| JNI with Eclipse [message #152399] |
Mon, 05 April 2004 13:02  |
I have a project that was originally written using Metrowerks
CodeWarrior that uses JNI, however the
same code built with Eclipse results in java.lang.UnsatisfiedLinkError
exceptions. Is there anything
unique to the Eclipse environment that is required when accessing native
libaries via JNI?
Bob
| Re: JNI with Eclipse [message #152764 is a reply to message #152723] |
Tue, 06 April 2004 13:11   |
Sam,
This is positively, absolutely NOT a source issue, but here you go. The
ONLY difference between the
CW version that works and this code is that Eclipse will not permit me to
place MyNativeAPI.java in the
default package. The CW version of MyNativeAPI.java is in the default
package.
jni generated .h file:
/* DO NOT EDIT THIS FILE - it is machine generated */
#include <jni.h>
/* Header for class MyNativeAPI */
#ifndef _Included_ MyNativeAPI
#define _Included_ MyNativeAPI
#ifdef __cplusplus
extern "C" {
#endif
* Class: MyNativeAPI
* Method: MyJNI_Open
* Signature: ([J)J
JNIEXPORT jlong JNICALL Java_ MyNativeAPI_MyJNI_1Open
(JNIEnv *, jobject, jlongArray);
#ifdef __cplusplus
#endif
#endif
MyNativeAPI.java:
package com.dog.cat; // changed to protect the innocent, not
present in the CW version
public class MyNativeAPI {
public MyNativeAPI() {
* Native Open
public native long MyJNI_Open(long api[]);
native .c code
#include <jni.h>
#include "MyNativeAPI.h"
#include <stdio.h>
* Signature: ([J)J
JNIEXPORT jlong JNICALL Java_MyNativeAPI_MyJNI_1Open(
JNIEnv *env, jobject jobj,
jlongArray japi)
starlic_handle_t* api;
starlic_error_t err;
err = my_open(&api);
if (err == starlic_ok) {
(*env)->SetLongArrayRegion(env, japi, 0, 1, (jlong*)&api);
return (jlong)err;
Sam Mesh wrote:
> Bob, please send the sources (a reasonable small part of them:)
> Sam Mesh
| Re: JNI with Eclipse - solved [message #153238 is a reply to message #152399] |
Wed, 07 April 2004 17:19  |
> libaries via JNI?
> Bob
I've resolved this and wanted to post the solution in case anyone runs
into something similar. The CW
version of this project had the class defining the native methods in the
default package, however, the
Eclipse project required this class (because it was imported by other
classes in another package) to be
in a named package. What I didn't realize was that running javah -jni
required the complete package
class name to be specified. For example, given class
com.mycompany.dogs.Collie, you need to specify
javah -jni com.mycompany.dogs.Collie. Seems like something javah could
figure out on it's own;-(
FUDForum. Page generated in 0.05129 seconds
