Home » Modeling » GMF (Graphical Modeling Framework) » How to change node's image?
How to change node's image? [message #152805] Mon, 01 October 2007 15:05 Go to next message
Originally posted by: napo.NOPRIVATEMESSAGE.com
Hi all,
I'm working on a graphical editor using GMF dashboard.
I know how to change the small icon inside the palette, concerning my nodes.
But when I insert a node in my diagrams, in the upper left corner there's
always the default icon.
I tried to change the "Large bundle image" but it doesn't work. And what
exactly "Large bundle image" stands for???
I also tried to study the Taipan example from Eclispe, but I didn't
understand... :-(
So, is it possible to change the node's image? How?
Marco
Re: How to change node's image? [message #152843 is a reply to message #152805] Tue, 02 October 2007 04:39 Go to previous messageGo to next message
Originally posted by: snej_NO-SPAM_.esuark.de
I don't know if there is an easyer method, i changed the getImage()
methods in the generated .edit plugin. You will find this method in the
XXXItemProvider.java. If you change code there, don't forget to add a
"NOT" behind the @generated tag.
hth
Jens
Re: How to change node's image? [message #152885 is a reply to message #152843] Tue, 02 October 2007 06:08 Go to previous messageGo to next message
Tnx, but I'd like not to modify the Java code if it's possible. :-\
The only solution I found at the moment is to overwrite the GIF file created
by Eclipse. But it's not a great solution...
Marco
Re: How to change node's image? [message #152909 is a reply to message #152885] Tue, 02 October 2007 08:08 Go to previous messageGo to next message
--------------000604080106030103050102
Marco,
The EMF generated code is intended to be specialized by hand so there's
no need to avoid that. It's of course fine (and better) to replace the
generated GIFs since these are just placeholders for your own graphical
talents. The generator will never overwrite an existing .gif file.
> Hi
> Marco
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Marco,<br>
<br>
no need to avoid that. &nbsp; It's of course fine (and better) to replace
the generated GIFs since these are just placeholders for your own
graphical talents.&nbsp; The generator will never overwrite an existing .gif
file.<br>
<br>
<br>
napo wrote:
<blockquote cite="mid:fdt5b5$4f3$1@build.eclipse.org" type="cite">
<blockquote type="cite">
<pre wrap="">I don't know if there is an easyer method, i changed the getImage()
</pre>
</blockquote>
<pre wrap=""><!---->
Marco
</pre>
</blockquote>
<br>
</body>
</html>
--------------000604080106030103050102--
Re: How to change node's image? [message #152917 is a reply to message #152909] Tue, 02 October 2007 08:10 Go to previous messageGo to next message
>The EMF generated code is intended to be specialized by hand so there's no
Well, fine.
But now, I've a question: what exactly "Large bundle image" stands for???
Marco
Re: How to change node's image? [message #152925 is a reply to message #152917] Tue, 02 October 2007 08:46 Go to previous messageGo to next message
--------------000406020300090409070505
Marco,
Sorry, I have no idea. I can only answer the EMF parts of questions here...
> Well, fine.
> Hi
> Marco
<html>
<head>
</head>
Marco,<br>
<br>
Sorry, I have no idea.&nbsp; I can only answer the EMF parts of questions
here...<br>
<br>
napo wrote:
<blockquote cite="mid:fdtcft$9jq$1@build.eclipse.org" type="cite">
<pre wrap="">The EMF generated code is intended to be specialized by hand so there's no
</pre>
</blockquote>
Well, fine.
Marco
</pre>
</blockquote>
<br>
</body>
</html>
--------------000406020300090409070505--
Re: How to change node's image? [message #152933 is a reply to message #152917] Tue, 02 October 2007 08:57 Go to previous messageGo to next message
You can set a property in the palette options to show "large icons". So
you can define 2 different icons for every tool, a small one and a
detailed larger one.
jens
Re: How to change node's image? [message #152941 is a reply to message #152933] Tue, 02 October 2007 08:58 Go to previous messageGo to next message
Great! Thanks!
Marco
Re: How to change node's image? [message #152963 is a reply to message #152941] Tue, 02 October 2007 09:16 Go to previous messageGo to next message
> Great! Thanks!
The options you get at runtime i forgot to say. By rightklicking in the
palette :).
Re: How to change node's image? [message #152977 is a reply to message #152963] Tue, 02 October 2007 09:22 Go to previous message
> palette :).
The GMF project and the automation precedure are great... but a little
complex. :-\
Marco
Previous Topic:Download link for Consolidated zip 2.01 Broken
Next Topic:need guidance
Current Time: Fri Sep 19 01:50:25 EDT 2025
Powered by FUDForum. Page generated in 0.04996 seconds
