DTD from an attached jar
Current Time: Mon Jul 21 06:00:49 EDT 2025
Powered by FUDForum. Page generated in 0.08932 seconds
