Home » Eclipse Projects » GEF » Problem with DelegatingLayout
Problem with DelegatingLayout [message #155627] Tue, 26 October 2004 08:21 Go to next message
I am using DelegatingLayout but am facing problems with it. I suspect
the code in the method calculatePreferredSize().
<code>
protected Dimension calculatePreferredSize(IFigure parent, int wHint,
int hHint) {
List children = parent.getChildren();
Dimension d = new Dimension();
for (int i = 0; i < children.size(); i++) {
IFigure child = (IFigure)children.get(i);
d.union(child.getPreferredSize());
return d;
</code>
Here the preferred size of the container is being calculated as the union
of the preferred sizes of the children...which doesn't correspond to the
actual size that would be occupied by the child figures.
It should rather compute the Union of the bounds of the child figures ?
Can someone clarify on this?
Re: Problem with DelegatingLayout [message #155697 is a reply to message #155627] Tue, 26 October 2004 11:09 Go to previous messageGo to next message
I don't even know why that layout implements preferred size calculation.
You would have to layout in order to know the required size. Your figure
could override getPreferredSize() and just call validate() on itself, and
then union the children bounds.
"Dhiraj" <dhiraj@gmail.com> wrote in message
news:cllffs$lea$1@eclipse.org...
> <code>
> int hHint) {
> return d;
> </code>
Re: Problem with DelegatingLayout [message #155971 is a reply to message #155697] Thu, 28 October 2004 01:32 Go to previous message
Thanks Randy. my problem is solved.
> > Hi,
> > <code>
> > int hHint) {
> > return d;
> > </code>
Previous Topic:Popup menu problem
Next Topic:Palette Questions
Current Time: Fri Jul 18 21:48:00 EDT 2025
Powered by FUDForum. Page generated in 0.24694 seconds
