Home » Language IDEs » ServerTools (WTP) » Web Service Client(The service definition selected is invalid.)
Web Service Client [message #501752] Thu, 03 December 2009 11:59 Go to next message
Hello all ...
I'm trying to create a Web Service Client.
When the box asking for a service definition appears, I enter:
http://172.17.6.100/WSDL/v4.0/iLON100.WSDL
It tells me that " The service definition selected is invalid." and that is as far as I get.
If I cut and paste the same URL into a browser, I get lots of lovely XML, as I would expect.
If I repeat the exercise with
http://soap.amazon.com/schemas2/AmazonWebServices.wsdl
it all works as expected, both in Eclipse and in the Browser.
So why doesn't eclipse like http://172.17.6.100/WSDL/v4.0/iLON100.WSDL ?
Is it having a problem parsing it ?
I'm really stuck if there is no solution !!
Thanks for any suggestions
Richard
Re: Web Service Client [message #501877 is a reply to message #501752] Fri, 04 December 2009 04:30 Go to previous messageGo to next message
Just a few more details:
1) Same behaviour on Eclipse Ganymede & Eclipse Galileo, and on 2 different computers
2) The wsdl file is in a commercial product: http://www.echelon.com/Products/cis/smartserver/default.htm
3) Netbeans has no problem with the URL http://172.17.6.100/WSDL/v4.0/iLON100.WSDL
...don't like jumping to conclusions, but looks like an Eclipse bug to me !
Re: Web Service Client [message #506247 is a reply to message #501877] Wed, 06 January 2010 11:48 Go to previous messageGo to next message
Hi Richard,
The WSDL validator included in WTP should give you any specific
errors/warning with the WSDL file. Can you try to import your WSDL file
into Eclipse and validate it?
Lawrence
Re: Web Service Client [message #510750 is a reply to message #501752] Thu, 28 January 2010 09:43 Go to previous messageGo to next message
I´ve got the same error when I try to create a web service client as follow:
http://10.3.10.72:9763/services/Verify?wsdl
All works fine If I use this instead:
http://localhost:9763/services/Verify?wsdl
The problem is that the WSDL is not on localhost but on 10.3.10.72.
Re: Web Service Client [message #510860 is a reply to message #510750] Thu, 28 January 2010 15:32 Go to previous messageGo to next message
If you haven't already,
Select Window->Preferences->Web Services->Wizard Validation.
Enable Wizard Validation for all files
In the Web Service Client dialog, click the Browse... button. In the Select Service Implementation dialog, enter the URI. Wait until validation is completed. What are the errors?
icon8.gif  Re: Web Service Client [message #510869 is a reply to message #510860] Thu, 28 January 2010 16:50 Go to previous messageGo to next message
It worked. Thanks a lot... I also configured de network connections in Windows->Preferences->General->Network Connections
and switched Active Provider to Direct for the eclipse to connect directly to 10.3.10.72...
Thanks again...
[Updated on: Thu, 28 January 2010 17:21] by Moderator
Re: Web Service Client [message #537525 is a reply to message #501752] Wed, 02 June 2010 14:39 Go to previous messageGo to next message
I am also facing similar problem.my URL address is secured and I get the xml directly from URL but from eclipse , I get the following error message "service definition selected is invalid"
My URL address is
https://<<hostname>>/fims/services/fimsRetrievalService?wsdl
I tried playing with eclipse network setting (addedd my host name to proxy bypass ) but of no help
appreciate your help
Puru
icon10.gif  Re: Web Service Client [message #1558029 is a reply to message #510869] Sun, 11 January 2015 02:51 Go to previous messageGo to next message
Surprised lmteijon wrote on Thu, 28 January 2010 21:50
Thanks again...
Re: Web Service Client [message #1695178 is a reply to message #1558029] Tue, 12 May 2015 09:44 Go to previous message
Can you please give me details on what else you have done apart from
Windows->Preferences->General->Network Connections.
I did the above changes in my Eclipse but getting the same error message.
Roshan
Previous Topic:Integrate maven jsp/webapp project with eclipse
Next Topic:Extends the javascript code completion
Current Time: Wed Jul 23 15:24:24 EDT 2025
Powered by FUDForum. Page generated in 0.04371 seconds
