Home » Modeling » Papyrus » <<use>> not displayed(<<use>> label randomly disappears from Usage dependencies)
<<use>> not displayed [message #1549678] Tue, 06 January 2015 12:29 Go to next message
The display of the <<use>> stereotype in Usage dependencies often disappears from my class diagrams. It seems random - sometimes closing and opening the diagram restores them, sometimes it makes them disappear. Sometimes hiding the link in the diagram and then dragging it from the model view restores it -sometimes not. Some dependencies have the label and others not in the same diagram.
When a diagram is opened, the <<use>> is briefly rendered.
Typically, I am using the Usage dependencies between classes (rather than associations).
Is anyone else experiencing this, and is there a cure?
Clive.
Re: <<use>> not displayed [message #1553315 is a reply to message #1549678] Thu, 08 January 2015 11:33 Go to previous message
Hi Clive,
It would be useful if you could specify the version of Papyrus you are using. I'm running Luna SR1 (with nightly builds).
I have not experienced the <<use> being briefly rendered. However, I have experienced that the <<use>> is sometimes positioned rather far from the dependency arrow, which can be confusing when you have multiple <<use>> relationships displayed. In such a case, clicking on <<use>> and moving it slightly will show a link to the correct arrow.
You can also hide/show the <<use>> if you right-click on it or its the usage dependency arrow and select "Filters > Manage Connector Labels" from the pop-up menu.
I'm not sure whether this solves your problem, but I hope it helps you with your modeling tasks.
/Charles
Previous Topic:new to sysml: package?
Next Topic:Register Listener on Editor Changes
Current Time: Sun Jul 27 01:58:49 EDT 2025
Powered by FUDForum. Page generated in 0.05181 seconds
