Home » Newcomers » Newcomers » Required plug-ins vs. Plugin dependencies
Required plug-ins vs. Plugin dependencies [message #152217] Fri, 12 May 2006 08:59 Go to next message
Originally posted by: katja.henttonen.vtt.fi
Hi all!
Could someone kindly explain me the difference between "Plugin
Dependencies" (in the Manifest Editor)
and "Required Plugins" (visible e.g. in Package Explorer and Properties -
Java Build Path - Required Plugins).?
I have added "eclipse.org.jdt.core" into Plugin dependecies (not optional),
but it does not appear
in the "Required Plugins" listing. As a consequence, I can't include it
into Java Build Path and get
the error "Import cannot be resolved".
So how can I modify "required plugins" listing? Why is it independent from
the "Plugin depencies"?
I have Eclipse 3.1.2 and Java 5 on XP.
All replys are appreciated. Thank you in advance.
Kind regards,
Katja Henttonen
Re: Required plug-ins vs. Plugin dependencies [message #152227 is a reply to message #152217] Fri, 12 May 2006 09:52 Go to previous messageGo to next message
Originally posted by: cesar_olavo.hotmail.com
Hi Katja,
plugin dependencies is the runtime classpath and the build path is...the
build classpath. A way of synchronize both is right click package explorer>
pde tools > update classpath.
Cesar
"Katja Henttonen" <katja.henttonen@vtt.fi> a
Re: Required plug-ins vs. Plugin dependencies [message #152567 is a reply to message #152227] Mon, 15 May 2006 07:09 Go to previous messageGo to next message
Hi again!,
Thank you, Cesar, for explaining the difference. There are still a couple
of issues:
1) I tried update "class path" before but it does not have any affect. I
recall it used
to work with an example project, but it does not work with mine.Why could
that be?
2) I have added external libraries to the build path. Every time I do
"update
class path" Eclipse removes these libraries from the build path. How
I can prevent this?
Many thanks again.
Katja
"cesar" <cesar_olavo@hotmail.com> wrote in message
news:e423ui$e9g$1@utils.eclipse.org...
> Hi Katja,
> explorer> pde tools > update classpath.
> Cesar
Re: Required plug-ins vs. Plugin dependencies [message #152898 is a reply to message #152567] Wed, 17 May 2006 04:11 Go to previous message
Katja Henttonen wrote:
>Hi again!,
>of issues:
>recall it used
>that be?
>"update
>I can prevent this?
Update hammers the content of your manifest.mf (or plugin.xml) runtime
information onto the Java build path properties. You have to declare all
those libraries in the manifest.mf (or plugin.xml).
Dani
>Many thanks again.
>Katja
>>Hi Katja,
>>Cesar
>>"Katja Henttonen" <katja.henttonen@vtt.fi> a écrit dans le message de
>>news: e420s8$1iq$1@utils.eclipse.org...
>>>Hi all!
>>>optional), but it does not appear
>>>from the "Plugin depencies"?
>>>Kind regards,
>>>Katja Henttonen
Previous Topic:t
Next Topic:Question: Dependencies between multiple projects
Current Time: Sat Nov 08 18:07:36 EST 2025
Powered by FUDForum. Page generated in 0.07513 seconds
