Re: Can't select target during edge creation [message #1554699 is a reply to message #1554579] |
Fri, 09 January 2015 05:51   |
Hi Tommaso,
What do you mean by it is blocked?
Nothing is created or you are in deadlock?
Best Regards.
Le 09/01/2015 10:20, Tommaso De Sica a écrit :
> Hello everyone,
> I'm still a beginner and I've got a very annoying problem during edge
> creation.
> I've got a Node called PortNode (which is associated to EObject Port),
> and I've got an edge called ConnectionEdge (which is associated to
> EObject Connection).
> This is my model situation:
> Port has 0...* Connection
> Connection has 2 Port
> Each port stay in a different resource, and there is another resource
> contains all connections.
> I've tryed to create an EdgeCreation. Edge Mappings is ConnectionEdge,
> which has PortNode as Source Mapping and Target Mapping.
> Now I'm going to use that operation, I can select a PortNode as source,
> but when I try to select PortNode as destination, it is blocked.
> Any suggestions?
> Very thank you.
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: Can't select target during edge creation [message #1561858 is a reply to message #1554846] |
Tue, 13 January 2015 05:43  |
Could you provide an example to reproduce? Because your description
doesn't help.
Best Regards.
Le 09/01/2015 13:54, Tommaso De Sica a écrit :
> Thank you for fast reply. When I use creation tool I can select first
> PortNode, but not the second one (I can't click on it, the mouse pointer
> has ban symbol).
FUDForum. Page generated in 0.04517 seconds
