Home » Eclipse Projects » GEF » Problems while using button border of draw2d
Problems while using button border of draw2d [message #155461] Mon, 25 October 2004 09:29 Go to next message
Originally posted by: Greenbank.water.pku.edu.cn
Hi!Randy and other ensusiasts:
Can anyone please guide me to use the ButtonBorder? I try to use it just
as following:
label1.setBorder(new ButtonBorder());
but I am getting an Exception.
I searched in the newsgroup and found that some people had asked the
same question as me.Randy answered that it requires a Button figure.But
how can I get the figure? Can anyone please point me to an example on
the same?
Thanks a lot!
Re: Problems while using button border of draw2d [message #155470 is a reply to message #155461] Mon, 25 October 2004 10:23 Go to previous messageGo to next message
Did you see the class cast exception? That is the class you need to use
with the border.
"Greenbank" <Greenbank@water.pku.edu.cn> wrote in message
news:cliuf3$10u$1@eclipse.org...
> as following:
> the same?
> Thanks a lot!
Re: Problems while using button border of draw2d [message #155517 is a reply to message #155470] Mon, 25 October 2004 22:05 Go to previous messageGo to next message
Yes, there is an error log about the class cast exception,but it didn't
tell me which class I need to use,the log is as following:
*** Stack trace of contained exception ***
Reason:
java.lang.ClassCastException
Unhandled exception caught in event loop.
Reason:
Failed to execute runnable (java.lang.ClassCastException)
Randy,could you give me a simple example about how to use the
ButtonBorder? Thank you very much!
Best regards!
Greenbank Tang
Peking University
Beijing,China
Tel:86-010-62759092
> with the border.
>>as following:
>>the same?
>>Thanks a lot!
Re: Problems while using button border of draw2d [message #155524 is a reply to message #155517] Tue, 26 October 2004 01:01 Go to previous messageGo to next message
Have you look in the [runtime-workbench-workspace/.metadata/.log]
file?
I think you will find the hole stack trace. In that case you can take
a close look to your code.
I find my hole mistakes in this log file.
greetings
Andreas
Re: Problems while using button border of draw2d [message #155548 is a reply to message #155524] Tue, 26 October 2004 01:56 Go to previous messageGo to next message
Thanks for reminding me!
I read the .log file and find the exception start at
at org.eclipse.draw2d.ButtonBorder.paint(ButtonBorder.java:226)
but I just use the following codes:
label.setBorder(new ButtonBorder());
to set a border and the system called this function automaticly.
Is this problem a mistake of mine or something wrong with my system?
Anyone who gives any idea will be grateful. :)
Greenbank Tang
Peking University
Beijing,China
Tel:86-010-62759092
> file?
> greetings
> Andreas
Re: Problems while using button border of draw2d [message #155589 is a reply to message #155548] Tue, 26 October 2004 03:47 Go to previous messageGo to next message
In the ButtonBorder.java on line 226(or 227)
you can see that the ButtonBorder expected an
class from type [Clickable]. The class [Label]
doesn't extends this class.
In this case you can't use the ButtonBorder for
a Label. Use instead [SimpleRaisedBorder].
greetings
Andreas
226 public void paint(IFigure figure, Graphics graphics, Insets insets) {
227 Clickable clickable = (Clickable)figure; <<<<<< crash
228 ButtonModel model = clickable.getModel();
229 ButtonScheme colorScheme = (ButtonScheme)getScheme();
230
231 if (clickable.isRolloverEnabled() && !model.isMouseOver()
232 && !model.isSelected())
233 return;
234
235 Color tl[], br[];
236 if (model.isSelected() || model.isArmed()) {
237 tl = colorScheme.getShadowPressed();
238 br = colorScheme.getHighlightPressed();
239 } else {
240 tl = colorScheme.getHighlight();
241 br = colorScheme.getShadow();
242 }
243
244 paint(graphics, figure, insets, tl, br);
245 }
> Greenbank Tang
> Peking University
> Beijing,China
> Tel:86-010-62759092
Re: Problems while using button border of draw2d [message #155611 is a reply to message #155589] Tue, 26 October 2004 05:52 Go to previous messageGo to next message
Thanks for Andreas' answer!Now I understand where I was wrong.
But what I am trying to do is to write an editor just like the SWT
Designer.I want to use the draw2d control figures as my view(like the
buttons,textfields...).And I just need an static editable image of the
button(the display text can be changed by the user)rather than a real
clickable one.But the draw2d button do not provide any methods to change
these properties of the figures after constructed.So I asked this
question here a few days ago,Randy suggested me to use a label figure
with a button border.If I cannot achieve my goal by this method,could
anyone point me another way?
Each time when I asked a question here I received many enthusiasm
replys,and they helped me a lot.I really appreciated these friends and
people,if any of you come to china please contact me!
Best Wishes!
Greenbank Tang
Peking University
Beijing,China
Tel:86-010-62759092
FreeGroup wrote:
> Hi
> greetings
> Andreas
> 230
> 233 return;
> 234
> 239 } else {
> 242 }
> 243
> 245 }
>> Greenbank Tang
>> Peking University
>> Beijing,China
>> Tel:86-010-62759092
Re: Problems while using button border of draw2d [message #155657 is a reply to message #155611] Tue, 26 October 2004 11:00 Go to previous message
Create a Button figure, and add a Label to it as its child.
Previous Topic:Question Regarding ActivityDiagramPart in Flow Example
Next Topic:insert more than one element with the palette at once
Current Time: Sat Sep 13 17:40:14 EDT 2025
Powered by FUDForum. Page generated in 0.04317 seconds
