Home » Language IDEs » Java Development Tools (JDT) » Eclipse 3.0 M8, Ant plugin, Could not find one or more classes
Eclipse 3.0 M8, Ant plugin, Could not find one or more classes [message #152912] Wed, 07 April 2004 01:08 Go to next message
Originally posted by: anony_java.anon.foobar
I am using Eclipse 3.0M8 on Windows XP.
The Ant plugin in Eclipse 3.0 M8 is not configured properly.
When I try to run an Ant build script inside of Eclipse, I see
this error:
Could not find one or more classes: "org.apache.tools.ant.BuildException"
I looked at the Ant configuration.
Windows ---> Preferences --> Ant --> Runtime --> Classpath
I see this:
Ant Home Entries (c:\eclipse\plugins\org.apache.ant_1.6.1)
/c:/eclipse/plugins/org.apache.ant_1.5.4/lib/ant.jar
/c:/eclipse/plugins/org.apache.ant_1.5.4/lib/optional.jar
/c:/j2sdk1.4.2_02/lib/tools.jar
I've got Ant plugin 1.6.1 and it is trying to load the Ant 1.5.4 jar files
My plugins folder, c:\eclilpse\plugins, contains a subdirectory:
The org.apache.ant_1.5.4 subdirectory does not exist
Re: Eclipse 3.0 M8, Ant plugin, Could not find one or more classes [message #152920 is a reply to message #152912] Wed, 07 April 2004 01:30 Go to previous messageGo to next message
I found a workaround:
1) Windows ---> Preferences --> Ant --> Runtime --> Classpath
2) Ant Home Entries
Remove: /c:/eclipse/plugins/org.apache.ant_1.5.4/lib/ant.jar
Remove:
Add: /c:/eclipse/plugins/org.apache.ant_1.6.1/lib/ant.jar
Add:
/c:/eclipse/plugins/org.apache.ant_1.6.1/lib/ant-launcher.ja r
> this error:
> I see this:
Re: Eclipse 3.0 M8, Ant plugin, Could not find one or more classes [message #152936 is a reply to message #152920] Wed, 07 April 2004 02:52 Go to previous messageGo to next message
I have not seen this state in my testing.
You best bet is use the "Restore Defaults" functionality or to make use of
the Set Ant Home...
Setting only the ant.jar and the ant-launcher.jar does not give you the full
set of required Ant JARs.
HTH
Darins
"Anony" <anony_java@anon.foobar> wrote in message
news:c503bn$pn9$1@eclipse.org...
> 2) Ant Home Entries
> Remove:
> Add:
> > this error:
> > I see this:
files
Re: Eclipse 3.0 M8, Ant plugin, Could not find one or more classes [message #153067 is a reply to message #152936] Wed, 07 April 2004 10:27 Go to previous messageGo to next message
I think I know how my environment got into this state.
Prior to installing 3.0 M8, I was using 3.0 M6 on this computer.
Using 3.0 M6, I created a workspace called c:\myworkspace
Prior to installing 3.0 M8, I removed 3.0 M6 from
my system ( rm -rf c:\eclipse )
After I installed 3.0 M8, I told Eclipse to use my existing workspace,
c:\myworkspace
> the Set Ant Home...
> HTH
> Darins
>>2) Ant Home Entries
>> Remove:
>> Add:
>>>this error:
>>>I see this:
> files
Re: Eclipse 3.0 M8, Ant plugin, Could not find one or more classes [message #153075 is a reply to message #153067] Wed, 07 April 2004 11:38 Go to previous message
As I stated in the Ant mailing list, please log a bug report with the
relevant details.
And there is no need to double post. I would suggest that the newsgroup is
the best place for these types of discussions.
Darins
news:c512q4$3au$1@eclipse.org...
> c:\myworkspace
of
> > the Set Ant Home...
full
> > HTH
> > Darins
> >>2) Ant Home Entries
> >> Remove:
> >> Remove:
> >> Add:
> >>>this error:
> >>>I see this:
> > files
Previous Topic:CVS/SVN checkouts in same package tree
Next Topic:Java object monitor plugin
Current Time: Thu Jul 24 14:16:36 EDT 2025
Powered by FUDForum. Page generated in 0.27888 seconds
