Home » Eclipse Projects » Eclipse Platform » Re: pb building TreeView
| Re: pb building TreeView [message #15382] |
Fri, 25 April 2003 10:20  |
Originally posted by: knut_radloff.oti.com
Does getChildNodes return null when there are no more children? You can set an exception breakpoint in the debugger and find
out.where the exception is occurring.
Knut
PS: Please continue the thread on eclipse.platform, eclipse.tools should no longer be used and will be made read-only soon.
"anthony saucet" <anthony.saucet@freesbee.fr> wrote in message news:b8bbcv$u1r$1@rogue.oti.com...
> I'm trying to build a TreeView in my perspective to have a look on a DOM
> tree built in memory.
> I've implemented the TreeView with new TreeViewer, called
> setContentProvider() and setLabelProvider(). setInput() gets the
> rootElement of my DOM tree. Then in class contentProvider, the tree is
> being built by getChildren(), and everything seems ok.
> here's the code to get the children:
> public Object[] getChildren(Object element) {
> Object elnts[]=new Object[20];
> int i = 0;
> int j=((Element)element).getChildNodes().getLength();
> for(Node child = ((Element)element).getFirstChild(); i<j;
> ((Element)element).getNextSibling()){
> elnts[i]=((Element)element).getChildNodes().item(i);
> i++;
> return elnts;
> I don't really know what happens BUT when it arrives at the end, when no
> more child or items, it tries to continue and to create the tree and the
> following message appears:
> "Unable to create part: Tree" from
> eclipse.core.internal.runtime.InternalPlatform
> and the exception: "nullPointerException".
> Does anybody have an idea of what I need to do, or what I missed ?
> many thx
| Re: pb building TreeView [message #15516 is a reply to message #15382] |
Fri, 25 April 2003 11:15   |
Originally posted by: anthony.saucet.freesbee.fr
getChildNodes() is not null BUT getChildNodes().getLength() = 0 !!!
I've printed out what happens in class contentProvider:
getChildNodes: !null
j: 0 /* getChildNodes().getLength() */
contentPovider getChildren end /* end of method getChildren() */
hasChild /* call method hasChild */
contentPovider getChildren /* calls method getChildren() */
and when tries j = getChildNodes().getLength(), stops here and after lot
of things I didn't catch, exception.
anthony
> Knut
> > int i = 0;
> > i++;
> > return elnts;
> > many thx
| Re: pb building TreeView [message #15610 is a reply to message #15516] |
Fri, 25 April 2003 13:07   |
I just noticed that you initialize your children array (elnts) to a fixed size. The array you return must only have enough slots for
all the children and no extra null slots. That's probably what's causing the exception.
You need to size it to getChildNodes().getLength(). If you have no children an empty array will be returned.
Knut
"anthony saucet" <anthony.saucet@freesbee.fr> wrote in message news:b8bjer$6na$1@rogue.oti.com...
> anthony
> > Knut
> > > int i = 0;
> > > i++;
> > > return elnts;
> > > many thx
| Re: pb building TreeView [message #15642 is a reply to message #15610] |
Fri, 25 April 2003 13:08   |
Oops, I just ignored my own advice and crossposted to the deprecated eclipse.tools newsgroup.
"Knut Radloff" <knut_radloff@oti.com> wrote in message news:b8bq00$cob$1@rogue.oti.com...
for
> Knut
> > anthony
> > > Knut
> > > > int i = 0;
> > > > i++;
> > > > return elnts;
> > > > many thx
| Re: pb building TreeView [message #15672 is a reply to message #15516] |
Fri, 25 April 2003 13:10   |
Antony, The problem u are encountering might be due to the fact that u are
using an array that has no elements. Use a list and convert it to a array to
return an array of objects.
HTP
> anthony
set
> > Knut
no
DOM
> > > int i = 0;
> > > i++;
> > > return elnts;
no
the
> > > many thx
| Re: pb building TreeView [message #15700 is a reply to message #15672] |
Fri, 25 April 2003 13:13   |
I did not see Radloff's reply..
Balaji
"Balaji" <balajik@us.ibm.com> wrote in message
news:b8bq7h$cu5$1@rogue.oti.com...
to
> HTP
> > anthony
can
> set
> > > Knut
should
> no
> DOM
is
> > > > int i = 0;
> > > > i++;
> > > > return elnts;
when
> no
> the
> > > > many thx
| Re: pb building TreeView [message #18550 is a reply to message #15610] |
Mon, 28 April 2003 05:44   |
You were right, now I size the array with getLength() and tree.setInput()
works perfectly. It seems to build a tree in memory and then expand the
tree in the view, BUT without the root element.
What's the trick to display it?
anthony
exception.
> Knut
> > anthony
set
> > > Knut
no
DOM
> > > > int i = 0;
> > > > i++;
> > > > return elnts;
no
the
> > > > many thx
| Re: pb building TreeView [message #21883 is a reply to message #18550] |
Tue, 29 April 2003 07:25   |
I've resolved the pb. Instead of getting the root element (ElementImpl) of
my DOM tree, I retrieve the whole document (DocumentImpl), which will be
the root. Then my root element is a child of the doc.
> anthony
the
> exception.
> > Knut
> > > anthony
> set
> > > > Knut
should
> no
> DOM
is
> > > > > int i = 0;
> > > > > i++;
> > > > > return elnts;
> no
> the
> > > > > many thx
| Re: pb building TreeView [message #27520 is a reply to message #21883] |
Mon, 05 May 2003 07:52   |
When I was building the tree in memory, everything was ok, I followed your
advices.
But now I build it in a class and I have a stange pb.
I build my DOM tree in memory with the root element from my DTD. I
retrieve it (No problem.) and try to display it in the the treeView (pb).
I got an inputChanged where new_input is null. And I don't know why!
'cause I only have the rootElement in the document.
Messages I got:
ContentProvider-inputChanged // launching of the view
ContentProvider-inputChanged old=null
tree view // setContentProvider
tree view // setLabelProvider
TREEbuilder-getDoc[MASTER103: null] //gets the rootElement
ContentProvider-inputChanged new=null
Do you have any idea ?
thanks, anthony
> > anthony
> the
> > exception.
children
> > > Knut
lot
> > > > anthony
can
> > set
> > > > > Knut
> should
> > no
a
> > DOM
> is
> > > > > > int i = 0;
> > > > > > i++;
> > > > > > return elnts;
when
> > no
and
> > the
> > > > > > many thx
| Re: pb building TreeView [message #28578 is a reply to message #27520] |
Wed, 07 May 2003 06:40  |
In fact I think I have something working wrong. I don't know if it's my pc
or eclipse (or the 'Run' mode), but sometimes its behaviour is very
strange.
Now, everything is almost ok, but without modifying anything, the layout
has changed !
thx anyway for your help
anthony
> advices.
> Messages I got:
> thanks, anthony
> > > anthony
fixed
causing
> > the
> > > exception.
> children
> > > > Knut
> lot
> > > > > anthony
> can
> > > set
> > > > > > Knut
> > should
> > > no
on
> a
> > > DOM
tree
> > is
> > > > > > > int i = 0;
> > > > > > > i++;
> > > > > > > return elnts;
> when
> > > no
> and
> > > the
> > > > > > > many thx
Current Time: Sun Nov 09 03:51:02 EST 2025
Powered by FUDForum. Page generated in 0.06537 seconds
