Home » Eclipse Projects » GEF » A Question Regarding UpdateManager
A Question Regarding UpdateManager [message #155509] Mon, 25 October 2004 18:25 Go to next message
Originally posted by: zenilnh.infotech.stph.net
Got a couple of doubts that i encountered when going through the examples.
Cna somebody please clarify??
1)
While going through the flow example ,I came across the following code,
while(GraphAnimation.step()){
parentFigure.getUpdateManager().performUpdate();
What does a peformUpdate() do??When is it used??Instead of the above cant
i call each child figure(of parentFigure) and say repaint()??
2)What is the diffrence b/w calling a figure.revalidate() and
figure.repaint()??
Zenil
Re: A Question Regarding UpdateManager [message #155665 is a reply to message #155509] Tue, 26 October 2004 11:03 Go to previous messageGo to next message
> 1)
This causes an update (layout followed by repaint) synchronously, instead of
deferred. The animation must occur while the UI is blocked to prevent
unexpected changes during the animation. Therefore, waiting for a deferred
layout is not OK.
> figure.repaint()??
revalidate() means that the figure hierarchy needs to be validated. For
example, if you change the text for a label, the label now wants to be
bigger, which may cause it's parent to be bigger, etc.
repaint() means that the figure needs to be repainted. For example, the
COLOR has changed.
Often, you need to call both revalidate() and repaint() because even if a
property changes, sometimes nothing moves, and there won't be a repaint
without asking for it.
Re: A Question Regarding UpdateManager [message #155795 is a reply to message #155665] Tue, 26 October 2004 19:21 Go to previous message
Thanks for the clarification.
Zenil
Randy Hudson wrote:
> > 1)
> layout is not OK.
> > figure.repaint()??
> COLOR has changed.
Previous Topic:Command.execute will not be called
Next Topic:Refreshing FlyoutPalette
Current Time: Fri Sep 19 04:48:32 EDT 2025
Powered by FUDForum. Page generated in 0.06205 seconds
