Home » Language IDEs » ServerTools (WTP) » Debug servlet with Tomcat require restart after each modification
Debug servlet with Tomcat require restart after each modification [message #151839] Wed, 14 December 2005 02:12 Go to next message
Originally posted by: whisk_whisk.yahoo.com
Hi all,
I am now using the eclipse 3.1.1, WTP 1.0RC4, and Tomcat 5.0 as my
development platform.
The Tomcat is started in debug mode and all break points are stopped
successfully.
However, everytime I have modified a servlet, even just adding a blank
space, triggers a restart of the Tomcat server.
What I expect is the hotswap of the classes with no structual change. How
should I configure the Eclipse and Tomcat to achieve this?
Thank you very much for your help!
Best wishes,
WHiSK
Re: Debug servlet with Tomcat require restart after each modification [message #152252 is a reply to message #151839] Wed, 14 December 2005 07:48 Go to previous messageGo to next message
Originally posted by: dserodio.gmail.com
WHiSK wrote:
> Hi all,
> successfully.
> How should I configure the Eclipse and Tomcat to achieve this?
I expect that too, if the "Tomcat Plugin" can do it, why can't WTP?
TIA,
Daniel Serodio
Re: Debug servlet with Tomcat require restart after each modification [message #152267 is a reply to message #151839] Wed, 14 December 2005 09:04 Go to previous messageGo to next message
> successfully.
You mean an actual Servlet class? You might want to open a bug if
you're seeing this and Sysdeo's plugin handles it better.
- Nitin
Re: Debug servlet with Tomcat require restart after each modification [message #152317 is a reply to message #152252] Wed, 14 December 2005 11:05 Go to previous messageGo to next message
Daniel Serodio wrote:
> WHiSK wrote:
>> Hi all,
>> successfully.
> TIA,
> Daniel Serodio
This is really strange! Is there any config trick to make hotswap
possible?
I prefer a simple startup rather than those complicated remote debugging.
Re: Debug servlet with Tomcat require restart after each modification [message #152323 is a reply to message #152267] Wed, 14 December 2005 11:08 Go to previous messageGo to next message
>> successfully.
yup... a Servlet class, or even a HTML page change will trigger a restart.
I tried Sysdeo's plugin but the settings are not user friendly, and seems
do not support multiple server.
May I ask one more question? Is this just happen on wtp with tomcat? how
about wtp with websphere?
Thanks all!
Re: Debug servlet with Tomcat require restart after each modification [message #152337 is a reply to message #152317] Wed, 14 December 2005 14:55 Go to previous messageGo to next message
> possible? I prefer a simple startup rather than those complicated remote
> debugging.
Point 1) The Hot-swap part is standard with Sun JDK 1.5 just launch the
runtime in debug mode.
Point 2) Now to stop Tomcat reloading the servlet one config trick maybe
to have a file:
WebContent/META-INF/context.xml:
and in that file might be something like this:
---- SNIP ----
<Context path="/mycontext"
debug="1"
reloadable="false">
<Parameter name="runtimeEnvironment" value="DEVEL" override="false"/>
<!-- BLAH BLAH BLAH ... -->
</Context>
---- SNIP ----
Note the reloadable="false" this tells Tomcat that changes inside the
WEB-INF/classes hierachy are not to auto-re-deploy the web-app.
Point 3) Now if you are saying that the Tomcat Server Runtime driver is
forcing a reload you'll need to open a bug for since thats certainly not
necessary in all^H^H^Hmost situations.
But before opening the bug you need to be sure what you are seeing is a
forced reload by the Tomcat Server Runtime driver and not an
auto-re-reploy by tomcat itself because its operating as-if
reloadable="true".
I will upgrade WTP later and confirm Point 3 really isn't the case, I
did not get that feeling from RC3 or RC4, the development process was
really getting back that warm and fuzzy feeling I get inside.
Darryl
Re: Debug servlet with Tomcat require restart after each modification [message #152632 is a reply to message #152337] Fri, 16 December 2005 13:31 Go to previous messageGo to next message
Thank you very much!!!
the reloadable="false" is the key word of not to reload all the
servlets!!!!!!
or we can simple double click on the Server->Server
Configuration->Modules->Edit->Untick Auto Reloading Enabled
Once again, thank you all!
Re: Debug servlet with Tomcat require restart after each modification [message #152648 is a reply to message #152632] Fri, 16 December 2005 17:23 Go to previous messageGo to next message
You know I have completely forgotten that "Modules" tab exists. There
was another query open for changing the Context path for a WebModule.
This looks like the place in UI that should do the trick.
Darryl
Re: Debug servlet with Tomcat require restart after each modification [message #152673 is a reply to message #152648] Sat, 17 December 2005 01:03 Go to previous message
> Darryl
Yup~ exactly! but that tab can easily be ignored. the tab size should be
made bigger! it is toooo small now, i noticed it just by luck. >_<
happy programming!
Previous Topic:external jars
Next Topic:IWAB0489E Error
Current Time: Sat Jul 19 00:04:47 EDT 2025
Powered by FUDForum. Page generated in 0.35725 seconds
