Home » Language IDEs » C / C++ IDE (CDT) » memory leaks
memory leaks [message #155338] Thu, 29 September 2005 03:17 Go to next message
does anyone know a half-decent program for detecting memory leaks? i've
tried a few scripts that track new and delete operations within the code
and external programs but nothing has really worked. there has to be
something out there i'm sure, any reccommendations?
Re: memory leaks [message #155371 is a reply to message #155338] Thu, 29 September 2005 04:32 Go to previous messageGo to next message
Originally posted by: johan.nosp.m.appeal.se
Valgrind is *excellent*: http://valgrind.org/
//Johan
Re: memory leaks [message #155462 is a reply to message #155371] Thu, 29 September 2005 21:02 Go to previous messageGo to next message
looks great, but does anyone know one for windows/cygwin? i've found a
few for linux but that doesn't help me at the moment.
> //Johan
>> i've tried a few scripts that track new and delete operations within
>> the code and external programs but nothing has really worked. there
>> has to be something out there i'm sure, any reccommendations?
Re: memory leaks [message #155494 is a reply to message #155462] Fri, 30 September 2005 03:42 Go to previous message
you should try Eletric Fence (efence), a small library for c++ code. Just
google for it. You just
have to compile the efence files, build the library and then, finally,
include the lib in the
linking process of your project (with -lefence).
Quite small, but very usefull.....
good luck
andrés
Am Fri, 30 Sep 2005 03:02:28 +0200 schrieb Anthony Knittel
<anthony@centreforthemind.com.au>:
>> //Johan
Written with Opera
Previous Topic:External Tools causing rebuild
Next Topic:CTags not found or in path? Which path?
Current Time: Sun Jul 27 04:40:08 EDT 2025
Powered by FUDForum. Page generated in 0.04642 seconds
