Page Breaks on PDF & nested grids [message #154381] |
Wed, 19 April 2006 12:30  |
Originally posted by: huffordkevin.johndeere.com
I'm experiencing a problem with page breaks when the report is rendered in
PDF. This is on BIRT 2.0.1.
It seems that if I place a grid on the report(Grid A), then inside this
grid nest another grid(Grid B). Then if I set Grid B's pageBreakBefore =
Always, the resulting PDF document doesn't contain the page break.
If I put the 2 grids in sequence on the report, and don't nest them then
the page break works as expected.
So my question is, do page breaks only work on top-level components now?
Or is this a bug? The page breaks on nested grids seemed to work ok in
BIRT 1.0.1.
-Kevin
FUDForum. Page generated in 0.02708 seconds
