Home » Eclipse Projects » Plugin Development Environment (PDE) » File | Export | PDE | Deployable Plugins - Bug with nested src
File | Export | PDE | Deployable Plugins - Bug with nested src [message #14888] Mon, 04 August 2008 04:16 Go to next message
Originally posted by: ekkehard.gentz-software.de
I have already reported a bug (bugzilla 241830), but got no response
till now.
I cannot use
if the bundle has nested src/
but I need the nested src/ because I generate source using
openArchitectureWare and so I have src/gen, src/res etc.
File | Export | Java | Jarfile
can export the bundle without problems, but then I loose the PDE comfort
to deploy a bundle
only workaround at the moment is to copy all to another bundle at src/
before deploy
if someone has an idea how to use
with nested src/ would be really great
thx
ekke
Re: File | Export | PDE | Deployable Plugins - Bug with nested src [message #15388 is a reply to message #14888] Tue, 05 August 2008 15:54 Go to previous messageGo to next message
What happens if you change your build.properties so that you have
source.. = src/gen, src/res
-Andrew
> till now.
> I cannot use
> to deploy a bundle
> before deploy
> thx
> ekke
Re: File | Export | PDE | Deployable Plugins - Bug with nested src [message #15421 is a reply to message #15388] Tue, 05 August 2008 16:55 Go to previous messageGo to next message
Andrew,
I have it this way - otherwise there would be a warning ;-)
and I can export as a Jar, but not as a plugin
ekke
> -Andrew
>> till now.
>> I cannot use
>> comfort to deploy a bundle
>> before deploy
>> thx
>> ekke
Re: File | Export | PDE | Deployable Plugins - Bug with nested src [message #15520 is a reply to message #15388] Wed, 06 August 2008 07:10 Go to previous messageGo to next message
btw: a very small example plugin is attached to bugzilla 241830
ekke
> -Andrew
>> till now.
>> I cannot use
>> before deploy
>> thx
>> ekke
Re: File | Export | PDE | Deployable Plugins - Bug with nested src [message #18858 is a reply to message #15520] Wed, 03 September 2008 01:18 Go to previous messageGo to next message
any ideas ?
this bug is really frustrating and blocks the normal workflow
thx for any help with https://bugs.eclipse.org/bugs/show_bug.cgi?id=241830
ekke
> ekke
>> -Andrew
>>> till now.
>>> I cannot use
>>> before deploy
>>> thx
>>> ekke
Re: File | Export | PDE | Deployable Plugins - Bug with nested src [message #21212 is a reply to message #18858] Fri, 12 September 2008 02:30 Go to previous message
benjamin cabe found a workaround:
its the /src entry in build.properties (Source...)
PDE build uses
/src, /src/gen and /src/man
and so gets classes twice and reports errors
in opposite to this behaviour the normal Java Build Path from project
properties have more informations:
/src (without /src/man, /src/gen)
/src/man
/src/gen
so the normal java build gets classes only one time
solution should be that build.properties has more informations stored in
..classpath of the project
thanks to benjamin I can use PDE again to export
(only have tp watch that nothing on my projects is directly placed under
/src)
ekke
ekke schrieb:
> any ideas ?
> ekke
>> ekke
>>> -Andrew
>>>> till now.
>>>> I cannot use
>>>> before deploy
>>>> thx
>>>> ekke
Re: File | Export | PDE | Deployable Plugins - Bug with nested src [message #575494 is a reply to message #14888] Tue, 05 August 2008 15:54 Go to previous message
-Andrew
> till now.
> I cannot use
> to deploy a bundle
> before deploy
> thx
> ekke
Re: File | Export | PDE | Deployable Plugins - Bug with nested src [message #575520 is a reply to message #15388] Tue, 05 August 2008 16:55 Go to previous message
Andrew,
ekke
> -Andrew
>> till now.
>> I cannot use
>> before deploy
>> thx
>> ekke
Re: File | Export | PDE | Deployable Plugins - Bug with nested src [message #575640 is a reply to message #15388] Wed, 06 August 2008 07:10 Go to previous message
ekke
> -Andrew
>> till now.
>> I cannot use
>> before deploy
>> thx
>> ekke
Re: File | Export | PDE | Deployable Plugins - Bug with nested src [message #578155 is a reply to message #15520] Wed, 03 September 2008 01:18 Go to previous message
any ideas ?
ekke
> ekke
>> -Andrew
>>> till now.
>>> I cannot use
>>> before deploy
>>> thx
>>> ekke
Re: File | Export | PDE | Deployable Plugins - Bug with nested src [message #579933 is a reply to message #18858] Fri, 12 September 2008 02:30 Go to previous message
PDE build uses
/src/man
/src/gen
/src)
ekke
ekke schrieb:
> any ideas ?
> ekke
>> ekke
>>> -Andrew
>>>> till now.
>>>> I cannot use
>>>> before deploy
>>>> thx
>>>> ekke
Previous Topic:plugin.xml created by PDE for plug-in with sample help contents
Next Topic:Icon for contenttype is not displayed when plugin is deployed
Current Time: Sat Nov 08 18:03:54 EST 2025
Powered by FUDForum. Page generated in 0.05231 seconds
