Writing to model [message #152751] |
Mon, 01 October 2007 10:05  |
Originally posted by: kmcglinn.gmail.com
Hey Guys,
I notice that although I specify a label for my ecore attributes, it seems
that they will not be saved to the xmi file when I save the diagram. Is
there any way to force an xmi attribute to appear in the gmf file?
For example, lets say I have a transition between two nodes with an
attribute "condition"
<containsActivities xsi:type="service:TransformationCondition"
source="//@containsSwimlanes.0/@containsActivities.2"
target="//@containsSwimlanes.0/@containsActivities.1" condition=".."/>
If I had not entered ".." into the model I would not have got:
target="//@containsSwimlanes.0/@containsActivities.1" condition=""/>
But rather
target="//@containsSwimlanes.0/@containsActivities.1"/>
Which crashes my parser...any way to force the attribute to be created,
empty or not?
Guy.
Re: Writing to model [message #152761 is a reply to message #152751] |
Mon, 01 October 2007 10:09  |
Guy,
EMF will only save attributes for which eIsSet is true so generally you
must set the value if you want it to be saved. If you use
XMLResource.OPTION_KEEP_DEFAULT_CONTENT as a save option, then features
with an explicit non-null default will serialize that default.
Guy Incognito wrote:
> Hey Guys,
> seems that they will not be saved to the xmi file when I save the
> diagram. Is there any way to force an xmi attribute to appear in the
> gmf file?
> But rather
> created, empty or not?
> Guy.
FUDForum. Page generated in 0.04827 seconds
