Home » Language IDEs » C / C++ IDE (CDT) » CTags not found or in path? Which path?
CTags not found or in path? Which path? [message #154948] Fri, 23 September 2005 00:14 Go to next message
I have exuberant-ctags in my /usr/bin. My cdt always complain about
CTags not found on path or not installed.
I do not specify the binary explicitly but use default in the indexer
settings.
What path is it looking for? Any ideas?
Re: CTags not found or in path? Which path? [message #154954 is a reply to message #154948] Fri, 23 September 2005 01:32 Go to previous messageGo to next message
Alwyn,
if you start a command shell on your system, type "ctags" and it works then
it should work from eclipse, too. Eclipse also just starts a new shell and,
when no path is given, calls ctags without explicit path. The "path" is
simply the standard command search path.
Can you confirm this?
Norbert
"Alwyn Schoeman" <alwyn.schoeman@gmail.com> schrieb im Newsbeitrag
news:dgvvsp$58t$1@news.eclipse.org...
> settings.
Re: CTags not found or in path? Which path? [message #154956 is a reply to message #154954] Fri, 23 September 2005 03:01 Go to previous messageGo to next message
Hi Norbert,
ctags yield command not found. Maybe what I need is a link between
ctags and exuberant-ctags...
Norbert Ploett wrote:
> Alwyn,
> Norbert
>>Hi,
>>settings.
Re: CTags not found or in path? Which path? [message #155138 is a reply to message #154956] Tue, 27 September 2005 13:03 Go to previous messageGo to next message
Alwyn Schoeman wrote:
> Hi Norbert,
>>Alwyn,
>>Norbert
>>>Hi,
>>>settings.
Make sure that 'which ctags' yields you the exuberant one, and restart
Eclipse.
JC
Re: CTags not found or in path? Which path? [message #155231 is a reply to message #155138] Wed, 28 September 2005 01:37 Go to previous messageGo to next message
Something new I've noticed is that when the ctags file gets very big, I
get a NegativeArrayException whenever I ask for a completion. Deleting
the file, fixes it till next time...
>> Hi Norbert,
>>> Alwyn,
>>> works then it should work from eclipse, too. Eclipse also just starts
>>> a new shell and, when no path is given, calls ctags without explicit
>>> path. The "path" is simply the standard command search path.
>>> Norbert
>>>> Hi,
>>>> settings.
> Eclipse.
> JC
Re: CTags not found or in path? Which path? [message #155518 is a reply to message #155231] Fri, 30 September 2005 14:06 Go to previous message
Sounds like a good bug for bugzilla...
Previous Topic:memory leaks
Next Topic:eclipse, JNI and tomcat
Current Time: Tue Jul 22 14:02:43 EDT 2025
Powered by FUDForum. Page generated in 0.51166 seconds
