Home » Language IDEs » ServerTools (WTP) » xml format and big files
xml format and big files [message #155261] Sat, 07 January 2006 14:22 Go to next message
I try format big xml file (600k, original in 2 lines)
on eclipse with wtp 1.0 and netbeans 5.1 dev (linux ,P3 900 mhz 512M)
netbeans do work relative quick and don't block ide when do format
eclipse freeze - i wait yet, but i think that i have to kill IDE
Please comment
Re: xml format and big files [message #155293 is a reply to message #155261] Sun, 08 January 2006 00:42 Go to previous messageGo to next message
Originally posted by: ifedorenko.rogers.com
https://bugs.eclipse.org/bugs/show_bug.cgi?id=102822
Haris Peco wrote:
> Hello,
> Please comment
Re: xml format and big files [message #155320 is a reply to message #155293] Sun, 08 January 2006 10:12 Go to previous messageGo to next message
i see, but it is general eclipse failure, not formating only.
i can't explore this file too and simple text (or java editor)
freeze eclipse with large files (> 2mb)
see http://www.eclipsezone.com/eclipse/forums/t59786.html
this is bad and blam for eclipse
> Haris Peco wrote:
>> Hello,
>> Please comment
Re: xml format and big files [message #155349 is a reply to message #155293] Sun, 08 January 2006 15:16 Go to previous messageGo to next message
On Sun, 08 Jan 2006 00:42:41 -0500, Igor Fedorenko <ifedorenko@rogers.co=
m> wrote:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D102822
> Haris Peco wrote:
>> Hello,
>> on eclipse with wtp 1.0 and netbeans 5.1 dev (linux ,P3 900 mhz 512M)=
>> netbeans do work relative quick and don't block ide when do format=
>> Please comment
Also see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D108806
I suspect since original is in "2 lines", that bug 108806
is the majority of this this problem.
Thanks for the continued reminders of what problem's you encounter in pr=
actice.
Re: xml format and big files - off topic [message #155365 is a reply to message #155320] Sun, 08 January 2006 15:28 Go to previous messageGo to next message
I must say I found this blog entry very interesting useful, so thanks Ha=
rris for
pointing it out, and thanks to Ed for writing it!
I think its very helpful to have this sort of "meta analysis" of bugs
to identify a problem that might go unnoticed (or, at least its severity=
when you look at only individual bugs. I wonder how many other constella=
tions of
bugs are lurking out in that in that mass database of 20,000 open Eclips=
e bugs?
It may seem acedemic, but I wonder if there's been any "clustering" work=
done
to help identify groups, or themes of bugs? (If not, would be a good mas=
ters theis :)
Re: xml format and big files - off topic [message #155373 is a reply to message #155365] Sun, 08 January 2006 17:46 Go to previous messageGo to next message
> Harris for pointing it out, and thanks to Ed for writing it!
> to identify a problem that might go unnoticed (or, at least its severity)
> constellations of bugs are lurking out in that in that mass database of
> 20,000 open Eclipse bugs?
> done to help identify groups, or themes of bugs? (If not, would be a good
> masters theis :)
i format this file with prettyPrint (from dom4j) and it do job for 2-3
seconds - after this formating xml editor work fine with this file
(file is from windows environment,too - e-banking statement)
vim editor (6.1) can't work with long line, too, but work fine after dom4j's
formatting
Re: xml format and big files - off topic - sorry [message #155381 is a reply to message #155373] Sun, 08 January 2006 18:07 Go to previous messageGo to next message
>> masters theis :)
> dom4j's formatting
i work with wrong file (sorry) - file with 600k freeze eclipse after dom4j's
prettyPrint,too - explore or formatting do freeze
Re: xml format and big files - off topic [message #156023 is a reply to message #155365] Wed, 11 January 2006 22:10 Go to previous message
> constellations of
> Eclipse bugs?
Would an audit on File.deleteOnExit() usage to remove it from the
codebase and use some alternative method fall within what you ask.
http://www.bobcongdon.net/blog/2005/07/filedeleteonexit-is-e vil.html
http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=4513817
Darryl
Previous Topic:Does XDoclet work for you with WTP M200601102004 (aka R1.0.1 alpha) ?
Next Topic:could supply a tool to convent a project to J2EE prpject
Current Time: Sat Nov 15 09:52:07 EST 2025
Powered by FUDForum. Page generated in 0.05209 seconds
