| Showing only a part of a line series? [message #154915] | Thu, 20 April 2006 14:53  |  |
| Eclipse User  |  |  |  |  | Originally posted by: mikewulkan.flyingmoose.ca
 I have a chart with 3 line graph series.  Series 1 data is meaningful from
 X1-Xa.  Series 2 data is meaningful between Xa -Xb; and finally Series 3
 data is meaningful between Xa - Xc.
 Currently I am just setting the values of the series to 0 where the series
 falls outside their meaningful ranges.  However this doesn't look very nice.
 Is there a way of limiting the X axis range where a line series is actually
 plotted?
 Mike
| Re: Showing only a part of a line series? [message #155219 is a reply to message #155212] | Fri, 21 April 2006 09:10  |  |
 Ooops! Nevermind that last post.  I was plotting the wrong value.
 Mike
 "Mike Wulkan" <mikewulkan@flyingmoose.ca> wrote in message
 news:e2akmj$58k$1@utils.eclipse.org...
 > Hi David,
 > Thanks, this seems to cover about 98% of the problem.
 > For some reason the Series 1 plot seems to interpret null values as zero
 and
 > plots them as such.  But the other series behave as you describe and don't
 > plot the points.
 > Can you think of any reason this should be happening?
 > Mike
 > "David Michonneau" <dmichonneau@actuate.com> wrote in message
 > news:e29vfl$f5q$1@utils.eclipse.org...
 > > Not really, but you could try to set some null values instead of 0
 values.
 > > It should not plot them in that case.
 > > Thanks,
 > > David
 > > news:e28lap$pi2$1@utils.eclipse.org...
 > > > Hi,
 > from
 3
 > series
 > > > nice.
 > > > actually
 > > > plotted?
 > > > Thanks,
 > > > Mike
FUDForum. Page generated in 0.04087 seconds
