| GNU Autotool-Based Projects: Best Practices? [message #154763] |
Wed, 21 September 2005 10:42  |
Originally posted by: eeide.cs.utah.edu
Having looked over the online CDT docs and recent posts to this newsgroup, I
haven't found a good answer to what I think must be a common question:
What are the best practices for working with exitsing C/C++ projects
that use the GNU autotools (autoconf, etc.)?
Some things seem relatively straightforward, e.g., running one's `configure'
script as an external tool. Other tasks, however, like managing multiple,
separate object trees, seem not so obvious to me. In addition, it would seem
to be tedious to set up this kind of "custom" configuration for every C/C++
project that uses the GNU autotools.
Given that there are many (!) existing C/C++ free software projects that use
the GNU tools, I assumed it would not be hard to find advice for working with
such projects in Eclipse CDT. But I was wrong! Either it is hard to find good
advice, or I'm just looking in all the wrong places.
So --- all pointers appreciated! Thanks!
Eric.
Eric Eide <eeide@cs.utah.edu> . University of Utah School of Computing
http://www.cs.utah.edu/~eeide/ . +1 (801) 585-5512 voice, +1 (801) 581-5843 FAX
| Re: GNU Autotool-Based Projects: Best Practices? [message #155177 is a reply to message #154763] |
Tue, 27 September 2005 14:29   |
Previously I wrote:
Eric> Having looked over the online CDT docs and recent posts to this
Eric> newsgroup, I haven't found a good answer to what I think must be
Eric> a common question:
Eric>
Eric> What are the best practices for working with exitsing C/C++
Eric> projects that use the GNU autotools (autoconf, etc.)?
Eric>
Eric> Some things seem relatively straightforward, e.g., running one's
Eric> `configure' script as an external tool. Other tasks, however,
Eric> like managing multiple, separate object trees, seem not so
Eric> obvious to me. In addition, it would seem to be tedious to set
Eric> up this kind of "custom" configuration for every C/C++ project
Eric> that uses the GNU autotools.
Eric>
Eric> Given that there are many (!) existing C/C++ free software
Eric> projects that use the GNU tools, I assumed it would not be hard
Eric> to find advice for working with such projects in Eclipse CDT.
Eric> But I was wrong! Either it is hard to find good advice, or I'm
Eric> just looking in all the wrong places.
Eric>
Eric> So --- all pointers appreciated! Thanks!
I haven't seen any replies --- so just in case the original was lost, I'm
"reposting" my question.
Thanks!
Eric.
| Re: GNU Autotool-Based Projects: Best Practices? [message #155254 is a reply to message #155177] |
Wed, 28 September 2005 08:56   |
> Eric>
> Eric>
> Eric>
> Eric>
> Thanks!
> Eric.
I've tried this one
http://kde-eclipse.pwsp.net/
but I couldn't make it work... if you are more lucky please let me know
Lorenzo
FUDForum. Page generated in 0.06829 seconds
