Home » Eclipse Projects » Eclipse Platform » Eclipse Debug events and halt states
Eclipse Debug events and halt states [message #152555] Mon, 03 November 2003 14:04 Go to next message
I'm implementing a debugger and I'm unable to discern between halting for
a breakpoint vs. stepping (this information isn't reliably exposed to me)
So far, it doesn't seem to impact the UI or interactions with the user, at
least within my debugger. It seems I should be firing the correct events,
and I don't know who else might be listening. Is there any chance I'll
run into trouble here if, say, I'm always using the BREAKPOINT event, even
if it was a step or a user suspend which caused the halt??
Adam
Re: Eclipse Debug events and halt states [message #152674 is a reply to message #152555] Tue, 04 November 2003 04:12 Go to previous messageGo to next message
You need to create an array of DebugEvent(s),
and call DebugPlugin.getDefault().fireDebugEventSet( the array of events ).
The debug event(s) contain the info telling what happened (bp, step),
and the debug plugin will update the debug view.
Steve
Re: Eclipse Debug events and halt states [message #152826 is a reply to message #152555] Tue, 04 November 2003 13:14 Go to previous messageGo to next message
There is no "breakpoint" event. There is a suspend event, with a detail that
tells why the suspend happened - a breakpoint or a step, etc.
Darin
"Adam Peller" <apeller@us.ibm.com> wrote in message
news:bo68sr$qq$1@eclipse.org...
> Adam
Re: Eclipse Debug events and halt states [message #153106 is a reply to message #152826] Wed, 05 November 2003 11:14 Go to previous messageGo to next message
Yes, sorry, this is what I meant. Given that I cannot make the
distinction, I am faced with using something like "BREAKPOINT" for detail,
regardless of the actual cause (vs. stepping, client request). Just
wondering if any Eclipse code (outside of my own) actually cares what's in
this event. I'm assuming it isn't required for some sort of debugger
state information or UI.
Adam
> Darin
> > Thanks,
> > Adam
Re: Eclipse Debug events and halt states [message #153532 is a reply to message #153106] Thu, 06 November 2003 09:41 Go to previous message
The debugger will automatically switch to or open the debug perspective when
a breakpoint is hit, and the window containing the debugger will be
activated (i.e. flash on Windows).
Darin
news:bob7le$f07$1@eclipse.org...
> Adam
that
> > Darin
for
me)
user, at
events,
I'll
even
> > > Thanks,
> > > Adam
Previous Topic:Searching for Feature/Update Site Tutorial
Next Topic:Problem with RMI in eclipse (ClassNotFound)
Current Time: Tue Nov 04 02:40:08 EST 2025
Powered by FUDForum. Page generated in 0.06131 seconds
