Home » Eclipse Projects » Eclipse Scout » Loading master detail data on tabboxes(Loading master detail data on tabboxes)
Loading master detail data on tabboxes [message #1534068] Sun, 28 December 2014 19:04 Go to next message
what is the best way to load the master detail data of the "TABS" ?
see below screenshot
index.php/fa/20319/0/
Only the data of the first tab should be retrieved when opening the form.
All other tabs should only have the data imported when they are consulted.
The data on the other tabs are almost always detail tables to the master.
(e.g. in this example translations, aromas, production methods used etc)
Below an example of the second tab sheet.
It is only necessary to import that data when on is looking at the tab sheet
index.php/fa/20320/0/
Is this possible ?
Kind regards
Tore
Re: Loading master detail data on tabboxes [message #1535514 is a reply to message #1534068] Mon, 29 December 2014 14:19 Go to previous messageGo to next message
Hello there,
I have not tried it yet. But I'll also need some kind of lazy loading in my app. My approach would be the org.eclipse.scout.rt.client.ui.form.fields.tabbox.AbstractTabBox.execTabSelected(IGroupBox) callback. There I would call a service to fill the TableFieldData according to the selected IGroupBox. The only open question for me is, how i can specifically invoke the importFormData method just for this particular table field, in order to get it displayed on the screen as well?
Regards, Peter
Re: Loading master detail data on tabboxes [message #1544444 is a reply to message #1535514] Sat, 03 January 2015 15:18 Go to previous messageGo to next message
Dear Peter,
based on your hint, I found that below filtering could work :
      protected void execTabSelected(IGroupBox selectedBox) throws ProcessingException {
          if (selectedBox.equals(getVertalingenBox()))
          System.out.print("getVertalingenBox");
        else if (selectedBox.equals(getAccijnsvooraadfichesBox()))
          System.out.print("getAccijnsvooraadfichesBox");
        else if (selectedBox.equals(getAromasBox()))
          System.out.print("getAromasBox");
        else if (selectedBox.equals(getKeurmerkenBox()))
          System.out.print("getKeurmerkenBox");
        else if (selectedBox.equals(getSmakenBox()))
          System.out.print("getSmakenBox");
        else if (selectedBox.equals(getGistingswijzenBox()))
          System.out.print("getGistingswijzenBox");
If you click on a particular tab, one ends in the correct part of the code.
As you mention, from there it is trying to identify how to get the data into the tablefield.
Thanks already for the hint.
Kind regards
Tore
Re: Loading master detail data on tabboxes [message #1545444 is a reply to message #1544444] Sun, 04 January 2015 04:51 Go to previous messageGo to next message
no problem at all Smile
When you found a solution how to lazy load the tables please let me know Smile
Did you manage to to load your one-to-many relationships with one SQL.selectInto(...) already?
If yes, how did you do that?
Peter
Re: Loading master detail data on tabboxes [message #1545452 is a reply to message #1545444] Sun, 04 January 2015 04:59 Go to previous messageGo to next message
Dear Peter,
No realy sure what you mean.
What I have done is in the "load service" add different calls for all the tabs
(Don't know if it is a good way, but it seems to be working)
I have know something like :
    cSQLVertalingen = "call sp_tdtdrankv_selectdetail(:drankNr) ";
    oVertalingen = SQL.select(cSQLVertalingen, formData);
    formData.getVertalingenTable().clearRows();
    for (Object[] oVertaling : oVertalingen) {
      formData.getVertalingenTable().addRow(oVertaling);
    cSQLAccvoorraadfiches = "call sp_tdtaccfch_selectdetailmetdranknr(:drankNr, :taalnr)";
    oAccvoorraadfiches = SQL.select(cSQLAccvoorraadfiches, formData, new NVPair("taalnr", nTaalnr));
    formData.getAccijnsvoorraadfichesTable().clearRows();
    for (Object[] oAccvoorraadfiche : oAccvoorraadfiches) {
      formData.getAccijnsvoorraadfichesTable().addRow(oAccvoorraadfiche);
    cSQLAromas = "call sp_tdtdrankar_selectdetail(:taalnr, :drankNr, :aromanr)";
    oAromas = SQL.select(cSQLAromas, formData, new NVPair("taalnr", nTaalnr), new NVPair("aromanr", 0));
    formData.getAromasTable().clearRows();
    for (Object[] oAroma : oAromas) {
      formData.getAromasTable().addRow(oAroma);
    cSQLKeurmerken = "call sp_tdtdrankkm_selectdetail(:taalnr, :drankNr, :keurmerknr)";
    oKeurmerken = SQL.select(cSQLKeurmerken, formData, new NVPair("taalnr", nTaalnr), new NVPair("keurmerknr", 0));
    formData.getKeurmerkenTable().clearRows();
    for (Object[] oKeurmerk : oKeurmerken) {
      formData.getKeurmerkenTable().addRow(oKeurmerk);
    cSQLSmaken = "call sp_tdtdranksm_selectdetail(:taalnr, :drankNr, :smaaknr)";
    oSmaken = SQL.select(cSQLSmaken, formData, new NVPair("taalnr", nTaalnr), new NVPair("smaaknr", 0));
    formData.getSmakenTable().clearRows();
    for (Object[] oSmaak : oSmaken) {
      formData.getSmakenTable().addRow(oSmaak);
    cSQLGistingswijzen = "call sp_tdtdrnkgst_selectdetail(:taalnr, :drankNr, :gistwnr)";
    oGistingswijzen = SQL.select(cSQLGistingswijzen, formData, new NVPair("taalnr", nTaalnr), new NVPair("gistwnr", 0));
    formData.getGistingswijzenTable().clearRows();
    for (Object[] oGistingswijze : oGistingswijzen) {
      formData.getGistingswijzenTable().addRow(oGistingswijze);
As far as I think it is working; I have one call to the server to fill in the formData object, but I have different calls to the database server.
Kind regards
Tore
Re: Loading master detail data on tabboxes [message #1546042 is a reply to message #1545452] Sun, 04 January 2015 12:59 Go to previous messageGo to next message
I found what I was looking for:
https://code.google.com/p/sakilapp/source/browse/scout/net.sakilapp.server/src/net/sakilapp/server/services/process/FilmProcessService.java?name=luna#107
Perhaps this helps too.
Re: Loading master detail data on tabboxes [message #1571356 is a reply to message #1546042] Sun, 18 January 2015 10:32 Go to previous message
With regards to lazy loading.
This seems to work, but maybe somebody with more experience in the scout framework can validate if it is good practice :
   public class DrankInfoTabBox extends AbstractTabBox {
          DrankenFormData drankenFormData = new DrankenFormData();
          exportFormData(drankenFormData);
          IDrankenService service = SERVICES.getService(IDrankenService.class);
          drankenFormData = service.loadDrankenAromas(drankenFormData);
          importFormData(drankenFormData);
          getAromasTableField().reloadTableData();
The data of this tab is only loaded when the tabpage is selected.
The code might need some tweeking to prevent
  • reloading each time the tab is clicked.
  • copying back and forth of all the formdata. Maybe it is faster if only the table data would be copied.
Tore
Previous Topic:Change SubTitle fontsize on Forms
Next Topic:Tab layout and selection issues
Current Time: Sun Jul 27 12:56:10 EDT 2025
Powered by FUDForum. Page generated in 0.04289 seconds
