Home » Eclipse Projects » Eclipse Platform » Sudden problems with Eclipse
Sudden problems with Eclipse [message #14174] |
Thu, 24 April 2003 19:00  |
Originally posted by: niceguy.wisdomteeth.tlanta.com
[Reposted from defunct eclipse.tools group]
Suddenly, my Eclipse (GTK) 2.1 install is having major problems doing
simple things. For example, if I select a Project in the Resource
Navigator perspective, and then select 'File...New....Folder', the
wizard appears as expected. When I enter the folder name, and then
select 'Finish', Eclipse seems to hang. No folder is created, the
wizard remains visible, but in a 'disabled' state. Attempting to close
the wizard does elicit a response about having to select 'Cancel' to
end the current operation before closing the dialog, but 'Cancel' is
disabled. Furthermore, after this happens, I can click on the exit
button of the main Eclipse window, and Eclipse exits. In an attempt to
fix this, I grabbed the latest integration build (I20030422), but it
exhibited the same behavior. All this is on a Mandrake Linux 9.1
machine running the Blackdown 1.4.1 JDK, but the behavior is the same
with Sun's 1.4.1_01, IBM's 1.4.1 and IBM's 1.3.1, so I don't think it is
a VM problem.
The .log file usually includes the following ominous message:
!MESSAGE Unable to find Action Set: org.eclipse.jdt.ui.refactoring.actionSet
If anyone has any thoughts on this, please reply.
Jim S.
Remove my extraneous mandibular appendages to reply via e-mail.
Re: Sudden problems with Eclipse [message #14227 is a reply to message #14174] |
Thu, 24 April 2003 21:11   |
Sounds like http://bugs.eclipse.org/bugs/show_bug.cgi?id=31525
Top shows 100% CPU, half in 'java', half in 'X11'?
Start eclipse on a konsole and then kill -QUIT <PID of one eclipse
prozess) to get a thread dump, which should reveal more.
This bug is fixed in latest gtk builds (at least on debian, don't
know about mdk).
Jan
Re: Sudden problems with Eclipse [message #15250 is a reply to message #14227] |
Fri, 25 April 2003 07:55   |
> know about mdk).
Yep, this sounds like the culprit. The comment from 4/15 about
scrollbars misbehaving is something I've seen as well. I'll have a look
around for some newer GTK builds.
Jim S.
Re: Sudden problems with Eclipse [message #15579 is a reply to message #15250] |
Fri, 25 April 2003 12:56  |
You need to update your gtk package to gtk-2.2.1-mdk3.
See Bug 36698 for instructions.
Felipe
> > know about mdk).
> Jim S.
Current Time: Tue Sep 16 15:22:48 EDT 2025
Powered by FUDForum. Page generated in 0.03851 seconds
