Home » Modeling » GMF (Graphical Modeling Framework) » Live Validation/Audit Rules
Live Validation/Audit Rules [message #153661] Fri, 05 October 2007 05:26 Go to next message
Originally posted by: martinschmidt.83.web.de
Hi @all,
i want to implement some rules i cant describe with my ecore-model. so i
wanted to use audit rules with ocl. i
Re: Live Validation/Audit Rules [message #153683 is a reply to message #153661] Fri, 05 October 2007 07:04 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
My best guess is that there is a logical error in you ocl statement (and
that your setup is correct) - maybee you could post the ocl?
Tomas
Martin Schmidt wrote:
> Hi @all,
> wanted to use audit rules with ocl. i´ve seen, it is implemented in
> mindmap-example:
> - topics must have a name
> - one rule for avoiding circles of the connections
> but it does not work. in the past, there was a message in the error
> log..something like: "you dont have an ocl-parser". so i downloaded the
> feature for it as it was described in a past Newsgroup Thread. Now the
> message do not appear anymore. But the rules wont work. I dont get the error
> message, which is defined in audit rule...
> Somebody knows why?
Re: Live Validation/Audit Rules [message #153709 is a reply to message #153683] Fri, 05 October 2007 07:14 Go to previous messageGo to next message
Originally posted by: ijerez2001.gmail.com
Perhaps because you generate a RCP application code, in RCP, the live
validation don´t work, and you have to press the menu Validate button, it
show to you a icon in your figure that they don´t validate.
It work well if it is a non-RCP application.
Also, you can do live validation manually, change the diagram code and
introding MessageDialog.operError(....).
Regards. Iván.
"Tomas Zijdemans" <trommas@yahoo.com> escribió en el mensaje de
noticias:fe55nr$ui9$1@build.eclipse.org...
> Regards,
> Tomas
>> Hi @all,
>> mindmap-example:
>> error message, which is defined in audit rule...
>> Somebody knows why?
Re: Live Validation/Audit Rules [message #153727 is a reply to message #153661] Fri, 05 October 2007 07:20 Go to previous messageGo to next message
Hi !
Maybe you forgot to set Validation Provider at priority medium or more
on your gmfgen. You should check it !
Greets
Re: Live Validation/Audit Rules [message #153759 is a reply to message #153727] Fri, 05 October 2007 07:41 Go to previous messageGo to next message
hi guys,
thanx for your fast answers. but it was not yet the right thing i needed ;)
I am working with the Mindmap example at the moment, because my thougt was
"i dont need to create my own olc-statements, if the examples do not work".
so i hope the OLC constraints they used in the exampe are correct.
Also i use not an RCP application.
I tried to set the Validation Provider priority to medium, high etc. Nothing
happened. Where
Re: Live Validation/Audit Rules [message #153799 is a reply to message #153759] Fri, 05 October 2007 08:01 Go to previous messageGo to next message
and the validation decorators??
Also your priority validation decorators.
"Martin Schmidt" <martinschmidt.83@web.de> escribió en el mensaje de
noticias:fe57sh$7k7$1@build.eclipse.org...
> hi guys,
> work". so i hope the OLC constraints they used in the exampe are correct.
> Nothing happened. Where´s my fault?
> "Julien Forot" <julien.forot@bull.net> schrieb im Newsbeitrag
> news:fe56ld$2m9$1@build.eclipse.org...
>> Hi !
>> Maybe you forgot to set Validation Provider at priority medium or more on
>> Greets
Re: Live Validation/Audit Rules [message #153812 is a reply to message #153799] Fri, 05 October 2007 08:17 Go to previous messageGo to next message
Sorry, i found my fault. The value "use in live mod" of the seperate Audit
Rules was set to false. But now the old problem appears again.
"Warning
Fri Oct 05 14:13:22 CEST 2007
No parser is registered for the "OCL" language. Constraints expressed in
this language will not be evaluated."
Can somebody explain for a beginner, how OCL-Parser in registered step by
step?
Thank u a lot!
"Iv
Re: Live Validation/Audit Rules [message #154086 is a reply to message #153812] Mon, 08 October 2007 08:16 Go to previous messageGo to next message
I had the same problem as you.
Try adding the 'EMF Validation Framework OCL Integration' plugin from the
Europa Discovery Site. That solved my problem! :)
Johan
> "Warning
> step?
> Thank u a lot!
Re: Live Validation/Audit Rules [message #154583 is a reply to message #154086] Wed, 10 October 2007 04:41 Go to previous message
Thanx! This was what i needed. Indeed, I did it before, but i forgot to
check out the new plugin for the project in "open run dialog" ;)
"Johan Linander" <johan@mediaempire.se> schrieb im Newsbeitrag
news:7f4d9a14f932f9fde3909a84d64c3f09$1@www.eclipse.org...
> Regards
> Johan
>> Audit Rules was set to false. But now the old problem appears again.
>> "Warning
>> step?
>> Thank u a lot!
Previous Topic:Programmatically creating a link
Next Topic:Properties view in formdialog
Current Time: Fri Nov 07 00:37:26 EST 2025
Powered by FUDForum. Page generated in 0.05144 seconds
