Home » Language IDEs » C / C++ IDE (CDT) » How to debug a vector
How to debug a vector [message #155287] |
Wed, 28 September 2005 11:04  |
Originally posted by: mendoza.anafocus.com
Hello.
I just can't view the contents of a vector when debugging. I just see
something like this:
{<_Vector_base<int,std::allocator<int> >> = {_M_impl = {<allocator<int>> =
{<new_allocator<int>> = {<No data fields>}, <No data fields>}, _M_start =
0x3fd140, _M_finish = 0x3fd258, _M_end_of_storage = 0x3fd340}}, <No data
fields>}
Is this a bug or is it something that I'm missing?.
Re: How to debug a vector [message #155502 is a reply to message #155413] |
Fri, 30 September 2005 04:14   |
Ok. Here you are a very simple test case:
int main()
vector<int> OneVector(10);
for(int i=0;i<10;i++)
OneVector.push_back(i);
return 0;
If I stop the debugger at "return 0;" and select "OneVector" in the
Variables view, I get:
0x3f2760, _M_finish = 0x3f27b0, _M_end_of_storage = 0x3f27b0}}, <No data
fields>}
By the way, I can add watch expressions like "OneVector.at(0)", but I
would like to see the whole vector contents at a glance.
Mikhail Khodjaiants wrote:
> The CDT debugger is using gdb as backend. Probably, gdb can not handle the
> vector types c9orrectly.
> If you post a simple test case I can give you the details.
> "Carlos" <mendoza@anafocus.com> wrote in message
> news:6338fc4f048d9bfc087d9f08ae8b861d$1@www.eclipse.org...
>> Hello.
>> fields>}
>> Thanks
Re: How to debug a vector [message #155526 is a reply to message #155502] |
Fri, 30 September 2005 16:48   |
Originally posted by: mikhailk.qnx.com
What is your environment? The example works fine for me (CDT 3.0, CygWin,
Windows 2000).
news:23d00a7e2e8c831c63f37266934e69e9$1@www.eclipse.org...
> int main()
> return 0;
> fields>}
>> the vector types c9orrectly.
>>> Hello.
>>> = {<new_allocator<int>> = {<No data fields>}, <No data fields>},
>>> _M_start = 0x3fd140, _M_finish = 0x3fd258, _M_end_of_storage =
>>> 0x3fd340}}, <No data fields>}
>>> Thanks
Re: How to debug a vector [message #155653 is a reply to message #155526] |
Tue, 04 October 2005 08:16   |
I'm working under Windows XP Pro, CDT 3.0, Cygwin.
Please, could you tell me what do you see in the Variables view?. Maybe
I'm asking to much.
> Windows 2000).
>> int main()
>> return 0;
>> fields>}
>>>> Hello.
>>>> Thanks
Re: How to debug a vector [message #155695 is a reply to message #155653] |
Tue, 04 October 2005 14:01  |
I see a similar output in the Detail pane of the Variables view, but the
tree looks fine.
news:b771088b74562efb89fab384aaede0e0$1@www.eclipse.org...
> I'm asking to much.
>> Windows 2000).
>>> int main()
>>> return 0;
>>> fields>}
>>>>> Hello.
>>>>> {<allocator<int>>
>>>>> Thanks
Attachment: vector.jpg
(Size: 142.86KB, Downloaded 720 times)
Current Time: Thu Jul 17 20:27:42 EDT 2025
Powered by FUDForum. Page generated in 0.05116 seconds
