Home » Eclipse Projects » Eclipse Platform » Launching failed: startup.jar is missing
Launching failed: startup.jar is missing [message #155636] Tue, 11 November 2003 17:54 Go to next message
Originally posted by: eipe.NOSPAM.uiuc.edu
I'm working through Erich Gamma and Kent Beck's book on how to contribute
plugins. I tried launching a run-time workbench upon starting out to
create a plugin, and I get this message:
Exception occured during launch
Reason:
Launching failed. Required library "startup.jar" is missing from the
target platform.
The startup.jar is at C:\eclipse\startup.jar - I haven't moved it.
Any idea what I could try? See below for log entry.
Thanks for your help
Rohit
Here's the log entry:
!ENTRY org.eclipse.debug.ui 4 120 Nov 11, 2003 16:47:33.917
!MESSAGE Error logged from Debug UI:
!STACK 1
org.eclipse.core.runtime.CoreException: Launching failed. Required Library
"startup.jar" is missing from the target platform.
at
org.eclipse.pde.internal.ui.launcher.WorkbenchLaunchConfigur ationDelegate.createWorkspaceRunnerConfiguration(WorkbenchLa unchConfigurationDelegate.java:163)
at
org.eclipse.pde.internal.ui.launcher.WorkbenchLaunchConfigur ationDelegate.launch(WorkbenchLaunchConfigurationDelegate.ja va:75)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:156)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:732)
at org.eclipse.debug.ui.DebugUITools.buildAndLaunch(DebugUITool s.java:550)
at org.eclipse.debug.ui.DebugUITools$2.run(DebugUITools.java:49 9)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:101)
!ENTRY org.eclipse.pde.ui 4 0 Nov 11, 2003 16:47:33.917
!MESSAGE Launching failed. Required Library "startup.jar" is missing from
Re: Launching failed: startup.jar is missing [message #155719 is a reply to message #155636] Wed, 12 November 2003 05:04 Go to previous message
Originally posted by: wassimm.ca.ibm.com
What version of Eclipse are you using?
On the Java > Classpath variables preference page, what is the value of
the ECLIPSE_HOME variable?
On the Plug-in Development > Target Platform page, where is the location
of the platform you are developing for?
Rohit Eipe wrote:
> Hi
> Reason:
> target platform.
> The startup.jar is at C:eclipsestartup.jar - I haven't moved it.
> Rohit
> !STACK 1
> at
> at
> at
> at
> at
Previous Topic:Package Structure for Plugin Extension ...
Next Topic:purge or squeeze files in cvs
Current Time: Tue Jul 22 02:21:54 EDT 2025
Powered by FUDForum. Page generated in 0.04243 seconds
